Question about Gateway MX6025 Notebook
Manual for disassembling
I hav a gateway mx6025 and need to resolder the ac adapter post but I'm having problems disassembling it. Is there a manual or site that can instruct me on doing so?
Bwil
Systems Administrator
  • Anonymous Apr 04, 2008
    necesito el drive de sonido de gateway mx6025 pc notebook
I got mine open in under 30 minutes. It's really pretty easy. I don't know how far you got, but there's only a few tricks here. Take the hard drive, CD drive, and battery out, first. There are four screws hidden by the battery. Then also, you have to unscrew and remove the heatsink/fan assembly before you can get the mobo out, so you have to remove the large panel on the bottom. Finally, once you remove the heatsink/fan and all the screws holding the mobo to the bottom of the case, it may still feel stuck. You have to wiggle the audiojack ports out first, then lift it out minding the wirewire port.
Posted on Feb 24, 2008
  • 84 Answers
Http://laptop-support.net/Laptop-disassembly-guides/The-laptop-disassembly-guide.html
this link might help.
Posted on Feb 10, 2008
Why won't my gateway MD78 power on?
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Replacement Gateway MD78 AC Adapter 65Watt 19V 3.42A Option
Replacement Gateway MD78 MD7800 AC Adapter 90Watt 19V 4.74A
Nov 29, 2012 | Gateway Computers & Internet
I hav My Acdelco 34300 4 IN 1 Power Pack With Air Compresser I need manual for it can you halp me?
I have the manual for the ACDelco 34300 and I need the AC Adapter for it. If you can give me the DC Volts and Amps listed on the adapter, I can send you the manual in PDF format.
Dec 29, 2011 | Cars & Trucks
Power adapter is good, but Gatway MX6025 will not power on. It does power on briefly with battery installed. I've tested the ac adapter with a multimeter and it appears to be good. Green light on,...
Try to check with another adapter if possible.
The connector of the laptop might be damaged. so the battery is not charging and also not staring laptop on AC power. Check the ac connector of laptop.
Jun 08, 2011 | Gateway MX6025 Notebook
Laptop won't power on with ac adapter or battery
Could be a combination of things.
1) Battery is low. Not enough power to turn the laptop on.
Caused by;
2) AC adapter has a plug on the end of the cable. The plug plugs into a DC Power Jack on the laptop.
The DC Power Jack is bad.
2a) The DC Power Jack has a bad connection to the motherboard, (Cracked solder joints), and/or the jack itself is bad.
2b) Center Pin is loose in the jack's mount.
The back of the Center Pin where it mounts has become loose.
2c) The plastic body of the jack, which composes the jack's case, is cracked. This allows movement of the Center Pin.
2b, and 2c cause a bad connection with the AC adapter plug.
No charge to the Battery, no power to the laptop.
http://www.laptopjacks.com/view_part/For-Gateway-MX6920-DC-Power-Jack-GW51425.html
[ If this is the case the DC Power Jack needs to be resoldered to the motherboard. The cracked solder joints need to be re-melted, (Reflowed)
Entire laptop needs to be disassembled down to the bare motherboard in your hand.
(No Processor, Ram Memory, or any adapter cards mounted to the motherboard. Nada)
OR,
The DC Power jack needs to be replaced.
This entails disassembling the entire laptop, down to just the motherboard in your hand. (Same as above)
The old DC Power Jack is de-soldered, and a new one soldered in place.
Very FEW computer repair shops have the necessary skill level.
They just want to replace the entire motherboard.
IF one is available.
More Ka-Ching for them also. ]
3) The AC adapter is bad.
Not providing power to the laptop, to charge the Battery, nor give power to the laptop without the Battery.
AC adapter cord from adapter to plug, which plugs into the laptop, (DC Power Jack), may have a break in it.
May be an intermittent contact provided by wiggling the cord.
If this is the case the wires have stretched, and broken.
Wiggling causes the wires to briefly touch, and make contact.
Where this cord meets the plug itself. A lot of times there is a break in the wires in this area.
Solution is to replace the AC adapter. There are universal AC adapters you can buy, or perhaps Gateway still has some for sale.
(Ka-Ching)
Oct 21, 2010 | Gateway MX6920 Notebook
My gateway mx6025 is displaying no battery is detected and it can only charge when it off, I thought it was the battery, but since i charge it for over two days, it display 100% charge on the battery...
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Sep 01, 2010 | Gateway MX6025 Notebook Computer...
Is there any manuals for disassembling a gateway mx6025? any were I can get a chassie cheap?
you will find the schematics diagram on gateway site and ebay is your best bet for a cheap chasis
Aug 02, 2010 | Gateway MX6025 Notebook
I have a mx6025 gateway notebook. I installed
When i checked, i can only find the Conexant Audio Driver Version: 6.14.10.0565 for this model.
Is that the driver which u tried?
Oct 04, 2009 | Gateway MX6025 Notebook
GATEWAY LAPTOPS NOT CHARGING...WE NEED TO GET FILE COMPLAINTS WITH BOTH BBB AND GATEWAY AND THEN SUE THEM IF NOTHING HAPPENS...
you can take the laptop to a laptop shop & have them resolder the power plug to the mother board or purchase a new motherboard.
Jan 16, 2009 | Computers & Internet
Broken dc jack on gateway 400sd4, need to disassemble
You can download a .pdf service manual from here: http://www.eserviceinfo.com/fulltext.php?search_ft=400sd4 It is a multi-part download so make sure you get all four parts to the manual before you try to open it. (if you need WinRAR to unzip the files you can get a demo at download.com) The service manual has instructions and photos on how to disassemble your laptop. Good Luck, El Duderino
Jun 29, 2006 | Gateway 400SD4 Notebook
Gateway MX6025 Notebook Logo
839 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
