Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Moel #60PP93 5217
My t.v is 5 years old and just started with "double" vision type problems and lots of pink and green on the screen.
  • hughr Mar 04, 2008
    Having double vision in the close caption Has diagional lines when cable is on port B. Remote will not operat TV. Have to unplug and replug in every use. About 5 years old
  • 84 Answers
You are having a convergence problem. It is the most common problem with all projection TVs. It needs professional repair.
C-Dog
Posted on Feb 10, 2008
My screen is mostly neon pink and green and double-vision. looks like 3d without the 3d glasses.
i am a tv engineer the problem is the convergence settings they are mento be set say every 3 years depending on the model it will cost around 80 pounds to get done you can check anywere that is definitely the problem
Jan 20, 2011 | Hitachi 57F500 57" Rear Projection...
Double vision on my Mitsubishi 46 inch width screen--TV is 5 years old
any repair shop can re converge the tv for you.id do some calling arond and get a few quotes to see what it would cost to have them come to you
Oct 09, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Line at top of screen
There are problems in the vertical blanking or scanning circuits. This is not something you can fix yourself at home. It involves troubleshooting the deflection amplifiers and scan generator areas to locate the defective components.
You will have to give the set out for service. I would suggest to get an estimate before proceeding. This type of repair can be costly for the labor to find the fault. If it is only generic type parts involved, the parts themselves will not be too expensive.
Jerry G .
Jul 09, 2008 | Samsung HC-P4752W 47" Rear Projection...
Double Vision
The convergence ICs need to be replaced both of them at the same time they are STK392-040 you can get replacment ICs at the following link and they provide free instalation instructions with pictures so you can do the repair yourself.
Heres the link.
http://servicemanuals.vstore.ca/
Jun 29, 2008 | Akai PT4298HD Rear Projection Television
Double vision
My television is a hc-p4752w and the color convergence is way off. The red and green are not together and curl away from the top of the screen and bottom too. I tried to auto focus with only making the color separation worse. The tv is about four years old with lots of play time...
I am a aircraft mechanic with some electronics training so I don't mind replacing components I just don't know where to start and have no troubleshooting manual for help. Any help would be greatly appreciated!!!!
Jun 28, 2008 | Samsung HC-P4752W 47" Rear Projection...
Green and pink double vision on my tv
This is a convergence problem. Try resoldering the pins on the convergence ICs. These are large black ICs attached to a heatsink. They should have about 15 pins and be marked STKxxx. If the resoldering does not resolve the problem, replace the ICs. These should cost about $15-$25 each.
Dan
May 12, 2008 | Toshiba 43H72 43" Rear Projection...
Double vision on my samsung HDTV 1080i
If one or more of the colors, red, green or blue have separated from each other and you can`t correct the problem using the convergence procedure as described in the users manual, that would indicate you have a convergence problem. Bad solder connections on the convergence output chips are common. If the set had a rough ride down the stairs while moving, that may have facilitated in exposing a preexisting condition. However, the most likely cause is the natural failure of one of the convergence output chips and or related components and not the move. The fix is to have a qualified technician address the problem. This is not a do it yourself job.
Feb 22, 2008 | Televison & Video
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
