Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite Front Load Washer: Debris rattling inside washer tub
A screw (or something) has made it way through the tub grate and makes an ittitating noise when washer in use. how do I get in there to clean it out? Thank you.
  • 77 Answers
You are going to have to take it apart
Posted on Feb 11, 2008
Started rattling at end of cycle, broken belt?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Jun 01, 2010 | Kenmore Elite 45986 Front Load Washer
Do I need to secure the tubs inside Kenmore Elite Washer & Dryer?
Not the dryer but you do for the washer ... there is bolts that go in the back to hold the tub ... the bolts came with the washer went it was new... you may be able to get a set from sears...
Oct 03, 2009 | Kenmore Elite 45986 Front Load Washer
I have a kenmore Elite front loading washer and yesterday during a load it made a terrible noise and when the washer was opened two of the fins inside the stainless steel tub had fallen off and now when...
u will need 2 replace all the baffles .remove top when this done on top of tub u will see a plug removethis . if u notice on the new baffle there is a place for a screw, that screw hole can b acessed through the hole in the top. the factory never puts these screws in the noise I dont know about. haundi24
Jul 21, 2009 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore 'Elite' front loading washer that stinks
Have you been leaving the door cracked open after washing a load? If not, mildew will form and smell. If you have, then it would be something else. Respond with any questions.
Jun 12, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer he5t error codr f21
remove bottom panel 3 screws 7mm get bucket and alot towels, turn pump filter clockwise and remove all debris from inside pump now close it up nice and tight should solve youre problem
Dec 28, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Washer top load Wont spin
Sounds to me like the belt is broken or has slipped off. Try taking the back off (6-8 screws) and you will immediately see if that is the problem.
Dec 23, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE 4T
HE 4 front load remove bottom panel 3 screws once remove now you have access to pump get towels and bucket oper lint filter and remove debris from inside ,,,,, and that its F2 long drain,,,,,,
Oct 13, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Washer making a weird noise
I didn't get to answer this but It makes "cents" to me.
Sep 09, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Screw or change stuck inside tub
only 3 ways to do this 1)take your sump hose off under the washer place your fingers on the inside of the washer and turn the drum slowly but watch your fingers the inner drum will act like a cheese grater i know this due to doing it myself and only once 2)got to strip it down totally but this is a big job m8 3)leave for a while it will find itself to the sump hose but this could damage your inner drum by tearing the side
Feb 10, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
