Question about Kenmore 63074 Top Freezer Refrigerator
Refrigerator water drains inside of refrigerator leaking water down the back inside pooling under the crisper and running out on the floor.
  • 12 more comments
  • AliceG Feb 22, 2008
    I ahve the same issue, water is leaking from top through the "air vent" i am assuming down onto the top shelf and then pooling under the cripser. I think it might need the drain tube cleaned as i don't have ice and water in the door or a tank. Any advice would be great!
  • cedwardh May 13, 2008
    water is leaking down the back side of the fridge and pooling under the crispers
  • Anonymous May 28, 2008
    water is dripping down from vent in back of the refridgerator and ponding on shevles, in crispers and at bottom of fridge.
  • umbie May 31, 2008
    water is pooling under the crisper tray
  • phxchou Aug 05, 2008
    hi
    I have a Whirlpool pruchased on 7/2004. It's leaking water and accumulates over time.
    I am worried i have to get a whole new fridge.
    help!
    thank you!
    Phoniex
  • whiddonlk Aug 05, 2008
    Yes! My dad and I each own a Kenmore that has leaked from the freezzer onto hte shelves almost from the time of purchase. They ****!!! How to fix?
  • Anonymous Nov 23, 2008
    I have the same problem, water is leaking from top through the "air vent" on to all my shelves. I think it might need the drain tube cleaned as i don't have
  • Anonymous Jan 10, 2009
    I am having same problem. Water drips from top/back of frig onto shelves through vents on top/back of frig /control unit. Doesn't always do it. Why does this happen?
    Marv
  • Zayness Feb 24, 2009
    I have a Kenmore freezer on top fridge and it just started a few weeks ago leaking water that builds up on the glass shelves inside. I read online that the drains might be plugged having to do with the automatic defroster on the unit but i emptied out the entire freezer and cannot find a drain to unplug??? Anyone know how to fix this or where to find the drains etc to clean? Or if this can be stopped or does it mean time for a new fridge!
  • gervaisa May 05, 2009
    I have a Kenmore too. The water is pooloing on all the shelves and in the crisper drawers. Any other solutions to stop this?
  • Anonymous Mar 19, 2014
    Water pooling and freezing at the bottom under the crisper.
  • Anonymous Mar 20, 2014
    water leaking inside the refrigerator
    Cloged drain tube? where is it located?
  • Anonymous Mar 22, 2014
    outside hose not leaking.
Hi - I have the same problems with water accumulating under draws. Did you ever geta solution!
Kevin
kfr1013@live.com
Posted on Mar 27, 2009
The channel that collects the water from dehumidifying the refrig runs behind the crisper drawers to a plastic tube. We had to unscrew that channel and recaulk it to make it water tight. Also, pouring hot water and using a pipe cleaner in the plastic tube will clear a blockage if one is there.
Posted on Jun 21, 2008
  • 92 Answers
Check behind the drawers is there a water tank for water in thew door that would be my first guess
Posted on Feb 10, 2008
My fridge is leaking water down the back into crisper
The defrost drain is stoppped up. The easiest way to solve this is with a compressed air tank. At the back of the ref. at the bottom you will see a hose leading into a drain pan.Blow the air through the hose and it will unstop the drain.Hope this helps !
Sep 29, 2017 | Whirlpool GT1SHTXM Top Freezer...
Why is water pooling under right crisper?
On defrost refrigerators water is drained down the sides to an outlet on the bottom of the interior of the unit and then to a tray under the unit, close to the floor, where it is heated and evaporates.
If he hole inside is plugged then the water will pool inside.
Take out both crispers and try to find the location where the water will flow out. It may be plugged with gunk The inside bottom of the unit may have indented runs where the water will be directed to the outlet.
Oct 27, 2011 | Samsung RF217ABWP (20 cu ft) Bottom...
Water puddle forms on the floor in front of my GE TBX18SISERWN frig
lokk under the crisper draws,if there's water under them you have a blocked drain in the freezer.if there's no water under the crispers check the pastic water lines going to the water valve and the ice maker.if it's the drainyou have to pull everything out of the freezer,remove the inside back wall of the freezer and melt out all the ice with a hair dryer then you have to clear the drain,i use a steemer to do this,you can use a turkey baster or anything will push air down into the drain hole,pour hot water into the hole and when the water goes down the drain you'll know it's clear.before you start you can advance the timer into defrost to help melt out the ice or shut down the control or unplug it,you don't want it to be running while you take it apart.hope this helps you figure out where the water is leaking from.
Sep 24, 2011 | Refrigerators
Water comes off somewhere in the bottom of my fridge. what could have caused it?
When your refrig goes into defrost , the water runs down the back of the refrig ( inside ) and out to the drip pan thru a drain hole under the crispers . If water is under the crispers , remove the crispers and you should see a " cap " covering the drain hole . Sometimes crud will cover the slots where the water is supposed to drain , causing water to pool under the crispers . Just remove this cap , clean , and reinstall .
Mar 20, 2011 | Magic Chef Refrigerators
My fridge is leaking from the bottom or the back i dont know which yet. but i see water on the right back corner on the floor. any idea what this could be
Greetings,
I guess, I need to know if its the floor of the refrigerator, or kitchen floor? if floor of refrigerator. Its most likely a drain issue..The defrost system melts the ice and that water flows into a drain. these become clogged from food particles and stop up. The water then travels the path of least resistence and ends up down inside refrigerator. The solution is to open up drain and usually all is well..
Now, if its just on the floor. we have to check all the obvious. it still could be the drain and water could be running out from under crispers onto the floor. So, check that first...if not, check the connections at icemaker valve (if you have one) again, check water line if you have one....make sure the drain hose is in the drain pan...sometimes the drain pan sits above the compressor and heat evaporates the water...these pans get a hole in them I hope this helps..let me know if you need any clarifications....Bruce
Nov 25, 2010 | Whirlpool ER6AHKXPQ Top Freezer...
MTB2656G Top Freezer Refrigerator: Water is leaking and pooling below crispers in ref...
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - make sure to put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
May 06, 2010 | Maytag MTB2656G Top Freezer Refrigerator
Water pooling inside of refrigorator
sounds like the drain line for the defrost cycle is plugged. the water is supposedto end up in a pan under the refrig. the drain probably needs to be defrosted and cleaned.located behind the back panel in the freezer compartment
Jan 21, 2010 | Frigidaire Refrigerators
Water leaks down back of frig and pools under veg crisper
there is a drain hose that drains the frost from the freezer down to a drain in the botton of your refrigerator. then: to the evaporator tray under your refrigerator If the tube or, drain get clogged the water has no where to go and, pools in the refrigerator To fix this clean the hose with a coathanger or, stiff wire If you do not know where the hose is see the parts diagram for your refrigerator at: searspartsdirect.com
May 20, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaking into the bottom of frig. going under veggy crispers
Look for the drain trough on the bottom of the freezer and pour a mixture of baking soda and warm water down.
May 07, 2009 | Refrigerators
Kenmore 63074 Top Freezer Refrigerator Logo
1,171 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
