Question about Reddy Heater RLP100 Portable Forced Air Propane Heater with Variable Heat Ouput
Burning eyes, can't breathe.
I have an Reddy Heater RLP 100. I start it up, it runs fine but, it gets so strong smelling in the garage and burns my eyes that I have to turn it off. I bought it used so, no manuals. any help would be appreciated.
  • rta5 Feb 24, 2008
    I am having the smae proble. Did you ever fine the solution?
  • scottwfd Mar 20, 2009
    Same problem now, did not do this before, how can i fix it.
  • 4 Answers
If the unit is running correctly it will produce a lot of carbon dioxide, but if running incorrectly it will produce carbon dioxide (a deadly gas). Had the same problem with my RLP100, 100,000 btu, unit. I measured the carbon monoxide output at 97 ppm about 8 feet in front of the output. The unit was running on its low setting at the time. I removed the main burner (a bit of work) and found some plugged holes that were cleaned with a needle file. Reassembled and the problem was betterbut, the unit was still running cooler than it should have so the reduced propane with a constant strong fan was still resulting in uncombusted propane. I then tested the unit on high (100,000 btu setting) and the CO level went to zero and no eye burning. Guess I have a one heat setting unit now.
Posted on Nov 11, 2010
  • rkc3 Nov 11, 2010
    Should have said ... but if running incorrectly it will produce carbon monoxide ...
    Problem Solver:
  • 14 Answers
These produce large amounts of carbon monoxide, so you essentially are poisoning yourself. Leave the garage door open part way when using it.
Posted on Feb 11, 2008
Ready heater Pro 100 (65-100,000 BTU0) strong oder that berns the eyes after a short period of time and is worse on low settings. Does have suffishent ventalation.What cold be wrong or cause this
Your eyes burn because the flame is burning too rich or too lean. Always start troubleshooting a fuel delivery problem by setting the pump pressure.
If the pressure is correct, check for a restricted fuel filter, a cracked end cover, air or vac leaks between the pump/nozzle and tank/nozzle.
DESA recommended annual replacement of the nozzle because they wear out and start producing a spray rather than a fog.
Oct 10, 2011 | Reddy Heater RLP100 Portable Forced Air...
I just bought a 30K ventless wall mount heater and have a 24X30 insulated garage. I set it on 2 and it keeps it about 60 degress but the smell burns my eyes and stains my clothes. It's brand new. I have it...
You need to ventilate this area while the units running! This is potentially a lethal situation!
You are competing with a flame for oxygen and breathing the carbon monoxide gasses
from the heater! Both unacceptable scenarios! you can easily die in this environment!
I cannot stress this enough! You need to open a window or crack the door enough to allow air to circulte and gasses to vent out and escape, If the burning of eyes is really bad your unit may not have sufficient combustion air, I can t tell you without seeing it precisely, you better vent that room though!
Dec 24, 2010 | Reddy Heater RLP100 Portable Forced Air...
I changed filters,but still get eye burning smell,I do use Kerosene
In my experience, eye burning is a by product of burning even the best kero. And at 115,000, you are burning a lot.
Jan 03, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Smells like it is running rich and it does not seem to be getting as hot as my other one strong smell and burns your eyes
Whatever it is sounds like you should clean it... carbon and soot build up in exhaust... if it is a ventless (which is info you should have asked about) than you will find that it is the second heater in line and is starved for fuel.
Nov 27, 2009 | Reddy Heater RLP100 Portable Forced Air...
Reddy Heater 60k kerosene suddenly smells
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Mar 09, 2009 | Reddy R60A Utility Heater
Burning eyes and sore throat when heater is on
This heater should only be used in a very well ventilated area, the sore throat and burning eyes are from carbon monoxide.
Carbon monoxide is potentially fatal.  I cannot express how dangerous this is if used in a house or garage without the doors open
Please be careful and let me know if I can provide furthur assistance.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Mar 02, 2009 | Reddy Portable Forced Air Propane Heater...
Reddyheat rlp 100 will not stay lit, strong gas smell.
I had the same problem with my Reddy Heater PRO 100. It is the 20Lb bottle causing your problem.
I Put a 100LB bottle on and ended my problems.
Dec 31, 2008 | Reddy Heater RLP100 Portable Forced Air...
Heating & Cooling Logo
759 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
