GE Security Simon 3 Wireless Home Security System
Problem for GE Security Simon 3 Wireless Home Security System
System Low Battery
By Rie07 on Feb 10, 2008
I just bought a brand new GE Wireless Simon 3 security system and ever since it was set up the system status light is always lit and it says "System Low Battery".  Its brand new though and the manuel states the batteries usually lst 2 - 3 years.  What can I do or do I need a new battery?? Also, probably because there is a low battery...when i select no entry delay and open a window the alarm/siren doesn't go off.  It said in the manuel it might not if your system is on low battery.. so that could be why but I just don't understand why I am having so many problems so soon!!
Same Problem
Jun 23, 2008
-   Same issue - tried doing as person suggested - it worked for a couple days and then went back to low battery. Switched batteries again and tried powering down. Still have low battery issue.-   jcram1212
Feb 17, 2008
-   I have exactly the same problem. It is caused by plugging the transformer in before connecting the battery. Simon not the problem in their manual but amazingly offer no solution.
It can also be cause if the battery is disconnected to stop the alarm going off.-   Treydar
Best Solution
posted on May 19, 2008
Helpful)
Techsy
Rank: Guide
Rating: 86%, 9 votes
Response 1 is correct. If you plugged the transformer into an outlet before connecting the battery the system wont see the battery and give you that error. Should be a simple fix however. Unplug the battery and then the transformer, then reverse the process. Plug in the battery and your Simon should power up, then plug in the transformer. If this doesn't help then you should replace the battery. Did you buy the system from a dealer and have it professionally installed or did you do-it-yourself? If it was professionally installed have your technician come back out to diagnose/replace the battery if needed. Good Luck.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for GE Security Simon 3 Wireless
Questions and Unsolved Problems for GE Security Simon 3 Wireless
Do you recommend GE Security Simon 3 Wireless Home Security System?
Answer
Answer
I set the new Simon 3 system with a 4 digit master code...but then when I try to add an access code... (More)
Answer
we have had a gemini security system but have not installed it. Then, the baby in the house pressed... (More)
Answer
Hi, The system battery is low, but I can't figure out how to replace it; it's not in the manual. I... (More)
Answer
how do you replace the battery for the vista 15pmt system. I have the low battery light
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Security Simon 3 Wireless...:
Top Security System and... Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Security System and... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
