Question about Samsung LN-T4671F 46 in. LCD Television
Using Widescreen setting on Samsung LN-T4671F 46" LCD TV.
Recently my TV's widescreen setting has been changed (don't know who nor how), I tried going into the settings and using the "P.Size" button to change the screen to widescreen 16:9, but it does not appear to be widescreen at all. Some channels have the image cut off (heads are cut off or in the case of NY1 I can't see the words or weather display on the bottom of the screen either) and I rarely or at all have a letterbox look (black bars around image, the way I'd like the screen to look again) to my screen.
  • Klanky Mar 08, 2008
    The top and bottom of the picture on my Samsung LCD TV get cut off. Have tried adjusting the picture size, but there are only 2 options. Anyone know what's up?
  • Diminucita Mar 09, 2008
    Thank you Coldcut! I played with the # button on my Time Warner remote and the TV Image is perfect now. You Rock!!!
    Much appreciation,
    Diminucita
Nice just helped me....cablevision also
Posted on Mar 15, 2008
EXCELLENT Coldcut! Thank you so much! :)
Posted on Mar 10, 2008
    Genius:
  • 1,554 Answers
If you have a time warner remote press the # to zoom out.
if you have cox ask them.
Posted on Mar 08, 2008
Captions are locked on and guide cannot be accessed to turn them off. Also, volume is stuck at 0. When you adjust volume it goes immediately back to 0.
You might have the CHILD LOCK feature on.
Use the remote to access the MENU then SET UP then CHILD LOCK.
Set CHILD LOCK to OFF.
If this doesn't work, try holding down the MENU BUTTON on the front of the tv for 10 seconds until you hear a beep. This works for some models.
Or if all else fails, leave the power cord unplugged overnight and this shoud reset the internal memory back to default settings.
I tried to download the user manual at the following link but the site was temporarily down
http://www.samsung.com/ca/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=101&prd_mdl_cd=LNT4671FX%2FXAA&prd_mdl_name=LN-T4671F&srchword=LN-T4671F
Gppd luck and let us know how you make out.
Jan 22, 2011 | Samsung LN-T4671F 46 in. LCD Television
My samsung ln-t4671f 46'' tv is taking a few minutes to turn on,when it does come on it works fine.how can i fix this problem and how much will it cost? thanks..ROCMAN28
In most cases it is the capacitors in he power supply section that have gone out.
Common symtoms are
-shuts down
-takes a long time to come on
-relay clicks
-dead set
You can get capacitors online or you can get a complete kit with instructions and support from www.TvRepairKits.com . Its a failry easy DIY fix.
Dec 02, 2010 | Samsung LN-T4671F 46 in. LCD Television
LN-T4671F LCD samsung tv clicks on and off for about 1 minute before going on
Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. The power supply may be sensing overloading.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 27, 2009 | Samsung LN-T4671F 46 in. LCD Television
LN-T4671F 46 in get loud clincking sound when tv
power supply is probably about to fail. will probably start to cycle on/off by itself.
Oct 27, 2009 | Samsung LN-T4671F 46 in. LCD Television
16:9 on my lnt4671f change the setting?
using the samsung remote that came with unit. bottom right corner. up 3 buttons, labeled as p.size. you can toggle through the choices.
Oct 01, 2009 | Samsung LN-T4671F 46 in. LCD Television
Samsung ln-t4671f clicking - and won't power up
This is common problem of the 46" LCD. The power supply board has caps defective. You can open the case, look for the power supply. Normally, you will see the two small caps pop up. Replaced those caps, the TV may work again. If it does not work, those FET transistor in the board have been damage. You have to replace the whole board. The board cost $150 or so. You can order direc from SS. Go www.samsung.com//us then look for Support icon. Good luck
PS: Circuitcity still sell stuff by website, you can go there and found complain.
Aug 14, 2009 | Samsung LN-T4671F 46 in. LCD Television
Image cut off of Samsung LCD TV picture
if you have a time warner remote press the # to zoom
cox has another button . don't know it. ask them.
Mar 08, 2008 | Samsung LN-T4671F 46 in. LCD Television
LN-T4671F
You have to have a RF cable hooked to the tuner on the back of the set, should be 2 tuners, hook up the cable to either one and the channel option will be selectable
Jan 17, 2008 | Samsung LN-T4671F 46 in. LCD Television
VERTICAL LINES AND THE COLOR CHANGES
are the colored lines all the way across the screen? with no video even menu does not show up i would say you have a bad panel take it back to the store
Oct 22, 2007 | Samsung LN-T4671F 46 in. LCD Television
Samsung LN-T4671F 46 in. LCD Television Logo
415 people viewed this question
Jerry Greenberg
Jerry Greenberg
