Question about Sony MHC-RV777D 220 Volt Hi-Fi Music System Shelf System
Sony MHC-RV888D the disc tray in not coming out and the disc
The disc tray in not coming out and the disc is reading in descending orderand all the buttons on the players do not work and its not turning off also
SOURCE: Erratic CD tray behavior on SONY MHC-881 Shelf system
change cd head
Posted on Nov 27, 2007
  • 4234 Answers
SOURCE: DEST ERROR CODE
There is a problem with the mechanical loading mechanism of the CD portion. The unit is unable to complete its "startup" sequence. You will need to rebuild the CD loading mechanism. You should purchase the service manual for the instructions on how to rebuild this.
Dan
Posted on May 01, 2008
  • 3 Answers
SOURCE: Everytime I try to open the disc tray it flashes either EX-Change or mechanical error and won't open
I have a Sony MHC-GX555 stereo and every time I try to open the disc tray it either flashes EX-Change or mechanical error and it won't open.
Posted on Jun 18, 2009
ETRONIC
  • 62 Answers
SOURCE: sony mhc-gx450 cd player is not reading.I used a cd cleaner and d
First unplug the unit and press the power button to make sure all the power is out of the unit. Try to take a cotton qtip and clean the lazer lense with alcohol. after wipe it clean with a new cotton qtip to remove the film the alcohol produces. Do not use a lot of alcohol and drip it all inside of the unit though.
Also if you tried a cd-r try a real copy instead. Make sure your cd's are ok.
Good luck.
Posted on Feb 16, 2010
adamncc1701
  • 158 Answers
SOURCE: Sony MHC-RV888D coming error C
Hello, that error code means the laser is not reading.Either because the disc itself is scratched or dirty, the laser is dusty,or worst case the laser is bad. If the disc is in good shape than you will want to try cleaning the laser,first push eject(open),unplug power ,remove top,clean laser lens with dry q-tip. Then reassemble and plug it back in and give it a try.
Posted on Feb 12, 2011
WILL NOT EJECT DISC
What is the model number of your DVD player? You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
FOR SONY PLAYER's
This issue may occur if the disc is damaged or if the disc was not inserted properly into the Blu-ray DiscĀ® player. Follow the steps below to open the disc tray and eject the disc.
  1. Turn off the Blu-ray Disc player.
  2. Disconnect the power cord (mains lead) or AC adapter.
  3. Allow the disc player to remain without power for 30 seconds.
  4. While pressing the OPEN/CLOSE button located on the front of the disc player, reconnect the power cord.
    IMPORTANT: For some Blu-ray Disc Home Theater models it is necessary to press and hold the OPEN/CLOSE andPLAY buttons simultaneously, then reconnect the power cord.
    NOTE: This step may require the assistance of a second person.
  5. After reconnecting the power cord, when the tray opens, release the OPEN/CLOSE button.
  6. Remove the disc.
  7. If necessary, disconnect and then reconnect the power cord to recover the player.
Aug 24, 2015 | Televison & Video
How can I unlock Samsung HT-H4500R
1) Turn on the player with no disc in the tray.
2) Open then close the tray, wait to see the No-Disc Message
in the top Left Corner.
3) Now press the REPEAT button on the remote, followed by a
five digit code. eg. 57538 if you have a region 2 player.
4) When it works a 2 (your current region) will appear in
the top left corner.
5) Press 9 to make it region less.
6) Press Eject to OPEN to open the disc tray.
7) Press Eject to CLOSE to close the disc tray.
8) Power the unit off
9) Now power the unit on again, it should now read all
regions of DVD/BD Disc.
Here is a list of all the region codes:
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
Aug 25, 2014 | Samsung Televison & Video
Sony mhc-rv888d standby light is flashing
Output ic stk403-120 changed but still same problem.
Jan 04, 2013 | Sony MHC-RV888D Shelf System
When I turn on my Sony DVP-SR200P DVD player and press the eject button it's turns the DVD player off.
turn on first the dvd player and wait to read a disc inside if no disc inside the tray it will say disc error. if the unit doesn't turn off, eject now the the cd tray. if get turn off, remove the cover then check for an stuck up gear or obstruction in the cd tray assembly. you can check also the power supply board which may have unusual parts like bulged or burnt component parts.
Oct 06, 2012 | Televison & Video
I put a disk in and there was already one in now it wont eject
The disc tray does not eject when the OPEN/CLOSE button is pressed. Solution
sp.gif sp.gif Follow the steps below to troubleshoot this issue.
    IMPORTANT: The disc tray will not open while a disc is loading; this is normal operation. If this is the case, wait until the disc is finished loading before pressing the OPEN/CLOSE button to open the disc tray.
  1. Make sure the disc tray is not locked; if necessary,
  2. Perform a power reset.
    1. Press and hold the POWER button for 10 seconds until the BD player turns off.
    2. After the BD player turns off, press the POWER button again to turn it back on.
  3. Attempt to open the disc tray by pressing the OPEN/CLOSE button on the front of the BD player.
  4. If the disc tray still does not open and a disc is stuck inside, follow the steps below to force the disc tray to eject:
    1. Turn off the BD player.
    2. Turn the BD player back on.
    3. Immediately after POWER ON is displayed, press the STOP button on the front of the player. IMPORTANT: Only use the STOP button on the front of the BD player. The remote control cannot be used for this operation.
      NOTES:
      • The disc tray should eject and the BD player will turn off. If it does not eject, repeat steps A-C.
      • It may be necessary to press the STOP button in step C two or three times.
If the issue is still unresolved, service may be required
Sep 15, 2011 | Sony BDP-S300 Blu-Ray Disc Player
Can i get a product manual of rv999d?
Are you looking for Instruction Manual copy of MHC-RV999D ?
Let me know to upload it so can download from given link.
Thanks.
Mar 27, 2011 | Sony MHC-RV888D Shelf System
Disc tray does not come out, display say hello
There is a flex cable that attaches the tray assy to the main pcb ,make sure that has not pulled out, also see if tray tries to move at all as it may need the mechism realigned and the open/close switches cleaned.Also the is a gear that turns the tray that has broken teeth on,check that gear ,as tray must turn before unit will intalize
Apr 16, 2010 | Kenwood DV-605 Multi-disc DVD Player
Sony MHC-RV777D 220 Volt Hi-Fi Music System Shelf System Logo
80 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
