Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Ice door not opening
Ice maker works fine but the lower door doesn't let the ice out. I have been told to remove the front control panel and clean the connectors to the switch that operate the door but I can not see how to remove the front panel
  • 92 Answers
Your f%^*ed 90% of the time i work on these dispenser covers the tiny plastic tabs brake off. the best advice i can give is to start on the bottom corner and work around but be prepare to buy a new cover
Posted on Feb 10, 2008
Samsung RM255LABP/XAA freezer only gets to 27 degrees, won't harvest ice. Fridge and lower freezer work fine. After pressing the ice maker reset button, I hear a ding don sound coming from the control...
It won't harvest ice on its own unless it detects a temperature of 10 degrees. The ding ding sound is the control letting you know that the ice maker is functioning fine. Remove the evaporator cover in the freezer and make sure the coil isn't frozen over and the fan isn't restricted from turning. Check the door gasket is getting a good seal. If that's all good replace the sensor on the ceiling of the freezer.
Aug 31, 2016 | Samsung Refrigerators
Whirlpool refrigerator water dispenser not working
hve u tried to clean any blockages in the unit.let me know wat other problem u face
Oct 23, 2008 | Whirlpool GS6NBEXR Side by Side...
I have a Samsung refrigerator with a bottom freezer. The 'fridge and freezer temp settings are displayed on a panel between the upper and lower doors. The unit is about 4 years old. About a year ago,...
Hi adc3,
If the display has stopped working, it is often caused by a blown fuse. Please locate the main control board and check if there's a fuse that may have blown. For the ice maker issue, please check if the ice maker has been turned off. You can check it by looking for a wire that looks like a coat hanger that is located at the right side of the ice maker. Ensure that this wire is not in the raised position. If it is turned off, just simply lower the wire to the down position to turn on the ice maker. If this did not work, please check the tooth on the drive or driven gear of the ice maker. If you noticed a broken tooth you should replace the ice maker.
Hope it helps.
Thank you for using FixYa.
Jun 14, 2011 | Samsung RF265AA Bottom Freezer French Door...
I have a kitchenaid kuic18nnts ice maker. The power went off and it stopped working. I checked the plug and when I re-inserted the plug I found it will run only when the door is open. Once I close the door...
What this simply mean is that there has been a lose of wire from wiring connection which have brig up with the door of the oven what you are to do to solve this problem first of all trace the wire connection from the main power supply down to the control panel i.e the control unit .
2).Remove your microwave door will allows you to quickly clean out any accumulated food or grease. This also makes it easy to get to all the crumbs and debris around the door hinges. While you have the door off its hinges, examine the plastic panel and glass window for signs of damage. Make sure you install a replacement door that is designed for your brand of microwave to ensure that it will fit correctly.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Instructions and material needed bellow
(Phillips screwdriver (if necessary), Flathead screwdriver or putty knife)
  1. Remove the power cord from the electrical outlet and move your microwave onto a workbench or sturdy table. For cabinet-mounted microwaves, pry off the decorative grills or front panels and remove the mounting screws. You should then be able to slide the microwave out of its mounting bracket.
  2. Open the microwave door and remove the glass tray. Use a flathead screwdriver or putty knife to pry off the plastic cover on the inside of the door. Work around the edge of the glass until the cover slips free.
  3. Remove the door by pulling the mounting pins out of the hinges at the top and bottom. You may need an assistant to steady the door so you can have both hands free to work with the pins.
Thank you and thanks for using fixya.
Nov 03, 2010 | KitchenAid Microwave Ovens
Ice maker problems...the door of my freezer doesn't close since I cleaned out ice bin. As I try to get ice, the door pushes open. Help!!
Assuming the ice bin is all the way in The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Aug 04, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Parts inside my ice maker in the door fell out cant figure out how to get the front panel off the ice and water maker
Remove the top freezer door hinge cover and disconnect the plug there . This removes all power to the door so the refrig can still run while working on the dispensor . Use a butter knife slipped down between the lower portion of the dispensor cover and the main dispensor from the inside and press down . There are 2 plastic tabs holding the lower cover in place . After the lower portion is unclipped , lift upwards to remove the top portion . Disconnect the plug to the dispensor front . There are 3 or 4 screws holding the white " body " in place , so remove them and it should slide out a little ways to allow access to the inner workings .
Jun 08, 2010 | Estate TS25AFXK Side by Side Refrigerator
Will not release ice and makes crushed ice, even when on cubed.
I believe in your case the ice maker part number WR30X10093 being electronic with the control board in the front is the problem. I think the control board behind the front cover of the ice maker may have corrosion and causing the ice maker to malfunction. You can try disconnecting the set of wires to the coil on the water control valve and see if the water stops or turn off the ice maker first and try disconnecting the coil wires later. It has to be the control board or the water control valve part number WR57X10032
Oct 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Kitchenaid kscs25fjss01 (2002) front panel not working
Hi
If  The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Apr 02, 2009 | KitchenAid Superba Architect KSCS25INSS...
Amana af12538aes Refigerator No lights, ice, water
There's no ice If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Small or too few ice cubes If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly. Check these:
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Check the freezer temperature. If should be 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker mold thermostat. Make sure that it's cycling properly.
Specks in the cubes If you find black or gray specks in your ice cubes, have a look at the ice cube tray. If the protective coating is peeling away, the most economical solution is to completely replace the ice maker.
Jan 19, 2009 | Amana AFD2535DES French Door Refrigerator
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
188 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
