Jvc lt-32c50bj i cant get any sound when i plug my xbox into the hd plugs, green/blue/red, tryed most things ,perfect picture.
  • 84 Answers
The green,blue,red hd plugs are for video only. you'll never get sound to produce out of a video line. audio comes from left and right which usually is white and red. it's always marked above or below the jack input.
C-Dog
Posted on Feb 10, 2008
How do i connect xbox to akura apl3268fd4 tv so its in hd
There are two ways to connect it.
1. The cable that came with your xbox should have two sets of plugs on it. One being the red, white, yellow and the other red, green, blue. You need to plug the red, green, and blue plugs into the tv with the same color plugs. You will also have to plug in the red and white for sound. The yellow plug is not needed. There will also be a switch at the base of the cable near the xbox. That needs to be set to HDTV. If your cable does not have the red, green, blue you will need to buy a cable that does have them.
2. You can use an HDMI cable. With that all you need to do is plug one end of the HDMI cable into the xbox and the other into the tv. Not all xbox's have the HDMI output though. If its new i should have it on the back of the xbox near the normal tv output slot.
If you use the red, green, blue you will have to set your tv on the component channel. If you use HDMI the tv will have to be on the HDMI channel
This will give you a more thorough explanation. http://support.xbox.com/en-us/pages/xbox-360/get-started/console/audio-video.aspx
If you found this helpful please give me a good rating. Thanks hope this helps
Nov 21, 2010 | Video Game Consoles & Games
How do i connect an x box 360 to a HD ready tv please explain simply
Every xbox comes with the HD av cords. However they are not only the standard red, white, and yellow. But they also come with green, blue, and red av cords. These are the HD cords.Your HD tv should have green, blue, and red outlets on the back of the tv. It also has a another red and white outlet under it. So you have to take the HD cords and plug them into the appropriate outlets and then take the red and white cords from the other set of avs and plug them in right under those cords so you will have sound when you turn your xbox on. On my tv the red and white outlet is right under the HD outlet. But your tv may be different. And make sure that the "box" on the cord that reads either TV or HDTV is flicked toward HDTV.
Aug 27, 2010 | Microsoft Xbox 360 Console
My xbox 360 dosent give video
Plug in the Yellow A/V connection to your TV's Video input. or if you have the HD cable you have to have the Green, Blue, Red, pluged in to get video, and then the White and Red for the Audio. (HD cable will not work at all on a A/V input on a TV.) HD cables have 2 red plugs, 1 is for audio, and the other is for video, they should be labeled to tell you what one is what, but if they are not, if you flaten the cords, the Audo White plug will separate the 2 reds, and the one that is between the White and either the Green or Blue plug is the other video.
If thats not it, I couldnt tell you, unless you have a bad connection on the back of your 360, or just a bad xbox.
Mar 09, 2010 | Microsoft Xbox 360 Console
Hook up sony blu ray
You should be able to hook it up with a component video cable. A component video cable is a cable that has 5 color coded RCA style ends that are Green/Blue/Red/White/Red. The Green, Blue and one of the Reds is for the video and delivers the signals needed to produce the HD picture and the White and the other Red is for the audio to provide you with stereo sound.
The Video cords will plug into the section labeled component video facing up and down and the audio will plug into the side by side section. So if you plug into Component input 2 then you would plug in the audio into the audio section of input 2.
If you have a separate surround sound system you can connect one of two ways.
1. Plug a separate Audio (red/white) cable from the Blu Ray to an available input on the surround sound.
or
2. Plug all inputs into the TV (as noted above) and then plug a separate Audio (red/white) cable from the tv labeled "Audio Out" to an available input on the surround sound system.
Jan 03, 2010 | JVC AV-48WP30 48" Rear Projection...
I think the video cable for my xbox is messed up. Why does it keep showing up these little circle things? Whenever I turn on my xbox it doesn't come up anything but a black screen with little circles...
NOT HD: Make sure red goes to red, white on white, and yellow on yellow, also make sure the switch that is on the xbox wire plug says TV not HD.
HD TV: Make sure red on red, white on white, yellow on yellow, blue on blue, green on green, etc. Also make sure the switch that is on the xbox wire plug says HD not TC
Oct 18, 2009 | Microsoft Xbox 360 Console
XBOX not connecting to LG flatscreen -no visuals only sound
There is a switch on the cable where it plugs into the XBOX that says HDTV/TV please make sure that it is set to HDTV when using component connectors.
May 13, 2009 | Microsoft Xbox 360 Hard Drive (20GB)
When connecting XBOX live to LG flatscreen there is no video only
There should be a switch on the cable that says HDTV/TV if you are using component connections, make sure that the switch is set to HDTV.
May 12, 2009 | Microsoft Xbox 360 Hard Drive (20GB)
Have sound no picture and 2 green rings around power button
They are green?!? usualy when people have problems with  the xbox 360 hardware, the lights turn red. This xbox 360 may have a birth defect... Best thing to do is call 1800-4my-xbox. Talk to a representative about sending your xbox in, ONLY if you have not voided the warranty. If so, you will most likely have to buy a new xbox or new motherboard for it.
Also try changing your video settings to tv instead of hd, or hd if it is plugged into a hd tv. You might have toggled the HD switch on the video/audio chords.
Dec 31, 2008 | Microsoft Xbox 360 Console
Picture is fine, but the sound won't work
Are the yellow, red & white cables RCA phono plugs?
Yellow = Video
Red = Right Audio
White = Left Audio (mono)
The red, blue & green cables are for picture only and don't include sound. Have you tried using the red, blue & green for the picture and using the other cable, red & white for just the sound? Don't use the yellow.
- Jim
Feb 10, 2008 | Sanyo HT32744 32" TV
Hooking up Xbox 360 to JVC TV 20 inch 1 year old tv from Luxembourg
change the plug on the back of your xbox 360 from hd to tv unless of course your tv is hd then change it to hd :]
Jan 27, 2008 | JVC TV-20241 20 in. TV/VCR Combo
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
Electro Med Services...
