Question about Quasar VV-2000 20 in. Combo
Quasar tv combo with VHS will not turn on
The red, yellow, green lights are lite up on the bottom. It says its recording and the timer is on, etc. and its not!
  • jls7707 Feb 18, 2008
    Did you find out what the problem is? I have the same problem
4 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Hooking up a DVD player to a Quasar TV/VCR Combo
Yes, for a workaround. The adapter would be 2 RCA female to 1 RCA male. You have to connect both the red and white to the female RCAs and use the male to connect to the TV's Audio INput. The yellow goes to the video. There should be no negative technical effect other than lost of stereo quality. The audio output of the DVD is line level and could normally tolerate this condition.
The correct method is to use a simple line level audio mixer and mix the L& R audio signal to produce a mono signal or to use a stereo amplifier for the sound output.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Nov 07, 2007
mewms_14904
  • 1027 Answers
SOURCE: Quasar VH5280...
Check first 0000, 0374 0381 0162 0035
need to know which remote your using?
Posted on Mar 18, 2008
SOURCE: Blinking light front of TV
You need to set the clock. The timer is confused if it dose not know the time.
Posted on Jul 15, 2009
How do I connect old school dvd/vcr combo to LED HDTV?
The general rule of thumb is that R-W-Y outputs from the VCR/DVD combo plug into corresponding color coded inputs on the TV. I think the Y(ellow)/VIDEO designation indicates where to insert the Y cord. It's worth a try.
Feb 12, 2016 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How do I hook up a combo vhs dvd player/recorder to my tv?
The AV OUT on your DVD player must go into the corresponding AV IN[PUT] on your TV.
Jan 19, 2015 | Panasonic Televison & Video
Quasar tv/vcr combo
A converter box is not needed to connect a DVD player to a TV. However, you do need a single cable with red, white, and yellow adapters orconnecterson one end and at least yellow and white on the other end. Ok if you have red; just don't worry if there isn't a hole to plug into.
Feb 11, 2012 | Quasar VV-1302 13 in. TV/VCR Combo
I have a Sharp 32"
try checking the system for timer or sleep mode operation try to setting it off
Jul 16, 2011 | Sharp 25R-S100 25" TV
I have a new vhs dvd player recorder that will not record.
please note in your vhs dvd manual it tells which dvd (maxell, tdk etc.)are compatible with the recorder
okay do you have a cable/satellite box connected to tv/monitor? yes or no
yes- is the the tv on ch 3? cable connected to cable box in, cable box out connected to dvd in,(on dvd set up menu make sure broadcast is cable) dvd out connect to tv... ? please note some dvd recorder will not record HBO (you can record on vhs tape)
no connect antenna to dvd in, dvd out goes to tv.....
hope this help...
May 20, 2010 | Quasar VHQ400 VHS VCR
How do I connect my Magnavox DVD/VHS player to my Element Flat screen TV?
Do you have a newer TV or a older one lets start with a newer models does your tv have 3 or more jacks on the back or front you should see a RED, YELLOW and WHITE if you have a HDTV you should see more. (LETS HOOK UP) Did your DVD/VCR come with a cables if not you will need to buy at least 2 they are called RCA cables Lets start with the dvd/vcr combo on the back you should see a (LINE OUT) this is where playback or your picture and sound come out. On the back of the TV you should see a (LINE IN) this is where you plug it in to. RED goes to RED, WHITE goes to WHITE and YELLOW goes to YELLOW. To Record you will need to hook up the line in on your combo and the line out to your tv. ( IF YOU HAVE AN OLDER T.V WITH NONE OF THOSE JACKS ) you will need to buy a RF- MODULATOR the are cheap it is a box that let you hook a cable wire to a little box and the RCA jacks to you combo and you will turn your tv to channel 3 or 4
Jul 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Cannot timer record with Insignia HD TV and LG DVR/VCR
Make sure when you do the process two things: one, a blank tape or If it is a dvd recorder, a blank disk is inserted, in the tape make sure the tab that prevents recording is not broken.Two, before exit the timer recording menu, make sure that there is not a instruction that says "done" or "confirm" or any word meaning that all the steps went through.
Nov 20, 2008 | Insignia IS-LCDTV32 32 in. Television
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Quasar VV-2000 20 in. Combo Logo
41 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
jason
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
