Question about Lands Phones
Hi good moening, to bad uou gave ti work SUNDAY
I HVE A UNIDEN XA14288=2C, MY main base works, and the h51 haldheld works, but the h52, says replace back on main charger to register but nothinh haopens. I was wondering if it a simple fix, i no longerr have the wners many. I will yy to printint out tn pdf on the instructions id available, thanks for your suopoort, I AM A LOMG UNINDEDN CUSTOMER, hope I have no need to by a new phone...
Thanks Hope to hear from you soon,
Ctraug Langer
  • 65 Answers
I can not find the model you listed. so here is the website and see if you can find the model of your phone and download the manualhttp://www.uniden.com/index/manuals_results.cfm?cat=1
read the instructions on registering.
Posted on Feb 13, 2008
I gave 240 volt to my 120 volt uniden cordless phone. Smoke came out and obviously it is not working now. How bad I messed up? Any repair work can fix this? What needs to b replaced
Most phone systems use the same AC adapter (wall block) for the base as they use for the remote charging bases. You may have just fried the base AC adapter. See if that is the case with your system and try the working AC adapter with the base to see if it will work or not. Good Luck.
Jan 31, 2015 | Uniden Cordless Phone
Will the handsets from a model 1680 work with an 1780 base?
The bases and the voltage on both phones are the same so they should fit together. The main differences are the handset features.
Uniden D1680 Specifications vs Uniden D1780 Specifications Cordless...
Jun 12, 2014 | Uniden Cordless Phone
One handset on my uniden dxa13288-2 does not work. The battery is charged and good (swapped with other unit). When placed in masterbase, base led flashes, indicating good data marriage on both. The good...
The handset for this unit registers automatically to the base. The main base sync with the handset but it does not respond. The handset that is not responding has a problem and should to be replaced. You can pick one up on eBay for a few bucks.
Jun 02, 2017 | Uniden 2.4GHz Digital Answering System...
Not receiving on any channel
uou may a bad mic if not I would think the
autoamp is at bad.this means you will
have to thae to a shop.
Good luck
Aug 26, 2009 | Uniden Bearcat Pro PC78XL 40-Channels Base...
Can you take two different phones and get them to work on the same bases
I won't work unless you have both the Vtech and the Uniden bases hooked up at the same time.
May 28, 2009 | Lands Phones
Uniden cordless phone
Hello, While I cannot locate that model in any Uniden database (you might want to find the literature), It sounds as if the handset may be communicating with its base, but you have lost the dial tone. Did any storms pass through recently? Here is what you do. Go to your base and push the locator button on your base station to call the handset via the page/locator function. If it rings the handset and you can answer it okay then you know your handset is working well and communicating with your base (the radio portion is working correctly). If it does not ring your handset then your Uniden is definately bad (radio wise). But, I am going to guess that it is okay but you still cannot communicate with the outside world and dial out to get dial tone or get an incoming call. Okay, so we have a dial tone problem. The next step is to see if dial tone is getting to your base. So you will need to take another good telephone, preferably a handy "line powered" telephone (no batteries or ac adapter needed) you can use in a power failure emergency. Take that good phone and plug it into the phone cord you unplug from your Uniden base. If you get dial tone, then your uniden does need repair. If it does not get dial tone, then you have a bad cord, jack or something in your phone wiring. If thats the case, change cords, look for corrosion, dirt or bent pins in the jack on the wall. My guess is that your Uniden has gone bad, likely from a slight surge on the phone line. If you do need your Uniden repaired you can contact Uniden they are at http://www.uniden.com/repair/service.cfm , however I don't believe they offer repair, but offer to sell you a replacement. Or you can go to www.cordlessrepair.com where you can get your Uniden Cordless unit repaired, not exchanged. Good Luck, CG
Feb 18, 2008 | Uniden Cordless Phone
Handset does not work
Your handset is no longer communicating with your base. Depending on your model, the solutions can be a couple of different options. If I could view pdf files on this computer I would look it up for you. But here is the link to the manual on Unidens website- http://www.uniden.com/pdf/TRU8865-2om.pdf
Nonetheless, give this a try. Power down your base, and pull the battery out of your handset. Plug the battery back in the handset and set the bad handset in the base cradle, and then power up the base. Wait about 30 seconds, then give the phone a try. If it still does not work, then you need to try to "re-register" the bad handset back to the base. Look in the manual under "registration" procedures. Hope my help fixes it for you. Good Luck, CG
Feb 17, 2008 | Uniden TRU8865-2 Expandable System...
E4 error code
Exact same problem. E4, sent uniden an email thru their website though I doubt Ill hear any response. Very disappointed as the 9485 was working great until all of a sudden E4 showed up.
Nov 29, 2007 | Uniden TRU9485 Cordless Phone
Lands Phones Logo
157 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
