Question about Whirlpool LEB6300 Electric Dryer
Dryer won't start
You can hear the timer ticking, but it will not start up? Can it be the start switch or where would I begin trouble shooting this?
  • sleeling Feb 11, 2008
    Thanks, I'll give it a shot.
  • 164 Answers
I would start simple, check your door switch for continuity and then check the start switch. If this is an electric dryer make sure you have a ull 220 volts to the dryer, anything less and only part of the machine (timer) will operate
Posted on Feb 11, 2008
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: The dryer stopped working in the middle of drying
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 28, 2010
When the timer on an electric dryer fails to start the dryer. Should you still be able to hear it ticking, when the timer is turned on?
Of course. Correct diagnosis is the key to such things. All the items you swapped out were fine. There are checks you can make with all those components. The rotary type timer is just a clock timer like a wind-up alarm clock. When you turn them on, they tick. In normal circumstances, turning it on will start the machine, and not count down. You need to remove it and make sure you have continuity and also power to the timer. There is more to this than meets the eye. The other item that it may be, is the motor itself.
Nov 25, 2017 | Dryers
Dryer won't start? It has power and I hear the timer clicking.
Sounds like a bad door switch ( the little button the door closes against). If that switch is bad, the dryer thinks the door is open even though the door is closed. Dryer will not start. thats the easiest place to start.
May 11, 2015 | Dryers
Dryer will not start but timer ticking
If the start button is an "ON - OFF" button (meaning, you can turn the dryer off manually instead of resetting timer in order to switch it off), try turning the dryer ON...then switch it back to "OFF".
Hopefully the dryer will continue, and the thermostat will kick in.
Dec 01, 2013 | Dryers
Whirlpool Ultimate Care II gas dryer won't turn off.
Dryer Won't Stop Running
  • Ultimate Car II Dryers are fitted with a mechanical timer that sends an impulse to the control circuit board to stop running once the set amount of drying time has elapsed. This is because, should an electronic timer fail, this would necessitate the replacement of the entire circuit board. Confirm that the mechanical timer is indeed broken by opening the dryer's door. If the dryer stops, the circuit board is working fine and is not the problem. Simply slide off the protective faceplate of the dryer, unscrew the control board beneath, and flip it over. Connected to the back of the timer's knob should be a small round device with two wires running to the circuit board within the body of the dryer. Unscrew this device from the back of the knob and disconnect the wires. A replacement timer costs a few dollars and should screw into place without trouble. Reconnect the wires and put the dryer back together. It should work fine now.
  • If you need a new timer the best place ti get it is from Rough River Appliance Repair
  • Phone number is (270) 230-1818 his name is Charlie and he is the best!
Nov 16, 2011 | Dryers
Timer ticks, but dryer does not run
Sounds like door switch. Open door and push on door switch. you should here a clicking noise. If you can open the top of the dryer. put the 2 wires together of the door switch. Make sure it is unplugged when doing this. Make sure you use electrical tape when you put it together. Temp fix. Get a new switch
Oct 23, 2009 | Kenmore 62602 Electric Dryer
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Dryer
drcool is right, we need to know what type of dryer, but is sounds like the centrifugal safty switch is bad and that is why it was not reamining running after you release the start button. Some dryers it is seperate from the motor, others it is in the motor, that is where I would start testing and see if that switch is bad. You really will need a wiring diagram to truly trouble shoot it, and most dryers have them somewhere inside the covers.
Feb 12, 2008 | GE DCSR483EA Electric Dryer
Whirlpool LEB6300 Electric Dryer Logo
254 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
