Question about Canon MultiPASS F50 All-In-One InkJet Printer
Wrong Cartridge Error Message
I have a Cannon Multipass F50 printer. I have replaced all the cartridges with the Cannon brand ink cartridges. Why does the printer continue to give me an error message that says "wrong cartridge"? How do I fix the problem? The wrong cartridge error continues to flash. I have removed and cleaned the ink cartridges. i have removed and cleaned the carrige which holda the ink cartridges, and still the error shows. What else can be done before I bring the unit to be serviced?
  • 6 more comments
  • Anonymous Feb 19, 2008
    SAME PROBLEM
    wrong cartridge message
  • Anonymous Feb 26, 2008
    same problem!
  • Anonymous Mar 07, 2008
    Found Reset sequence online at www.fixyourownprinter.com/forums/inkjet
    This is what was suggested to me.
    F30/F50 Printer
    1. Enter Service Mode - by pressing "menu then copy then #"
    2. Select TEST MODE
    3. Select (8) PRINTER TEST in TEST MODE
    4. Select 3 (EEPROM CLEAR)
    5. Select 0 (INK COUNT)
    6. Press Stop/Reset key
    7. Press On/Off Key
  • Anansi Jun 04, 2008
    i changed the black cartridge and it said " wrong cartridgre". can't think of what else to do.
  • cv4windows Jun 20, 2008
    our unit continues to display wrong cartridge. we have tried entering the code listed in the previous page.
  • tousane Jul 29, 2008
    My problem is exactly the same.
  • justjoany Aug 17, 2008
    Have same problem tried all above except the Memory copy # Test mode. Once I got to the Test mode stage, I could not go any further than CF-FH. Nothing happens when I press the set button.
    I tried cleaning head and cartridge as suggested and when I put everything back in place and I try and clean the head by going to Printer on the menu option, I get the warning tone.
    Problem Solver:
  • 7 Answers
The "wrong cartriage" error code may be due to the print head going bad on the MultiPassF30. I had to replace the print head on Sep 02, 2004. The Canon part number is QY6-0034-010 and their phone number is 1-800-385-2155. I paid $56.23 back then.
Just last week I got the "check printer" error code. I took the F30 apart and cleaned the felt ink pad then reset the ink overflow tank setting per:
F30/F50 Printer
2. Select TEST MODE
7. Press On/Off Key
Posted on Feb 21, 2009
Thanks for your assistance....worked on it for a couple of hours still no success.....guess it is time to buy a new printer....this one is 6 years old and I quess it doesn't owe us anything......Our previous NEC lasted 10-12 years if not longer.... so in the long run we have faired well.....Don't want to spend the mopney on a cartridge when the sytem is old and may fail in some other way.
I am looking to purchase an HP combination printer to replace this one.........any thoughts.
By the way this is the best site for information on resolving any problems that I have had with my computer and accesories.
Thanks...justjoan
Posted on Aug 17, 2008
This Sequence is NOT for the "wrong Cartridge" code- it is for the ink overflow tank reset code.
Posted on May 27, 2008
I have same problem.Please let me know if u find an anser
Posted on Feb 23, 2008
Changed ink cartridges, error code Wrong Cartridge, won't print, copy or scan
I had this same problem with my HP All in One. They told me the cartridge was defective, or the sensor was bad. Try a new cartridge first.
Apr 22, 2010 | Canon MultiPASS F50 All-In-One InkJet...
Canon F50 error Wrong Cartidge , now Put in Cartridge
if you ever get this figured out, let me know, my mp730 says the same thing, i had the head cleaned after i got a wrong cartridge error and now i have a put in cartridge error
Jan 26, 2010 | Cannon MULTIPASS C530 Printer
Alarm message says "wrong cartridge". All cartridges are correct
On Canon, wrong cartridge means the printhead has gone bad, not your inks. The printhead is part number
QY6-0034-000 around $50.00.
Nov 03, 2009 | Canon MultiPASS F50 All-In-One InkJet...
The alarm is flashing
Wrong cartridge means your printhead is worn out, not inks, you just need a new printhead.
Jun 08, 2009 | Canon MultiPASS F50 All-In-One InkJet...
My Canon Multipass F50 has a "check printer" error and won't print. The ink cartridges will not move when you open the door (as if to replace). It won't even turn off to cycle it to clear the error,
I had a similar problem. Go to this page http://www.fixyourownprinter.com/forums/inkjet/29693 and try the codes they suggest to reset the count for the waste tanks. Good luck.
Jun 01, 2009 | Canon MultiPASS F50 All-In-One InkJet...
"Wrong cartridge" message.
Wrong cartridge means the printhead has gone bad, no amount of cleaning will help. Sorry about the poor advice, but you just need a new printhead.QY6-0034-010 around $45.00
Apr 20, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Canon MP F50 "wrong cartridge" error
remove all cartridges leaving printhead intact.
close cover, turn off
turn on, let power up, error message should be gone.
open cover, reinstall cartridges
if you cleaned your print head like I did you'll probly
eventually end up getting a new one anyway, due to the color variations
but I can at least print text.
Apr 08, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Wrong cartridge messsage
Hi, Please follow :
1. Reseat F30 / F50 print head 2. The Print Head may need replacing - F50 3. Press ON/OFF switch to reset the multifunction device 4. The F50 may require repair
You can see exactly how to perform these steps with pictures at this link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=6324
Go to this link if you are unable to find the"Wrong Catridge" link
then you need to type "wrong cartridge " in the small search box on the website.
If the website asks you to select
"Category.=Multifunction"
"Product Type =Inkjet"
"Model= Multipass F50"
Cheers
Jun 04, 2008 | Canon MultiPASS F50 All-In-One InkJet...
MultiPASS F50
check the Canon Knowledge base at www.canontechsupport.com, it may be the printhead or unit itself.
Oct 23, 2007 | Canon MultiPASS F50 All-In-One InkJet...
The Print Head might be the fault of that,try replacing the print head and see if that helps
Jan 31, 2007 | Canon MultiPASS F50 All-In-One InkJet...
Canon MultiPASS F50 All-In-One InkJet Printer Logo
891 people viewed this question
old marine
old marine
