Question about Paradigm PS 1200 Speaker
PS1200 Lost Volume/Pound
I have owned this sub since it first came out. I moved to a new home. I tested everything all seemed to work well originally. I have had to use approx 20 ft. of low level input cable. For the last 7 ft. I have all the speaker cable, a few power cables and a few misc rca cables all jacketed in the same jacet sleave for neatness. I seem to not have the "power/pound" that I had originally. I removed the single sub low level rca cable from the "bunch" and no difference. It does pound but only approx 1/2 of what it did originally. Would it be signal loss (low level input), an amp problem? I cannot adjust the sub output on the receiver. Quality cables are used.
Opinions/solutions would be greatly appreciated.
Thank you very much.
  • Cobra67 Feb 13, 2008
    Thanks Ledge,
    Unfortunately reciever has only one dedicated mono subwoofer output. The sub has stereo inputs but only the red rca input is a mono input.
    Any suggestions?
    Scholar:
  • 84 Answers
Try reversing the polarity on one end.
hope it helps.
wg
Posted on Feb 11, 2008
  • wilson garcia Feb 14, 2008
    i haven't hooked up a subwoofer in a while, but from what i remember, the speaker outputs from the back of the reciever [red&black] went into the red & black inputs of the subwoofer, then the red & black outputs of the subwoofer connected to the speakers. if yours is hooked up differently, try this setup. this is where i was writng about reversing the polarity.if the striped wire from the reciever is going into the red input and there isn't much bass, switch the striped wire to the black input. try different combinations.
    hope it works out.
    wg
How many cups in pound
http://calculator-converter.com/converter_c_to_lb_cups_to_pounds_calculator.php
Mar 13, 2015 | Home
Sub connected center speaker does not work
hmmm..that's a little weird..does the sub work on it's own? Is it powered? is it connected to right boost terminals ?
Feb 29, 2008 | Yamaha DVX-S100 System
Tip
Tip for your home theater system: tweak your subwoofer level and crossover...
An important tip regarding your home theater system is to Tweak subwoofer-level and crossover controls:
Test tones and meters aren't the final arbiters in the bass department. If your sub's bass is boomy, thick, or uneven, first try lowering its volume --most people complain that their sub louder than necessary. Next, if your satellites are very small, the crossover control should also be set to its midpoint or higher. Bigger speakers produce more bass on their own, so they sound best with the sub's crossover knob set at or near the bottom of its range. Finally, moving the sub out of the corner and closer to one of the front speakers may produce smoother, flatter bass.
on Aug 23, 2010 | Audio Players & Recorders
I lost some settings in the volume menu and sub volume
did you blow a fuse, or did you blow out your speakers.
Jan 30, 2013 | Alpine iDA-X100 Car CD/ MP3 Player
My MTX Jack Hammer JH300 Amplifier is warming up... A red led indicates that the amplifier is warming up.I checked the conections and everything seems to be ok, I've a 10" Jack Hammer JH 4510 Sub...
Check the speaker connections from the amp to the box and inside the box to the sub. Its possible these came loose from vibration. Also gently push in on the sub. It should move freely and feel spongy. If it drags or is stiff the sub may be bad. Use an Ohm meter and test the sub. There is an Ohm rating on the sub (usually 4) and it should be close to that. Also check the audio in. Maybe the amp/sub combo is fine but there is no sound going in. Use an MP3 player with a 3.5MM to 2M RCA cable as an input. Start with the volume all the way down and SLOWLY raise the MP3 volume.
Please Rate!
Apr 28, 2011 | MTX JackHammer JH300 Car Audio Amplifier
My receiver is not picking up the subwoofer, there is noise coming from the sub when I'm playing with the conection. The speakers are working and im getting prefect sound from them Please help.....
It would be helpful to know if this is a new problem on working equipment or a new problem on NEW equipment. And if you've flipped through the manual without success.
Of course you KNOW the sub must have its own amp, right?
First, you need to determine if the Onkyo or the unnamed sub is at fault.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR608-Receivers-manual/id/23653ag916/t/2/
At the Onkyo, check to make sure you have run the speaker setup starting on Page 40. If that doesn't work...
Disconnect the subwoofer pre-out at the Onkyo and move it to the VCR Out, tune an FM station and be ready for some real loud subwoofer output if your sub has no volume control of its own. If you can hear the sub, it works and it's back to the Onkyo. If not, the unnamed sub
Apr 09, 2011 | Onkyo TX-SR608 Receiver
My subs are moving and pulsing with the volume off
I am currently having this problem. Im no professional but i have done installs on my own personal cars and my friends cars (saab 95, Mitsubishi 3000gt, 1996 mustang, 1999 mustang, ect..) I have replaced every but my amp, so today i tried using a friend of mine amp and that solved the problem. I have a TON of research on this and everything i've read says its more than likely a bad relay on the amp and unless you have FLAWLESS soldering skills not to mess with it. idk if this helps much but it was the solution to my problem!
May 05, 2010 | Car Audio & Video
How to install klipsch sub woofer to yamaha reciever rx-v559. everything working properly but sub wont be adjusted with volume. i got my stuff moved out here but had a mate help me set up. didnt pull it...
Does the sub work at all? How is it hooked up? The sub needs to be fed by an RCA cable from the Subwoofer Output jack for the receiver to control its output.
Mar 01, 2010 | Yamaha RX-V559 Receiver
Alpine MRD-M1005 Subwoofer Amp Problem
He may be right! You might try finding a new source of contact for your ground cause it may not be sufficent enough to ground to, also make sure that no wires from the back of your radio have any wires sticking out touching other interfering things that could possibly be causing the noise
Sep 14, 2008 | Alpine MRD-M1005 Car Audio Amplifier
Paradigm PS 1200 Speaker Logo
710 people viewed this question
Top Paradigm Audio Players & Recorders Experts
 Grubhead
Grubhead
woodzowl307
Don Hart
Are you a Paradigm Audio Player and Recorder Expert? Answer questions, earn points and help others
