Question about Admiral AW22 Top Load Washer
Hello i need help with my admiral washing machine
I put the load cicle and the temperature cicle and the normal size 6 and i only received a smal amount of water and the washing machine it look like is working but it not what show i do
  • carolina515 Feb 11, 2008
    ok now i am having problen went it get to the rinse cicle it does not keep going went it get to the rinse cicle it soposte fill with water again but it does not do nothing what show i do and thanks for you response it was help full
    Scholar:
  • 90 Answers
Completely drain the unit by putting it in the final spin. Leave the clothes out... Put it to max load cold cycle. See if it fills to a high level as it should. If it does not, does the water run in quickly or trickle. Some machines just run water for a set time and if the valve is not letting water in as it should you will not get enough to wash right. Others have a pressure switch/pod in the area next to the timer control. You can see it if you take the control console apart from the unit. It will be round and have electrical wires, ususally two and a clear quarter inch hose coming off of it. The hose goes down and attaches to the tank. As water comes in it puts pressure on this pod causing it to turn off the water. There is an adjustment screw/bolt on it that should have locktight painted on it. You may be able to turn it in or out and get it to work again but chances are when they act up the should be replaced. Very rare to see these go out. Sometimes these are part of the load size adjustment control. Hose may be loose or cracked....let me know if you need more help.
Posted on Feb 10, 2008
  • Timothy Smith Feb 12, 2008
    I think you must have a problem with the timer/controller unit. Some bad connections internal to it which causes it to do crazy things..
My admiral washer does not work on wash cycle. It will rinse and spin on any cycle but wash
hi Marilyn.
this is what i have found but not sure if this will help you out,if not go to the link at the bottom and see if it helps you out.
Step 1
Make sure the washer's cord is plugged in to a functioning outlet if the Admiral washer won't fill with water. Check your circuit breaker to make sure the power is on and reset it if necessary. Reset the dial and start the washer again. Turn both of the washer's faucets on to full power. Untangle any inlet hoses to remove clogs. If this doesn't work, your hose filter screens could be clogged. Disconnect the hoses from the washer and clean the screens of any residue.
Step 2
Close the washer's lid completely if the Admiral washer will not agitate. The washer will not start if the lid is open. Restart the washer by setting the control dial to the desired cycle. Momentary pauses during cycles can be expected. You may need to wait a minute or two to see if the washer starts. Check the circuit breaker to make sure the washer is getting power. Reset the circuit breaker if necessary.
Step 3
Check and reset the circuit breaker as above if the Admiral washer will not spin or drain. Untangle any of the washer's hoses to allow water into the machine. Check your drains for clogs that may be preventing water to move into the washing machine. Close the lid and restart the washer. The washer will not start if the lid is not completely closed. If there are excessive soap bubbles in the washer, the washer may have locked up because of this. Wash the load again without adding detergent.
Step 4
Rearrange the laundry so it is evenly distributed if the Admiral washer stops or if laundry is still wet at the end of a cycle. Untangle any laundry from the center post in the wash tub. Select the correct water level for the amount of laundry. Select a normal spin cycle for jeans, towels or other heavy loads. Close the lid and start the washer.
Step 5
Check the hoses to make sure they are tightly connected to the Admiral washer if it leaks water. If they are loose, tighten them with a screwdriver. Make sure the drain hose is secured to the drainage area. Avoid putting too much laundry in your machine or soaking laundry for over 30 minutes.
Step 6
Make sure the Admiral washer is on a level plane if it is excessively noisy. If it is not on even ground, move the washer so that it is level. Remember that some washer noise is normal. Thin floors can cause the washer to vibrate and move about and the noise level may rise and fall depending on the speed of the cycle.
admiral washer does not work on wash cycle Google Search
Nov 25, 2017 | Washing Machines
Amana NTW475OYQ1no lights or sounds. Verified power @circuit board. Someone closed lid on a shirt earlier that preventing lid to I open.verified switch waz working and the wife did a load of laundry.
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following ... Speed Queen, Amana Whirlpool ..... Lid lock lightflases; no spin cycle.
Amana Washing Machine NTW5400TQ1 Troubleshooting ...
www.repairclinic.com/.../Washing-Machine...-/Amana-Washing-Machin...
Amana Washing Machine NTW5400TQ1 Troubleshooting & Repair Help. Amana Washing Machine problems. Washer won't spin · Washer is making loud noise ...
Jan 16, 2016 | Amana Washing Machines
I have an Admiral top-load washing machine (Model AK44000) which now leaves some items (especially kitchen/tea towels and bathroom towels of all sizes) with a 'funky' smell (like bad body odour)...
How old is this machine? Older machines' gaskets loose their property of remaining intact & melt like semisolid due to use of detergents, which are likely causes for the foul smell.
Sep 18, 2011 | Admiral Washing Machines
Hello. My washer kemnore Mod. 110.29822800 NO WASH
Sounds like the timer is faulty and needs to be replaced.
Jul 16, 2010 | Kenmore Washing Machines
Willnot spin
You may have a bad lid switch.
Mar 07, 2010 | Maytag Admiral AAV7000A
My admiral washing is making a clicking sound like torqued drill
CHECK THE MOTOR BRUSHES 1st if not that and it is bearings an engineer would normally change bearing two to three hour job depending on how the bearings come out some times they are stuck fast
Jan 16, 2010 | Admiral AW22 Top Load Washer
My Admiral washer machine moves and shakes all over the place on the spin cycle what is the problem
It needs to be rebalanced.screw the front legs down first tilt the machine up from the front slighltly to automaticly re adjust the back legs (shouldnt be any screw legs there) then manualy re adjust your front legs. this happen a lot when you wash big loads or blankets and such etc. and is normal glad to help you
Jan 08, 2009 | Admiral AW22 Top Load Washer
Lid switch for admiral washing machine (13 years old)
From description it looks more like you have to replace the lid switch, if you have to push it down, then the contact inside is broken.
You find replacements here, just insert the model number.
Sep 14, 2008 | Washing Machines
Admiral AW22 Top Load Washer Logo
63 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
