Question about Linksys Wireless-N WRT150N Router
Problem hello, I dont know ip adress for my router...I want change password. Can you help me?
Go to the website. They actually answer the phone, in India. They will hook you up. Hard to believe
Posted on Feb 10, 2008
  • 62 Answers
Try opening your web browser and in the adress bar type in or something close to that.
I have lost the security code and have a new laptop, how do i set it up to work
If you don't remeber the wireless security code, maybe you still remeber the user and password to access the web management interface of the router.
Then you have to connect the laptop to the router by using a network cable. Open a browser window, type in the IP adress of your router and check the wireless setup section. There you can find / modify the wifi security code.
If you don't know the router's IP adress, then open on your computer a ms-dos prompt and type the command
ipconfig /all
it will display your current IP adress, subnet mask and GATEWAY. The gateway adress is the router's IP adress that must be typed into the browser.
If you don't remember the user and password for accessing the router's web interface, please refer to the router's user manual in order to reset it to factory default configuration, and then proceed as for the first installation of the router.
Hope it helped,
Aug 30, 2011 | Belkin (F5D8231-4) Wireless Router...
I have an ibm r40. cannot connect to my wireless router.was working perfectly prior. when i hard wire to the wireless router the ststus show an ip address of
if you can set up your connection manually change the IP adress to (this is usually the default IP adress for most routers) let me know if this helps I have more Ideas for you if it doesnt
Nov 15, 2009 | IBM ThinkPad R40 2681
Router wont let ps3 have ip adress
you need to open a incoming port for the ps3 on your router all you have to do is use the computer to go to your router settings then use whatever ip the ps3 is using and open a port for that ip address that should work but i dont have a ps3 so i dont know you could try that
May 09, 2009 | Computers & Internet
Need to change netgear router rp614 from dsl to cable
First connect one of the ethernet ports (LAN) to your computer.
In windows to this:
XP: Start -> Run -> write CMD and press ok-> Black window pops up-> write IPCONFIG and press Enter. -> Look for Local ethernet connection and write down the ip adress outside default gateway (f.ex or
Vista: click windowsmenu icon-> write CMD in search field and press enter -> Black window pops up-> write IPCONFIG and press Enter. -> Look for Local ethernet connection and write down the ip adress outside default gateway (f.ex or
Open a webbrowser and clear det adress field, enter the adress (with the dots and no www.) you wrote down from default gateway and press enter.
If you get promted for a username and password the default is: username: admin password: password (you can find it on the side of the netgaer box under deafult accsess.
If you cant get in try to do a "hard reset" (push the reset button for 30 sec with a pen).
You are now in the web user interface for you netgear.
On your lefthand side, you should have a blue menu, click on the first option on the top and run the setup wizard, dont change anything (dont choose that your connection needs a password to connect) just use the default settings. Remember to press save on the botom.
You should now be ready to use your netgear router.
If this guide didnt fix your problem, i need more details to help you.
Check with your new service provider if they require a username and password to connect (PPPoE).
Feb 07, 2009 | NetGear WGR614 Wireless Router
How to open my router neatgear firewall? Cause the other website block like youtube.. Can u help me...
through the ip adress contol panel on you browser by typing the ip adress in the browser it will ask for a user name and password. This is where you can chang that setting and maney others.
Jan 06, 2009 | NetGear WGT624 Wireless Router
Netopia 2247NWG for smarttelecom
Sorry if my writing is not clear I dont have best english.
If you move your router from eircom to smartelecom you have to change security protocol from "chap" eircom to "pap" smarttelecom.
Now Do this few steps.
Go to start menu on windows find and click run.
type: cmd and press ok
When you will see black screen that will be command prompt.
Now you have to type your defaul ip adress. To check your defaul ip adress type ipconfig in command prompt and press enter.
Default Gateway is your default ip adress. Now when you know your ip type in command prompt:
telnet yourip 23 and press enter, for example:
telnet 23
If you didnt setup any password to login to the router you will be loged automaticly and you will see "Netopia-2000/18861188>
But if you have setuped login and password to your router you have to first type your login and press enter,then password and press enter to have acces.
next is easy type:
configure and press enter
ppp and press enter
set and press enter
now you have to pressing enter about till you will see line:
option <chap-only> [ off : on : pap-only : chap-only ]:
on this line type pap-only and press enter
now start pressing enter till you see:
Netopia-2000/18861188 <ppp>>>
then type save and press enter.
When you see line:
Configuration data saved you can close command prompt window.
From this moment your router will be work with smarttelecom.
Dec 13, 2008 | Netopia 2247NWG-VGx Wireless Router...
DWL-G710 - Not able to logon with standard IP-adress
Must have same IP-adress on Router and Repeater 192.168.0.x. Then have cable from router to PC and from router to repeater. Then logon to repeater and the Dlink-repeater SW have a command where you can see available networks. See to that you choose the right one and that channel, name and password is the same as the router. The repeater will not be visible when you search for available networks because it has the same name as the router. I also had to restart the router and the repeater before it worked.
The repeater gives us excellent connection where we otherwise has no connection, so I can recommend it.
Aug 27, 2008 | D-Link AirPlus G DWL-G710 Wireless Range...
Driver help...Anyone?????
For Router drivers is not required ,U can configure though the command prompt
I can tell some configuration try it,
the default ip adress of the router will the OR
In your Lan card configure,
1. obtain Ip adress automitically
go to command prompt----type ---ipconfig---check the ip address which ip is getting---
go to internet explorer ----type the ip address in adress bar-----------login page will get---
login as, user name admin
password admin------configure your internetip adress & DNS ip address,save & check.............
Mar 21, 2008 | Actiontec GT704WG Wireless Router...
Linksys Wireless-N WRT150N Router Logo
87 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
