Question about HP OfficeJet 6110 All-In-One InkJet Printer
Original document stuck in feeder of HP OfficeJet 6110 All-In-One
While trying to make copy Original document stuck in feeder of HP OfficeJet 6110 All-In-One. If you like you can call me at 732-679-3560
    Genius:
  • 3,587 Answers
Ok...this is not that hard...you'll need to open up the top of the machine, and most likely remove some components. Take a look at this link first though Got backup?
Posted on Feb 10, 2008
I want to fax a document
Hi
To send a fax from your hp officejet
Follow these steps to send a fax from your HP OfficeJet.
1 Load your original.
Note: You must use the automatic document feeder (ADF) for multi-page
faxes.
2 Enter the fax number using the keypad.
3 Press Start Fax, Black or Start Fax, Color.
Oct 26, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I want fax a document
Hi
faxes.
pls vote me i help you
How do I scan a picture and email it?
Hi
You can start a scan from your computer or from your HP OfficeJet.
to scan an original from your Windows computer
1 Load your original either on the glass or in the automatic document feeder
(ADF).
2 Press Start Scan.
A scan of the original appears in the HP Preview window.
3 In the HP Preview, you can edit the scanned image. When you have
finished, click Accept.
For more information about making changes to an image during the
preview, see adjust an image during the preview in scan pictures and
documents in the HP Photo & Imaging Help for more information.
The HP OfficeJet does a final scan of the original and sends the image to
the HP Photo & Imaging Gallery.
If i helped you pls vote me
Sep 07, 2010 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet J5780 Vertical Black Line Prints when copying or scaning only. Cleaned rollers and changed black ink cartrigde. Still problem.
Have you tried cleaning the document feeders Scan Glass? (small glass under doc feeder ~ 1" by 9") Most times there is dirt spot on this glass, causing a shadow on scans and copies.
Try copying from the large glass by lifting doc feeder / platen cover and manually placing original. If no line copying or scanning manually from large glass, then small scan glass is deffenitely the culprit. Hope this helps.
Sep 07, 2009 | HP Officejet 5780 Printer
Automatic document feeder will not feed. Tried
Check the sensor. (See here)
Take a look at solutions offered here.
Sorry I can't offer much more at the moment, the HP search engine is down for maintenance...
Jul 30, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Line through scanned document when using the document feeder only
try cleaning the glass scan bar on the unit with a clean soft cloth.
Feb 20, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My HP printer paper get stuck in top feeder whenever I try to fax
Lift the cover to the ADF (Automatic Document Feeder) and remove any paper debris from the rollers. Also, clean the rollers with a very damp cloth and a dab od dish washing detergent.
Also, check to see that the spring loaded lever is in place.
Clear the jam from the automatic document feeder (ADF)
  1. Make sure the product is turned off and the power cord is unplugged.
  2. Grasp the upper edge of the automatic document feeder (ADF) assembly and open it.
  3. Raise the roller assembly.
  4. Gently remove any jammed paper from the ADF.
  5. Lower the roller assembly.
  6. Close the ADF assembly.
  7. Plug the power cord back into the product.
  8. Press the Power button (c01346625.gif ) to turn the product on.
  9. Try the print job again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 01, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP 7410 streaks when using auto document feeder to make copies
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Will not copy
The machine is falsely reading that there is paper in the Automatic Document Feeder. That is why it is saying "Original Loaded" before you put the paper on the glass. When you hit Copy, it is trying to pull paper in from the ADF, when it doesn't get any, it reads "Reload Document" because it thinks there is a jam. There is either something stuck in the ADF causing it to trip the paper sensor, or the paper sensor is broken or dislodged. Open the top cover of the Auto Feeder and look for a small black piece of plastic that looks like it moves back and forth when paper hits it and see if there is anything wrong with it.
Hope it helps!
May 18, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Keeps asking to load original in document feeder
This has a happy ending. But first, the obligatory narrative:
The HP site has advice on how to deal with a document feeder that doesn't detect your document. It doesn't talk about the opposite problem, which is what molecular is describing. I had the identical problem yesterday. I'd place the original on the glass and it kept demanding that I put the original in the feeder. So I got into a chat session with the HP technician. Her advice, (based on the possibility that a power surge had created the problem) unplug from everything, restart, and retry. The problem persisted. I told her so. She broke the connection. Nice.
So here is how I fixed it. Using the Setup button>Tools>3. Restore factory defaults, I returned the device to its factory settings. I put the original on the glass and it made the copy without a problem.
Here is a pure speculation. There are at least two ways to enter settings related to two-sided copying. I had used one to enter the settings (two-sided original to two-sided copy, as it happens) and later tried to use another button to change those settings. I noticed the 2-sided settings did not change. I believe the feeder is the default for two-sided copying. So when the system failed to clear the settings, it failed to clear the default. Once I returned all settings to the factory originals, the problem disappeared.
Jan 13, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
85 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
