Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
Red blinking light on a Magnavox Plasma TV
I have a Magnavox Plasma TV. Model # 50MF2310/37
It was real windy outside and the power flickered, now I al get is 4 blinking red lights and nothing else happens. Does the 4 blinking lights possibley mean a fuse is blown or something else?
Thanks
  • 6 more comments
  • Anonymous Mar 27, 2008
    why is there no responses shown to this problem
  • da_sellars Oct 07, 2008
    I have a Magnavox 50" Plasma. mod# 50MF231D/37. 4 Red Blinking lights on power up. Called Magnavox for help. Out of Warranty. no help,bring it to repair shop near you. if there is any way to narrow it down to the power supply assy, i would like to know it.. if the tv sits for a few days, it will power up and function for a few hours, then dies, with 4 red blinking lights. HELP!
  • Anonymous Nov 11, 2008
    red light blinking no tv screen complete shut down
  • lwcummings Mar 18, 2009
    I have the same tv and the same problem...we were told to upload new information into the tv...on a disk drive...we did...it fixed it...but the next day started blinking again! Any help greatly appreciated!
  • Anonymous Apr 10, 2009
    Same red blinking light occured for me this morning. Anyone find an answer yet?
  • webringkaoz Apr 19, 2009
    i have the same tv 50mf231d/37 and today i got up and tried to turn it on the normal green light turned on but the tv itself didnt do anything and within 15 sec the green light turns red and it flashes 3 times stops for a sec and again 3 times it continues doing that but it doesnt turn on i did have the power go out on me a couple times before this happened so i dont know if that had something to do with it and is it something i can fix or am i screwed
  • baruhbosch23 May 19, 2009
    I have a magnavox 50 in plasma (50MF231D/37) and everytime I turn it on it takes 1 minute for the picture to come up. Sometimes it never comes up and it turns off by itself and thats when the blinking red light turns on. I just end up pushing the reset switch on my surge protector and wait 10 seconds until I switch it back. This usually works but I still have to wait a minute for the picture to show up.
  • bbotz May 11, 2010
    I have the same problem. After a power surge the tv turns on then immediatly shuts off and blinks 6 red lights. Can anyone tell me where to find the meaning to the blinking lights code. It has to mean something.
Here is the solution. For less that 100$ your Magnavox Plasma TV. Model # 50MF2310/37 will be running like a champ.
Issue:
Magnavox Plasma TV. Model # 50MF2310/37 screen has no picture. There is no sound, TV comes on and then after a few seconds clicks and screen remains blank.
Cause:
On the main power circuit board to Capacitors are prone to failure from over load. The caps are 3300uf 10v 105+c capacitors located to the left of the AC power input.
Service:
Magnavox will refer you to a service center. They will advise $$$ for an inspection. They will also want to charge upwards of 500$ to replace the entire board.
Solution:
1. Unplug your TV
2. Disconnect all connections from your TV
3. With assistance lay your TV on its face on a non-scratching service
4. Remove the back panel screws.
5. Lift back panel off
6. The central board is your main power board.
7. Remove all wire harnesses from the main board.
8. Remove all screws that are holding the main board in place.
9. Lift the main board out and carefully place it into a non electromagnetic pouch.
10. Take the board to a Circuit Board repair shop.
11. Have them replace the the above mentioned Caps.
12. Re-install the board in your TV.
NOTE: Replace the caps with 3300uf 16v 105+ high temp caps(preferrably Japanese caps)
This fix cost me 80$ and my time to search for other who had the same issue. Try searching for Magnavox Plasma TV. Model # 50MF2310/37 bad circuit board or Magnavox Plasma TV bad capacitors or Magnavox Plasma TV bad ciruit board.
Hope this all help, Magnavox is should take ownership for this problem and recall any tv's that have these caps in them. The worst part about this is that teh **** from the repair center that was paid 100$ to check the TV, stripped out the screw holes and damaged the case for the TV.
Portland Laptop Repair was awesome. They repaired the board and it looked like new. Check them out at http://www.laptopportland.com/
Jeff G
Portland, OR
Posted on Apr 28, 2009
  • mr_e_mn007 Apr 28, 2009
    Issue:
    Cause:
    Service:
    the entire board.
    Solution:
    1. Unplug your TV
    TV.
    looked like new. Check them out athttp://www.laptopportland.com/
    Jeff G
    Portland, OR
  • 22 Answers
Im not sure im new here. lots of people with problems, but no one seems to answer or respond to them lol. I have 5 blinking lights. what i gathered so far, it's either a fuse on the main power board, or the board itself.Juust open the tv up lots of screws, dont forget to take off the small little screws on the hdmi, and the nut on the coax.
Posted on May 03, 2008
My plasma made a loud POP! and now no pic only sound. What could that be?
Posted on Feb 17, 2010
    Problem Solver:
  • 17 Answers
Goater, is the fuses suppose to be white? Is that normal or blown?
Posted on May 05, 2008
My 50" plasma tv is flashing red blinking light and will not turn on
Flashing Red Light is a sign you should contact Authorized Service or check User Manual for such reference.
BUT BE CAUTIOUS NOT TO TRY A REPAIR YOURSELF!
Apr 28, 2014 | SNK Magnavox 42MF231D 42 in. Plasma TV
My magnavox tv model num 50mf231d137 will not turn on it turns on then turns off with red light blinking
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information google.com/+GopakumarGopalan
Nov 19, 2013 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox Plasma TV went off.
The red LED merely indicates that power is getting to your TV. There may have been a power supply failure, especially since your TV is a 2008 model
Jun 28, 2013 | Philips Magnavox 42MF521D/37 Television
Samsung plasma blinking red light, tv won't turn off
Hello, The real problem is on your TV 'scircuit. Due to high electric power supply there might be a short circuit damage. It's better you call up your service technician and ask him to offer you a onsite support.
Nov 11, 2017 | Samsung PN51D7000 3D Plasma TV
Phillips TV Model: 52PFL7422D/37 Purshased this TV Dec 16, 2007. No I have blank screen with the TV blinking a read light at the left - the red light flickers - blink, blink,blink,blink,blink then 3...
First place to check is the power supply board. I have not repaired this particular model. I'm very certain you have two bad capacitors in the power supply. This is a classic problem for Philips flat TVs. The capacitors will be bulged or skinned. Be sure to replace them with same values. I would certainly gamble my time removing the power supply for inspection. Spending a few bucks on two capacitors may prove good. A working TV is near. Thanks for asking and show all hands of support!
Jun 30, 2011 | Philips 50PFP5332D 50 in. Plasma...
Hi i have a magnavox 42" plasma TV (model
I'd look for the manual and see what it says about that red light. I can't find squat for "Magnavox KM42010P".
May 28, 2011 | Philips Magnavox MRD120 - home theater...
My 50 inch plasma
We have a 50 inch magnavox plasma screen. We found and used a fix from fixya! It only costs us $34.00 campared to the $300.00+
anyone wanted to look at it. The problem was on the powerboard but was two little capacitators with the model #3300 10v. We carefully took the back off the tv and removed the power board, went to a local electric supply store and bought the 2 parts for $2 each, we then found someone (tv repair shop!) to sauter the new ones on! Got it home put it back together and it stayed on, no depressing shutdown after a few seconds! you can find a picture of a fried capacitator on yahoo images, they are supposed to be flat but if defective will be bubbled at the top or even split! I am calling Magnavox today to complain that they are not recalling this part that should have been a better quality capacitator! Hope this helps some people!!
May 23, 2008 | Philips 50PF7320A 50 in. Plasma HDTV
Magnavox Plasma HDTV Red light
I had a similar problem with my magnavox tv with the blinking light issue. Eventually it just didn't come one anymore. Looking at other forms they said the problem was a bad capacitor number 2074 located on the power supply board. When I opened my tv, I noticed that the capacitor was bulging and burnt up. I bought a new one labeled 2200uf 35v and did some solder to attach the new piece. Put the tv back together and it works like new. No more blinking light. I hope this helps.
Feb 02, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips magnavox 25TS56
Same problem. The power button does not work. The volume and channel buttons turn the tv on. the tv then shuts its self off 15 seconds later. the red light blinks in second intervals while this happens.
Sep 16, 2006 | Philips Magnavox MS3252S 32" TV
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
3,291 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
