Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Tv screen black
I have a mitsubishi dlp model wd-62525. i changed my lamp about 4 months ago. all of the sudden the screen had green lines going horizontal then just went black. sound is there, red light came on. had technician come out and he seem confused. he said the lamp comes on then shuts off. he said it might be the power supply not getting enough power and said it would cost around $500. any suggestions are very much apreciated. don't really wanna drop $500 on a possible easy fix.
  • Anonymous Mar 12, 2014
    Sound comes on with static noise but screen is black
    Genius:
  • 3,422 Answers
Regarding the horizonta lines i can say it is not a common problem. This is a vertical deflection problem - possibly a bad capacitor, bad connection, flyback/pumpup diode, or other component. If the symptoms change - particularly if they become less severe as the set warms up, a dried up electrolytic capacitor is most likely. If they get worse, it could be a bad semiconductor. Freeze spray or a heat gun may be useful in identifying the defective component.
It is often easiest to substitute a good capacitor for each electrolytic in the vertical output circuit. Look for bad connections (particularly to the deflection yoke), then consider replacing the vertical output IC or transistor(s).
Here is what I want you to do:
ONE: Do a hard reset (just to make sure there is nothing in the coding that is fowling things up). Unplug the power cord; leave it disconnected for 4 hours. That will restore everything to factory defaults when you power it back up.
TWO: Do the "whacking test" by banging your fist on a few strategic places to see if there are any cold solder joints or loose wires acting up inside the set.
THREE: If the above does not restore the picture, then there is probably something strange going on with the horizontal deflection system. Probably one of the main Integrated Circuits that process the video and the raster generation. I doubt if it is the convergence board.
So finally if none of the steps told above solves ur problem i am sad to say you have to get it repaired..
Goodluck..
Posted on Feb 10, 2008
    Novelist:
  • 123 Answers
There are so many possibilities. It could be a dead projector tube,
leaking cooler fluids, bad power supply connection, broken connector pin
and so on. You really need someone who can get inside and find out the
cause of failure; it requires one who knows how to observe, take measurements
and track down the various possibilities. It is not an easy job on this one
and it is not a home remedy solution, sorry to say.
For the beginner, here are two things you can do - and they don't cost anything.
ONE: Do a hard reset. Unplug the power cord for 4 full hours, then power it up again.
TWO: Give it the banging test. Smack the set vigorously with your hand or fist in
various places. Doing so will often reactivate a loose connection or cold solder joint.
This may bring the red gun back to life - let's give it a 35% chance of doing so.
If these two procedures don't help you are going to have to bring in the big guns.
Just a comment: There are over 3,000 parts in a set of this kind not counting the
millions of transistors buried inside the several integrated circuits. There are
about 12 totally independent sections that function on their own as well as interface
with all the other circuits. It is not something easy to do. Even a trained and
experienced PHD in Electrical Engineering does not have the foggiest idea about what
goes on inside a tv without extensive training in television receiver theory and practice.
So, don't feel overcome with it all; there are few who really know this business.
IT is truly esoteric in nature.
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
  • 1 more comment
  • PRIYABRAT  PATTANAIK
    PRIYABRAT PATTANAIK Feb 10, 2008
    Does it have a video input? Does it have color when playing a vhs tape or dvd into the video input?
    Does the set show the raster lines? Is there any snow showing on the raster?
    If the set does not show color with an a/v input either then it is likely the main power supply section feeding the deflection system or the video processing is bad.
    RCA sets more than a few years old are not good investments for repairs, unfortunately.
    Let me know the answers to the questions above and I can give you a more precise suggestion.
    It may be almost certainly a high voltage and/or horizontal output amplifier going bad (they work together).
    It is quite a common failure among picture tube type sets. The cost of repair - if you lug it into a shop - should not exceed $200. That is my guesstimate.
    Best wishes,
    There are so many possibilities. Do you have any test equipment and can you take voltage measurements and/or scope images?
    I suspect the chroma/video board may need changing out. It iwll be very expensive; maybe more than the set is worth. The price of new 27" sets begins at around $120 now days.
    But, with the service manual you should check the dc voltages around the chroma section. If you don't have a vom or voltmeter I suggest the little one at Walmart tool section for $9.83. It will suffice for general readings.
    Hope this helps.
    Good Luck
Mitsubishi WD-62525 TV will not turn on
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it for a samsung ,it works like your mitusibishi:http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php The ballast has a sensor that detects when it's not able to power the lamp or if lamp is not responding,it will flash red when that sensor detects that.When you say: "it began to roll like the vertical and horizontal hold did not work then the sound went out" Do you mean you where getting horizontal lines? If you did that could be the Dmd.his is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Usually when there's a green light it could indicate a problem with the power supply,sometimes some capacitors do go bad. Check all of this and comment on this answer to see how it went.
Apr 08, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Bad color on mitsubishi dlp wd-73732 hdtv
Light Engine Failure.
Mitsubishi extended the warranty on THIS model to 3 years. Check your manufacture date on the back of the TV, , Then call Mitsubishi. They are replacing light engines and/or replacing TVs with newer models without the problem part.
Jul 22, 2009 | Philips 60PP9202 60" Rear Projection...
Tv totally black, with the red light of lamp on.
sounds like the 34 error which is caused by the power board capacitors. you can get the repair kit that should repair that issue. The kit contains the replacement capacitors and step by step instructions. Heres a link to the repair kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Jul 06, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Flashing Green "Timer" light on my Mitsubishi WD-62525
My Sony had the same problem. Unplug from the wall for 36 hours and it should solve the problem
Mar 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Model # WD-62525 lost picture
really hard fix. but its like 350 to send it off to the repair center in cali.
Mar 12, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi DLP WD 52525 has small green lines on the screen
do the lines go from top to bottom, and are they about 1 inch apart? or do they move diagonally across the screen?
Dec 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi tv
ok.
#1. replaced capacitors on power board. DM board FMT board .
# 2 on power board you need to chek caps. 3300mf x 35 v.QTY 2.
# 3 12 capacitor 1000mf x 16 v.
If caps 1000mf x 16 v . looked good. replaced anyway......
Sep 14, 2008 | Mitsubishi WD-62525 62" Rear Projection...
TV was working earlier, today came home no green power light no nothing
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
96 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
