Question about Canon Pixma MP500 All-In-One InkJet Printer
Canon Pixma MP500 Multifunction printer copier scanner error code 5C00
This is actually a possible fix for error code 5C00 "purge cam sensor" where the purge unit has been replaced but still shows the same error code.
I found this by error but it might apply to other Canon printers.
I bought the printer off a well known auction site for a couple of pounds described as "not working does not power up when switched on" I soon found a wire unattached on the power adaptor plug and after soldering got error 5C00. I stripped the unit down and removed the purge unit to find it unused with no ink on the pads that touch the print head, it looked new. I checked the microswitches and sensors were switching/sensing reassembled the unit to have the same error, the purge unit was being driven by the motor correctly, the scraper bit was moving but the unit said it wasn't sensing. I started checking the wiring and that all plugs were in the correct sockets. they were all different except for two, the plug from the purge unit with 4 yellow wires, and a plug with same fitting but with 4 multicoloured wires. the plug from the purge unit at this time was just to the right of middle of the main board and the plug with the multicoloured wires was on the extreme right
somewhere around half way up. I swapped them over the plug from the purge unit and 4 yellow wires were now halfway up on the extreme right of the mainboard, hey presto it worked and the printhead now moved so I assume the multicoloured wired plug feeds the print carriage. The printer functions perfectly.
The person who stripped it to replace the original purge unit must have got the wires crossed.
Hope this helps a few printers out.
  • sassy milf Aug 17, 2008
    hi i have the same problem error code 5C00 lights 1 x green 1 x orange flashing MP600 CANON PRINTER
    Problem Solver:
  • 3 Answers
He fix is in the problem
Posted on Feb 11, 2008
My printer has come up with a service error 5c00. What can i do to fix it?
The 5C00 code is for purge cam sensor error meaning an error occurred in the purge unit. You can remove the purge assembly and clean out all the ink covering the moving parts. You can clean it with isopropyl alcohol or just water. If no luck, replace the purge unit, will be around $30.
Mar 21, 2011 | Canon PIXMA iP90v Printer
I am getting an error message that says 5C00
The 5C00 code is for purge cam sensor error meaning an error occurred in the purge unit. You can remove the purge assembly and clean out all the ink covering the moving parts. You can clean it with isopropyl alcohol or just water. If no luck, replace the purge unit, will be around $30. This is the part number, if you need to replace it: Purge unit (QM2-2925).
Jan 24, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Canon pixma mp530. Error 5C00
it means Purge cam sensor error
visit this link for more info and possible solution
http://pcmediks.blogspot.com/2010/11/canon-pixma-error-codes-and-solution.html
Dec 05, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Error code 5C00 on Mp 500 please help with fix
Dec 01, 2010 | Canon Pixma MP500 All-In-One InkJet...
What problem of erro 5C00 ?
Nov 25, 2010 | Canon PIXMA iP3500 Printer
Printer makes loud noises while powering on, and displays error code 5C00
Nov 23, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Service error 5c00 canon ix4000
Purge cam sensor error [5C00], PG position error [5C10]
Mar 23, 2010 | Canon PIXMA iX4000 InkJet Photo Printer
Canon ix4000 error 5c00
error [5C00] & Light Blinking 4 times = PURGE CAM SENSOR ERROR
you may need to replace :
- PURGE UNIT
- LOGIC BOARD ASSY
Oct 14, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
Error number 5C00 Canon Pixma4000
Purge cam sensor error [5C00] - Purge unit may need cleaning.
Here is the service manual.
http://www.timtaylor.net/tech/iP4000_Service_Manual.pdf
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 27, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Service error 5C00? what's that?
Service error 5C00 is a purge unit error. The purge unit like a spitoon to the printhead where is stops. There is a sensor in the purge unit; when it is blocked (usually by ink build up), that error is given. The error indicates that the purge unit may be full or at least gunked up. It may be possible to clean the purge unit and sensor to make the error go away. I base this on information learned with experience on another Canon product (Model i560). Hope this helps...
May 30, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
1,221 people viewed this question
old marine
old marine
