Question about NEC ND-3540A DVD RW Dual Layer Burner
PC Saying there is a fault (code 39)
I was using my PC yesturday with no problems. Today however the PC does not show the CD drive at all, I went to the device manager and it showed my CD drive with a little warning icon next to it. I clicked on it and it says "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available."
I have done all of that but it still does not work. Any suggestions?
  • Jonnerz26 Feb 11, 2008
    Thanks very much! All sorted now.
    Many thanks again.
    Champion:
  • 208 Answers
Use this www.cdr-zone.com/forum/about4719.html&highlight=filtercheck
the 4.6 tool. download it. then run then click yess to all and restart. you havw corrupted upper or lower filter driver
Posted on Feb 11, 2008
please help me on this regard and thanks. sktatu@gmail.com
Posted on Nov 28, 2010
Can't eject CD from CD rom
Disassembling may be your only option, if the CD is Broken or jammed. Try rebooting and pushing the DVD rom button at boot. I had a DVD explode, I had to remove the drive and disassembling the DVD rom to remove all the pieces.
Apr 07, 2013 | Acer Aspire Z5700 All-in-One Desktop Pc
Hp probook cd rom opens by itself
Open the unit and disconnect the power supply to the unit and remove, Check the eject switch and see if this is jammed. Use a brush to clean and blow out dirt.
Now reset the unit and if the fault repeats the drive is faulty, Confirm this by connecting with another PC.
Jul 06, 2012 | HP Computers & Internet
OptiPlex GX400 can't find the CD drive and can't find the hard drive
hey, if the machine boots into windows but doesnt show the cdrom drive in my computer, might be you have had norton on in the past theres a common fault that makes the drive disappear, the fix is on this page http://www.facebook.com/l.php?u=https%3A%2F%2Fwww-secure.symantec.com%2Fnorton-support%2Fjsp%2Fhelp-solutions.jsp%3Fdocid%3D20090430144107EN%26lg%3Denglish%26ct%3Dunited%2Bstates%26product%3Dhome%26version%3D1%26pvid%3Df-home%26entsrc%3Dredirect_pubweb&h=jAQEyPa4V
if the drive aint showing in the bios, make sure you have the jumper on the drive set correctly to either slave or master depending on how its cabled. hope this helps ;)
Jun 12, 2012 | Dell OptiPlex GX400 PC Desktop
I changed my gas cap yesturday and my engine light went on today. would that have anything to do with it?
Hello: Yes if it is not designed for your truck it will cause the engine light to come. (the evap system) If you put a locking gas cap on that could be the problem. If you want a locking gas cap you will have to get a GM on
Aug 28, 2011 | 2007 Chevrolet Equinox LS New Cars
I went to start my car today. The car started fine, but then a light saying "airbag fault" came on. I went to put the car in reverse and back out of my driveway, and the gear shifter would not move. But it...
The Airbag and Transmission circuits are independent of each other.
There is a possibility of a computer malfunction, but this can only be determined by taking the vehicle to your nearest VW Dealership, and have the workshop scan your computer for Fault codes.
This will identify the problem immediately...
Hope this helps....
Nov 12, 2009 | 2003 Volkswagen Passat
System recovery
You can't do it in the BIOS? Mine you F1 operns BIOS and then F10 went into system recovery. Yuor might be different but look in the BIOS.
Sep 19, 2009 | Compaq Presario 5000 PC Desktop
Ran yesturday, tried today no fuel in lines, or pressure in rail, fuel pump not activating
Check the fuel pump fuse and relay under the hood in the fuse panel. If both fuse and relay are good then fuel pump may be at fault, but it seems too new for a fuel pump replacement. Hope this helps. Keep me posted please. Good luck
Apr 27, 2009 | 2005 Dodge Ram 1500
Drive not showing in WinXP (error code 39)Liteon Combo SOHC-5236v
After loading the Windows, the DVD/CD-ROM drives work properly, but we can not see the drives in “My Computer” (System can not recognize the drives.). When try to run the drives, it shows up a notice “Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code39).” Before solving this error, check the drives connection correctly, then follow the steps below:
Delete Device Manager. Most people will firstly think of Windows “Find New Hardware” when drives missed, but it does not always work out. To fix the problem: open “My Computer”’ “Control Panel” ’“System”’“Device Manager”’ “HDC(Hard Disk Controller) ”, then click “Delete”. Follow the note to reboot computer. After rebooting, the computer will find the Primary IDE Controller and Secondary IDE Controller again and install the drivers. Restart the computer again while the installation is completed. In this, we can get back our CD/DVD-ROM Drives.
The other way is by editing the registry to return the missed CD/DVD-ROM drives (Code 39 error.). Obviously, it is too risky to edit the registry if you are not familiar with it. To fix the error from the registry, carry out the following steps:
Exit and close all applications currently running on your PC.
Step1. Click Start > Run and type in Regedit, press Enter.
Step2. Look for the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\ {4D36E965-E325-11CE-BFC1-08002BE10318}
Delete any of the following registry entries under this key directory:
LowerFilters
LowerFilters.bak
UpperFilters
UpperFilters.bak
Step3. Reboot your PC and open My Computer to check that the CD-ROM drive is visible.
Also, have a look at the Device Manager to see if the yellow exclamation mark and the error code 39 are gone.
System errors are not welcome guests that bring up unhappy computing experience. Registry Easy (www.registryeasy.com) is a professional troubleshooting system maintenance tool that can help you to solve this error and many more.
Article Source: How to fix DVD/CD-ROM drives (Code 39 error) in Windows XP or Vista
Posted on 2 January '09 by , under TECH NEWS.
This worked for me.
Feb 12, 2009 | Lite On (SOHC5236V) CD-RW/DVD-ROM Combo...
NEC ND-3540A DVD RW Dual Layer Burner Logo
225 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
