Question about SanDisk Sansa e250 MP3 Player
Sansa e250 2GB won't sync with my WMP 11
I just got my REFURB Sansa e250 off of Amazon 2 days ago. I'm having a problem first of all getting it added to hardware. I keep getting "Cannot add this device" And it won't sync at all with my windows media player 11. Please Help!
Did you load the cd so your computer can recognise the mp3?
Posted on Feb 11, 2008
Sansa m230 No Longer Syncs with Windows Media Player 11
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the SanDisk website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Sep 29, 2009 | SanDisk Sansa m230 MP3 Player
Hello i have a sansa clip 2gb and the music is showing up when i check the files but does not on the clip itself. it says "No song" I know i added the songs on there. can you help me?
try using windows media player to transfer the's how 1.Update WMP to version 10 or 11 2.goto sync tab and yoyc player must be detected. 3.create a playlist of songs you want to transfer on start sync to transfer music to your player.
Sep 03, 2009 | SanDisk Sansa Clip MP3 Player
I have a SANSA C250 MP3 player. Trying to sync w/ iTunes.
Put on your ipod and put them on your media player by sync. Itunes can work on the ipod so you use itunes on your ipod and get them.
Apr 06, 2009 | SanDisk Sansa e250 MP3 Player
When I try to sync my Sansa E280 to WMP 11 it shows error report.
It could be the mode you are in.
MTP mode seems to not synce with WMP.
But MSC mode works.
Go to settings>USB Mode>MSC
Should work!
Mar 21, 2009 | SanDisk Sansa E280 MP3 Player
Does not show songs that were previously synced
1. Make sure you Windows Media Player 11 (Goto Help --> About WMP --> v??) 2. If you do not have it, install it from this location:  3. Change the Mode on Device: Go into Menu --> Settings --> USB Mode:Auto Detect/MTP/MSC  4. Select MSC and it should work. If it does not try Powercycling your device (turn it off and then turn it on). 5. Try other modes as well.
Jan 24, 2009 | SanDisk Sansa m240 MP3 Player
Sansa e260 won't accept songs
Hi Janworks4u. Question for you... Did your mp3 work fine with WMP 10? I ask because WMP 11 is known for causing problems w/mp3 players. You can try reverting to WMP 10 to see if that fixes your problem. To do this:
click START, click on CONTROL PANEL, ADD OR REMOVE PROGRAMS (look at the top center of the Add or Remove Programs box that pops up for a little square you can click on that says "show updates." Click that box and then scroll down to WMP 11. Click to change/remove. A box will pop up confirming that you will revert to WMP 10. NOTE THIS WILL NOTE DELETE ANYTHING FROM YOUR COMPUTER! All of your music that is in WMP 11 will still be there in WMP 10!
Now you can try to load your songs back on through WMP 10 and hopefully it'll work for you. Good luck!
Sep 29, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e280 will only charge when connected to my computer
I'v had problems with my Sansa 280r (I think)... everything was working fine for about two years and then I recently tried adding a new playlist and everything went funny.. WMP would only see it in MCS mode and not in MTP which is the wrong way around and when I sync everything appeared to work fine until I disconnected it and there was nothing on the player. So I hooked it back up, tried sysc again but it said that all the songs were already onn the device yet it was still empty when I unhooked it.
I tried everything from uninstalling it in Device Manager to reformatting it but nothing worked... Looked for drivers on San Disk but there are none.
Anyway, I had actually given up and was looking at new MP3's on the San Disk site and I noticed a link to download WMP 11... I kinda thought I had that version already but rather than even checking, I hit the download button... My sansa has been 100% ever since... I reckon I must have lost or damaged some files or components and it was affecting how WMP was interacting with the SANSA.
If your having any problems with your Sansa, these are the steps I would try.
1) Put the device iin MCS mode (Settings/USB Mode/MCS)
2) Hook it up to your computer and double click 'My Computer'
3) The player should show up here as a drive... Right click and select 'Format' (Personally I used the long format... not sure why but it doesnt take long)
4) Disconnect the player
5) Download WMP11 and restart your PC
6) Change your USB mode on the player to MTP
7) Open WMP and connect the MP3... You should see it straight away as a new device and it will ask you to name it (Delete any old references in WMP that you used to use as this is a new "partnership" your setting up... Just right click the old name and select 'End Sync Partnership)
Hope this helps... If not you someone else somewhere... Pain teaches well !!!!!
Shay Murray
Jun 25, 2008 | SanDisk Sansa E280 MP3 Player
Can't install MTP drivers
As I like MTP mode a lot better than MSC (I can use WinAmp to sync and it doesn't have to restart and refresh its database after disconnecting) I didn't like a lot of the solutions to this and similar problems telling to go to MSC mode.
However, I was able to go into Device Manager (right click on My Computer, click Properties, select "Hardware" tab, click Device Manager) and find the Portable Devices sublist, right click on "Sansa e280" (it had a yellow exclamation point on it) and click install driver. I followed this through, selecting automatic installation for the driver, and presto! Sansa is installed and ready to go. I actually had Windows Media Player open during this process, and while it wouldn't recognize it before, after doing this process, I went back to WMP and it had already found it and was trying to get me to sync it. So if you like MTP, try this. It worked for me.
(Note: this method may not work, unless you tried to plug the player in and it told you that there was an error in setting up the device. My problem was that I had installed WMP 11, but had not done the final "setup" process. After I had run WMP 11 for the first time, I was able to do this successfully).
Feb 06, 2008 | SanDisk Sansa E280 MP3 Player
Can not view my music files on my laptop (but can on my desktop)
Get the latest firmware upgrade - this player wasn't originally designed with WMP 11 in mind. Also, make sure the laptop has the folders "My Documents" and "My Music" on it - this is primarily where WMP reads from.
Dec 06, 2007 | SanDisk Sansa c240 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
64 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
