Question about Behringer EUROPOWER EP2500 Amplifier
Behringer 3282 mixer
Reported problem: audio output on desk low, restarted and fine for 5 min then low output.
Tested: +/- 16V rails, no ripple or fade when power supply forced to run hot. resistance test on power supply cable, connector from power supply output to termination on board in console. Tested sign wave in/out on channel to outputs with O scope with no problems seen until voltage limit clip. One channel had bad fader and it was replaced.
I am going to test desk without inserts normally used to see if it is out board gear today
Any other suggestions?
  • Graeme Ross
    Graeme Ross May 11, 2010
    How did you go with the desk in test?
  • 1,512 Answers
Any luck with the test. Let me know here Id like to know how you got on.
regards
Graeme
Posted on Feb 25, 2008
Having problems connecting speakers via a power amp in to my behringer x2222 usb mixing desk - im not getting the ins and outs correct :(
I had a like problem with a crown amp. I found it was in the amp settings , nothing to do with the mixer set up. We had it a mono setting. Take a look at your amp set up book, i'll almost bet thats where the problem is
Dec 06, 2012 | Behringer Xenyx X2222USB USB Audio Mixer
Where are the Amplifier inputs on a Behringer usb 2222 mixer
If you need a better answer post again with more details. You can connect an amplifier to any of the inputs assuming it has compatible output levels. In your case I am assuming you want to connect to a power amplifier, so connect to the Main Outputs.
This mixer does not drive speakers!
Nov 10, 2012 | Behringer Xenyx 2222FX 22 Input Mixer
I have a Behringer zenyx 2442fx mixer. I was using it one day and all the LEDs started glowing brighter and brighter until the whole desk went dead. It has not worked since. I'm guessing the power...
That sounds bad! I haven't heard of a runaway supply for these... Testing of the power supply is in order. The LED's are all driven from the +15 volt supply which is secondary regulated by a three terminal regulator... probably a 7815. I have seen failures of this chip in another Behringer product so it may be a bad batch. The question now is if this has fried the main switching power supply.
Nov 02, 2011 | Behringer XENYX 2442FX Mixer
Hook up external amp to the behringer pmh3000
You can do it if the desk has unpowered outputs (maybe the TLR outs on top?)
Jun 29, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Iam trying to make my behringerXENYX 1204fx mixer, / connect
I have trouble my new behringer xenyx 1204FX VU led dead , like new VU it must play , how to repair this unit VU light
Mar 13, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
How do I connect my behringer mixer desk to
The first thing to do is to swap teh L & R INPUTS to the amplifier. Did the speaker that works change?
If som the problem is with the setting of the mixer deck. If it did not change, then the problem is with your speaker wiring of the dead speaker, the speaker itself, or that side of the amp.
If the working speaker did swap, that means problem is with the mixer. The question then becomes how are you connecting to the mixer. You should be using TRS 1/4 inch connectors or preferably XLR from the MAIN outputs. These are balanced outputs connections.
If the inputs are from one of the mono inputs, the PAN control for that channel will control how much goes to each speaker... If at center, both will get same signal.
There are so many possibilities that I can't evaluate them until you try the test to find if it is problem of the amp or the mixer that I have given you to try.
Dec 28, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Connecting an M Audio Fast Track USB to a Behringer XENYX 1002
I suppose that you connect the behringer mixer master out (just one of the two channels in case of two) to the guitar input of the Fast Track. Have you tried to hear your mic from the phones output at the front panel of the Fast Track? Try changing the guitar gain and the output level at the top of the Fast track.
I'm waiting for your results or clarification, please post.
Thanks and regards
Please kindly rate this solution
Stelios
Oct 21, 2009 | M-Audio Fast Track USB (FASTTRACK) Audio...
Mac - no output from EMI 6/2 external sound system
re install the mac drivers from mfg web sight
Aug 03, 2009 | Computers & Internet
Using m-audio fast track usb with Behringer mixer
Use the taope outs. They're the RCA plugs located in your manual as "20".
Sep 01, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
Behringer EUROPOWER EP2500 Amplifier Logo
194 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
