Question about KitchenAid KESC307 Electric Kitchen Range
KitchenAid slide in range/stove model KESC307 HWH6 DOOR LOCK PROBLEM
We purchase this unit in 2002.
After the cleaning function, a soliniod buz occurs and the door mechanism locks the door. We called the repair service, just after the warranty, who replaced the soliniod.
The message on the panel reads "F5-E7". I have since been able to open the door by sliding a butter knife through the front grate and pry up the door locking arm. In the past this has essentially reset the stove, and if function normally, except cleaning, afterwards.
It has happened again.. February 8, 2008. I pried the door locking arm up and was able to open the door. The power is now turned off and after this message I will turn it back on.
Regarding "Superglides" message earlier, has Kitchenaid corrected this mis-engineered part or assembly?
  • rattlesnakei Dec 02, 2008
    same issues, now water boiled over, went into control panel now wires are fried, out of warrenty, afraid to fix it if it shorts out so easily, always been really careful not to let it happen.....anyone else have that happen?
  • 76 Answers
SOURCE: self clean inoperative
Dear Superglide, An error code "F5 E1" means "door latch not operating". In such situation I would recomend to replace the oven lock assy (part # 9782611 ) which is located on the back panel.If you are going to do it yourself - DO NOT forget to unplug the power cord first. About service manual - try to call Kitchen Aid directly.
Posted on Dec 13, 2006
FreeTech
  • 426 Answers
SOURCE: oven door locked
unplug the oven for a few hrs, need a brand and/or model number to look up diag. codes
Posted on Jun 13, 2008
SOURCE: hey,
I had this problem once and I just reached through the vent on the front with a knife and turned the locking mechanism. I eventually had to have the range repaired for self-cleaning mode, but this should at least let you get the door open!
Posted on Jul 12, 2008
SOURCE: KGSA906PSS Kitchenaid slide in gas
The thermal switch was bad. I removed the sheet metal back from the oven and there is a small round part with two wires one on each side. You replace it and bingo the door will open and display will come back on. If you do not have he part you can touch the two wire together and the stove will unlock.
Posted on Nov 29, 2008
mastersaintx
  • 928 Answers
SOURCE: I have a KGST300 gas
As most electronic devices go you can just unplug it first for about a few mins then plug it back in.
Posted on Dec 02, 2008
F22 flashing on hot point washing machine
Google it this is not the hotpoint website .
Jan 06, 2017 | Washing Machines
VDSC4876GSSLP - Oven element wont heat . . Main oven started going in and out of "clean" mode, locking and unlocking the oven door while in use, then eventually stopped working all together. Fan and light...
If there is power to the unit (lights turn on) I would check the fuses and switches especially the one for door lock mechanism if you noticed a glitch. But a lot of times if you experiences problems after running a self-cleaning function, including locked door issue, the solution could be as simple as resetting a switch and no actual replacement parts needed. It all depends. If you are in Los Angeles, we could send a Viking repairman the same day you call us. : Viking Appliance Repair
Dec 08, 2014 | Viking 48" 6 Burner, 12" Grill Gas...
What is error dL f
Doorlock error.
F dl Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
Possible causes/procedure:
¦ Door lock mechanism is broken or removed from door.
¦ Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
I have a service manual and more HERE
Jan 29, 2011 | Kenmore Elite 45986 Front Load Washer
Fail's to start. "DL" and "F" flashes, no matter
Hi
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code. It has happened because Door lock mechanism is broken or removed from door. It may also happen due to Door switch/lock unit failure. To resolve the issue follow these steps---
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Hope this helps...Please post back if you need more information.
Daniel
Jan 10, 2011 | Kenmore Elite 45986 Front Load Washer
Washer will not start, it beeps and say's dL / F
Door Lock Error---(F/DL)
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and
• Door Lock/Switch Assembly Failure
This will essentially be the result of a failed door locking mechanism(wax motor failure). The necessary actions are to replace the entire door locking assembly. Click here to access the repair manual for your unit. This universal duet manual will guide you through the necessary testing procedure and component accessing, as well. Replacing the door locking mechanism will correct this issue.
Aug 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer says dl and then f
Potential Causes
Aug 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My display window on my washer reads F and then dL.What does this mean?What do I do?
HI. That code is in reference to the door locking mechanism. It is experiencing difficulties at this time. A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
The necessary actions are to Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU). This can be achieved by removing the top and front panel. The door assembly must be removed as well. Once you have exposed the door locking mechanism and its respective connections to the CCU, kindly, inspect each connections for a loose fit. The CCU will be located on the top of the unit, just to the rear or side of the interface panel. Check the linking connections that run to the door locking mechanism for a loose fit, as well. If all connections check out ok,simply, replace the door locking mechanism(switch assembly). This will correct the issue.
I have included a service manual for this unit. This duet service manual will guide you through the necessary disassembling process, as well as, the proper testing procedures for the door locking mechanism and CCU. The common fault here in your case will be a damaged door locking switch assembly, and replacing it will solve the problem. Click here to access your service manual.
Component accessing procedures will begin on page 4-1. The door switch assembly removal procedure will start on page 4-3. it is part of the door removal section. Follow it carefully to extract the assembly. Componet checks start on page 5-2. You can test the CCU door lock solenoids for proper ohms by referring to the ohm chart on page5-3. The CCU pin connector location is labeled on the top of page 5-1 under door lock solenoids. Due to the fact that there is a very small possibility that the CCU may be damaged, you can test the pins to verify that the CCU is indeed functioning with a good set of door lock/unlock solenoids. This will, essentially, isolate the door lock switch assembly as the lone culprit.
  • Be sure to unplug the unit before attempting this repair and use caution.
Aug 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does code F LD mean?
Long Drain. Remove the drain pump filter and clean it out.
Jul 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F1 error code, continual beeping all other oven functions work properly
Here are the error codes for Dacor:
DACOR
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 Clock pushbutton is stuck in a depressed position Check clock buttons F1 Element relay circuit failure Control board may be bad F2 Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only) Call for service F3 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F4 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F6 Failure in the EEPROM check comparison (only time of day and timer will operate) Call for service, electronic clock control is usually the cause of the problem F7 Failure of the self- clean automatic door latch system Check door latch and switch(es) F8 Failure of the door latch motor. Occurs when the motor runs for two minutes without the door locking in self-clean mode Check door lock motor and door latch
Nov 08, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
KitchenAid KESC307 Electric Kitchen Range Logo
242 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
