If so you could just disable screen savers. Alternitavly it may be a back ground task crashing. Check you dont have any wierd 3rd party software running. (if your computer is running slow it could be the same scource)
There are lots of other things it could be, but see if that helps.
Hi, if you want screen saver for your phone, you can download from your from if it has internet access or you can use a PC or laptop to download latest screen saver for your phone by using Google search and typing in top screen saver for Motorola RAZR V3x Cellular Phone.
In Windows Screen saver can be managed from Display Properties window. Follow the steps given below: When using Windows XP, right click on the open space on the Desktop then click Properties to open the "Display Properties" window. In the "Display Properties" window, click on the "ScreenSaver" tab to manage it.
When using Windows Vista, right click on the open space on the Desktop then click "Personalize" to open the "Personalization" window. Next, click on the "Screen Saver" option to open the window where you can manage settings related to screen saver.
when you plug up laptop to ur tv...on the tv u should tune to (source) vga .....on the laptop click (intel graphic media accelerator driver, this where you can share what is on the laptop with an external screen)
it sounds like you might have a bad board or memory card. If you dont hear the normal sounds from the computer as it boots up, its an internal problem.
if theres nothing happening on ur pc like same as tv its probably the tv config ...
check tv setup
check tv screen saver..if it disabled it would explain why screen black...
could try checking power settings in pc(screensaver properties)
screen saver on your computer ... xp ... right click on disktop and chose properties.... it's one of the tabs at the top
vista... right click on the desktop and chose personalize... screen saver is listed in the window that pops up
