PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
New memory not recognised when ins...
By jakewilks on Feb 10, 2008
got new memory card equivelant to memory installed, when fitted nothing happens then get message memory not recognised,
new memory:128mb SODIMM 144pin PC100
CSO8889
do i just fit it in and reboot or do i need to do anything else??
memory is standard at 128mb and is very slow
running windows millenium
Best Solution
posted on Feb 10, 2008
Helpful)
danasaur
Rank: Guru
Rating: 87%, 111 votes
"Put it in and reboot"... be sure the aptop is OFF when you add memory! Otherwise, you can damage BOTH memory and laptop! Once memory is installed there is no "trick" to get it recognized. If it is good and meets the BIOS specs, it will be recognized and registered after a cold boot.
1. Be sure the memory is inserted properly (both clips on the sides are flush with the half-moon tabs between memory and metal clips).
2. Sometimes on a memory slot that has been empty a long time (and gets a bit corroded) it is a good idea to insert the memory, remove it again and reinsert 5 or 6 times (only) to clean the contacts.
3. If number 1 and 2 have been done, and you still have this error, then there is a problem with the memory:
It may be the wrong speed (PC100 instead of PC133, etc)
It may be too LARGE for the BIOS to use (all laptops have maximum memory per slot specs that must be observed, because the laptop cannot see memory that is greater than its specified capacity.
In any case, check the manual or the website for your laptop, to get the specifications for memory type AND capacity per slot, and TOTAL memory if you have two slots -or memory soldered on board).
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
how do i restore my aspire 5735-6694
Answer
please help me to restore my synaptic (mouse),i cannot roll up and down by synaptic.Thank my e.mail... (More)
Answer
I have a HP laptop DV2000 model laptop that does not boot up sometimes: The power light comes on,... (More)
Answer
is it ok to leave the laptop plugged into the wall all the time or does that damage the battery?
Describe your PC Laptops problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
in Las Vegas, NV
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
