Question about Pioneer PDP-5060HD 50 in. Plasma Television
PLASMA DISPLAY STARTING UP. PLEASE WAIT
Flat screen plasma gets the error as follows:
Volume works but no picture. I noticed some other people had similar errors in the support troubleshooting blog with no resolution posted.
any suggesttions? Please!!
  • PioneerFan Apr 29, 2008
    Hello There, I have the same problem with my new Pioneer Elite 110FD. While watching TV via my HDTV converter box, the power sudenly turns off and the power indicator blinks several times and the gray box with a text PLASMA DISPLAY STARTING UP appears for about 15-20 seconds... Then the display is restored. My TV is just 4 weeks old and it happened to me 2x already. It's like an intermittent error where you cannot predict when it will happen again. Pioneer Plasma Tech Support is also cluecless about this error. Any help or suggestions please?
  • 5 Answers
Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was.
Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
Posted on Feb 20, 2008
Restart your tv by unplugging the tv box from the power source/wall. Also,double check that all the plugs in the back of the tv box are secure. I did this and it fixed my problem.
Posted on Apr 13, 2009
Problem with plasma display on Panasonic TH-50PH9UK television
there is an x-buffer and a y-buffer. by disconnecting these and noticing if the picture changes you will be able to identify if it is on of these boards or if it is the screen itself. Youtube also has a lot of helpful videos. hope this helps
Jan 21, 2015 | Panasonic TH-50PH9UK 50 in. Plasma...
Best plasma TV HDMI
None.All Plasma tvs designs are alway have high heat output and consume alot more A/C power energy than any other tvs designs out there.Tvs like CRT-tube tvs,DLP tvs -Projection tubes and projection lamps tvs,LCD-flourescent tubes tvs as Liquid crystal display screen tvs.All these tvs designs are all good tvs designs to buy but the pictures display and screen lighting and the sharpness of the pictures never have and able to compare high enough qualities as a display picture on the screen output to a Plasma screen tvs,until now LED-tvs are LCD and LED screen display combine to make it better and brighter technologies and now are good enough to compare to a Plasma screen panel tv.So buy a LED tv will get less heat output and comsume less A/C power energy too and it is good enough pictures qualities too.To compare too as a plasma screen panel tvs output.
Oct 28, 2011 | Televison & Video
Have pioneer pro-950 hd plasma tv. Has been working great. turned on this evening and got a display saying Plasma Display - starting up. please wait. nothing happens? can't find anything in the manual...
Tries unplug,replug both tv and cable box an hour later.Let the tv reset it self back to the factory setting.The cable box to upgrade it softwares.The tv now should,work again.
Oct 20, 2010 | Pioneer Elite PRO-950HD 42 in. Plasma...
Help with Pioneer Elite Pro-1130HD 50 inch
just wait it, because it is processing the display data
Nov 16, 2008 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Feb 10, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
Cant get picture
Jan 09, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
Screen frozen
Dec 29, 2007 | Pioneer PDP-5060HD 50 in. Plasma...
Maxent-42" HD Plasma
i havn't been able to get a tech manual yet for this unit..however...the plasma display has lost power...i would replace the X board and Y boards, including the Ysus boards(upper and lower Ysus boards.
Nov 25, 2007 | Maxent MX-42HPM20 42 in. Plasma HDTV
Pioneer PDP-5060HD 50 in. Plasma Television Logo
3,784 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
