Question about Motorola Mobility RAZR V3
Poor reception i have poor reception with background noise and a lot of static. What can I do to fix it?
  • trish1 Feb 10, 2008
    thank you but... i do have all bars on my phone. i don't think it's the signal. it also has a muffled sound.
  • 52 Answers
Go to a radio shark or to a phone store and tell them u want the Reception Booster that goes inside ur battery pack and this should improve ur Signal. :)
Posted on Feb 10, 2008
Static noise coming from the dashboard of 2005 Buick lacrossr
Automotive Recalls and Technical Service Bulletins for 2005 ...
www.alldatadiy.com > Factory Service Bulletins and Recall Titles
Automotive Recalls and Technical Service Bulletins for 2005 Buick LaCrosse V6-3.6L VIN 7. ... PIP5191 APR 14 Engine - Ticking Noise on Cold Start Up. PI1217 APR ... 03-08-44-005L APR 12 Audio - Poor Radio Reception/Static Interference.
Aug 30, 2015 | Buick Cars & Trucks
STATIC BACKGROUND NOISE
The time is the clue static in the background is electrical interference this can be caused by faulty electrical appliances UHF ham and CB Radios etc ask neighbours if and when they suffer this interference this will help to locate and identify the cause ie the closer you get the worse it'll be
Once you identify the source the culprit may decide to fix the appliance desist from operation or you can buy filters to eliminate the cause of static noise once you know the cause
Feb 02, 2018 | Apex Digital PF3230 32" TV
Static on my laptop why
The problem is in the network connection through skype, you will need to contact them to see if there is a solution or reason why the reception is so poor.
May 08, 2012 | Samsung RV510A01 T4500 23G 4GB 320GBDVD...
Poor reception when trying to get MW
Poor reception or with heavy noise aas the interference is very high on the MW. If there is no signal strength then the fault can be due to faulty RF in the radio, poor MW oscillator settings or a faulty IF settings.
Also a faulty antennae can cause poor reception and pick of stray signals.
Check for other interferances from household applicances.
Nov 07, 2011 | Car Audio & Video
Acura mdx am radio problems- terrible am reception- lots of static in 2003 acura mdx. how to fix
there is a tsb on this one..this issue is most of the time linked to poor contact ,corrosion in the wiring of the antenna, damaged or loose antenna. It is located on the rear of the roof and to access the wiring, the head liner must be pulled down.
Jul 19, 2010 | 2004 Acura MDX
Reception is very poor. Grounding issues? Please
Reception has little to do with grounding. The ground plan is for transmitting. As long as the coax is connected and is in good standing, it should receive fine regardless of grounding.
There are a few reasons you may have bad reception.
  1. Turn the RF GAIN all the way up. This is your receive sensitivity.
  2. Squelch is too high. It should only be turned up enough to cut out the background noise.
  3. Poor antenna. If the antenna is cheap, and not made well, this could be the problem.
  4. Not enough of the antenna above the vehicle. It needs to be at least 60% of the antenna above the vehicle.
Hope this helps!
Oct 21, 2009 | Cobra 29 LTD CB Radio
Poor radio reception
could be or the station you have on.in between towers you will get static.
Jul 15, 2009 | 2007 Mini Cooper S Convertible
!994 Park Avenue FM radio reception poor. AM signal OK
Check antenna connections at radio and antenna assy.. Poor connections will only receive AM and hardly any FM
Apr 06, 2009 | 1994 Buick LeSabre
Station 1450 has irregular noise when car is running; 1240=OK
If the "static" you are getting is a high pitched whine and the noise volume increases and decreases with changes in engine speed, you probably have alternator induced radio noise.
Many times such noises are caused by poor ground connections that have begun to corrode over time. First try removing or loosening the screw or bolt which grounds the radio to the vehicle frame. Using a fine wire brush or a piece of steel wool, clean off both the terminal and the location on the vehicle where it was attached. Then reattach the ground. While you are behind the dash, make sure that the antenna connection is fully seated. Pull it out and put it back in again to make sure.
If these steps do not solve the problem, you may need to install noise supression devices. The are available at many retail locations like Radio Shack and some auto parts stores, as well as numerous online stores such as: http://www.crutchfield.com and http://www.sonicelectronix.com.
Mar 24, 2009 | Elliott's Car Radio Ford-C3AA-18808-C Car...
Motorola Mobility RAZR V3 Logo
442 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
