Question about Memorex AM/FM Clock Radio with CD Player
Memorex CD Clock Radio # 2863. Broken latch .. will not hold down top cover
The latch that holds down the top cover (CD access area) will not engage when the top is pushed down (top stays open all the time). The part is a small black latch and fits in a cut out in the housing of the unit. It is a stand alone piece and it appears to be easy to replace. Can yout tell me how to obtain the part?
Please email me at time7777@aol.com
Thanks in advance for your help.
  • 4 more comments
  • Anonymous May 31, 2008
    I have the same exact problem and found on the Memorex website that they use Fox Electronics for their parts (1-800-321-6993). They have the part for $8 plus $12 in shipping. A new cd clock radio will cost more so I will probably drop the $20 on that little part. I have not been able to find anyone else that supplies the same part.
  • sriranga Nov 19, 2008
    Memorex CD /Boom box -CD lid will not latch. Stays open all the time. There is a black latch on the right corner inside.Is the part available and can I fix it myself
  • raho561 Nov 19, 2008
    I have the same proplem Memorex should look at this as Difict in there product.
  • Anonymous Dec 03, 2008
    WE own two of these CD clock radios and both, within a few months, had the same issue whereby the female end of the latch to close the lid to active the CD player broke at the main stress point, causing non-functionality of the CD player and remains open, collecting dust and other airborne debris.
    I contacted Memorex's Customer service and was highly disappointed to learn about the Fox International cost/solution. I have come to two conclusions....
    It is NOT worth the cost and Memorex is NOT worth my business in the future. The issue is clearly a product defect as they selected a polymer blend that cannot endure the less-than regular usage over the anticipated lifetime of the product. Vote with your wallet! Memorex is out; too cheap for me.
  • Anonymous Mar 07, 2009
    I have the same problem. Black latch will not keep cover shut, but does not appear broken. There was no predictive indication of this failure, it just happened. I removed the lid spring, but this did not completely solve the problem - lid stays shut, but not enough for the CD player to work without manual intervention.
  • zhenbor Apr 17, 2009
    The lid stays open. It seems that the part of the latch on the unit was not strong enough to hold the latch on the lid and split.
    I tried using super glue to glue the split sides back - without any success. I tried to use small rubber band - it keeps that lid closed for a while, but the rubber band is not strong enough.
    This was a gift to my 6yo son. I'm VERY disappointed.
Also have the same problem, clock sat on the night stand for a couple of years. Wife took into work to play CD's at the Christmas Party and the latch failed.
Think we may have used it once or twice as a CD player.
The black latch was easy to remove, justed open up the radio and pushed in the ears on the latch and it slipped back up into the CD compartment.
Will see if I can find something to repair it. Looked like the side cracked and a housing lost some of its side.
Posted on Dec 20, 2009
  • barnyrbbl72 Dec 20, 2009
    Found what matches the latch.
    Sugatsune mini touch latch P/N PR-4PK
    Even the side opening matches.
How do I set the time
To set the time on a Memorex Mi4604PBLK Clock Radio, hold down the 'set time' button first and then the 'source' button, at the same time. But you must push the buttons in that order, 'set time' and then 'source'. The time display on the front will flash between dim and bright. Use the volume dial to change the time. Time is set, and the flashing display will stop after a few seconds.
Feb 09, 2016 | Memorex MI4604PBLK Ipod/iphone mini alarm...
I just got a Memorex Digital CD Alarm Clock with no manul the modle number is MC 7101. I'm not able to set the clock or alarm. I just need the instructions.
To set the clock:
1. With the power off, press the TIME button; the time will blink.
2. Press the MINUTE button to set the present minute and the HOUR button to set the present hour.
Make sure to set the correct AM/PM setting.
3 Press the TIME button (or wait approx. 15 seconds) and the time will be set.
To set or reset alarm time:
1. With the power off, press the desired ALARM, Press and hold the desired ALARM 1 or ALARM 2 button; the alarm time will blink. The Alarm 1 or Alarm 2 time and settings will appear.
Press the MINUTE button to set the alarm.
2. Press and hold the desired ALARM 1 or ALARM 2button; the alarm time will blink.
Press the MINUTE button to set the alarm minute and the HOUR button to set the alarm hour. Make sure
to set AM/PM setting. Press the ALARM 1 or ALARM 2button again (or wait approx. 15 seconds).
3. Repeatedly press the ALARM 1 or ALARM 2 button to select alarm off, alarm on, for buzzer, radio or CD.
If you needed the manual it could be downloaded:
http://www.retrevo.com/support/Memorex-MC7101-Clock-Radios-manual/id/1081dj880/t/2/
Thanks.
gylacz
Aug 01, 2011 | Memorex MC7101 Clock Radio
I need to installl a cd player in my car and i cant get the thing that holds the radio and heater off.
You will have to remove the dash cover to gain access to that bezel piece. That bezel actually extends around the instrument cluster and and radio area, all one piece. The dash cover is held on by a series of torx screws located under the top defrost vent, side access panels (when you open the car doors, there is a panel on each side). In the glove box area and there are two 10 mm bolts that are tucked up under in the glove box area but accessible. After you remove the dash cover, you can remove the torx screws that hold the bezel in place. On the bezel down by the radio, there are spring clips that hold that part of the bezel. Remember when replacing the stock OEM radio, you will need to buy a mounting hardware kit, wiring harness kit and antenna kit for the Cavalier that will work with your new cd player.
Dec 19, 2010 | 1996 Chevrolet Cavalier
After battery ran low, now radio will not power up with power button.
Make sure you don't have the HOLD button engaged. This button is what keeps your station buttons, power, etc., from accidently switching when you bump it.
This button is found on the top right hand side of the radio if you are looking down on the radio with the clock display facing you.
If the button is showing the red painted mark, you have the HOLD button engaged. Switch it off, and then press the Power button to turn on the radio.
Sep 23, 2010 | Sony Walkman SRF-M37V AM/FM/Weather/TV...
Broken latch on my cd player
Hi, Fox International is the parts supplier for Memorex. Here is their website: http://estore.fox-international.com/memcorp.asp
Good Luck!
Feb 10, 2009 | Radio Shack (15-2147) Remote Control
Memorex digital CD alarm Clock Model MC7101
Hi - You can download the manual from the link below:
MC7101
Please update the question & let us know if the information given was useful to you - Good Luck!
Apr 15, 2008 | Memorex AM/FM Clock Radio with CD Player
Top popped off.
I just removed the cover from my wave radio. There are 3 screws that hold the top cover on. Two are exposed and in the rear of the unit and the other is under the CD player lid.
To replace the cover find the two tabs in the front on the bottom cover. Slide the top on and using a screwdriver carefully pry back the front of the top cover so that the two tabs slip by and move into place. Then open up the CD player cover and make sure the spindle fits through the hole in the top cover. Push down and replace the screws.
I didnt remove the ribbon cable so you will have to check on how to refit the connector.
Apr 07, 2008 | Bose Wave Radio
Pioneer 45wx4
I had the same problem with the "roay" dude. I did not have an "F" button. Try this...there is an "Audio" button to the top right of my display. Hold this button until the clock numbers blink. Use the up and down buttons till you get the time desired. This button will also allow you to change minutes. Thanks "scottcal" for getting me in the right direction.
Mar 16, 2008 | Pioneer DEH-245 CD Changer
Clock settings
Phaedrus De Wolf--
To set the clock on the pioneer DEH-P2900MP Detachable face radio/CD/MP3 Player, follow the following steps in order.
Press the large round knob and hold for 5+ seconds to tuen the radio "off".
Once the radio is off press and hold down the large round knob 5+ seconds to enter clock set mode. (Note: You must hold the knob down otherwise you will just turn the radio back on.)
Now choose the < or > button next to the large knob to toggle between hours and minutes. Rotate the knob to adjust the digits.
When complete press the radio/sat button @ the top right of the stereo face.
When finished, quickly press and release the large knob again to turn the radio back on.
Nov 26, 2007 | Pioneer DEH-P2900MP CD Receiver...
Memorex AM/FM Clock Radio with CD Player Logo
1,038 people viewed this question
Top Memorex Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
