Question about Whirlpool AWT5108 Top Load Washer
NOT TAKING IN WATER FOR WASH
The machine doesn't seem to be taking in any water for the wash. The water feed and hoses are ok but the machine goes through the wash cycle dry.
  • shamdue Feb 11, 2008
    washer is only filling up to 20% of capacity
    Scholar:
  • 90 Answers
Do the water valves click when you turn on the unit? Have someone test to see if the valves are getting 120vac to them when the water should be running in. Usually both valves don't fail at the same time unless the common wire to both is bad. Most problems of this nature end up in the wire connectors or timer control unit..The connectors at the valve or on the control itself. If you do have 120v at the valves then the valves themselves must be bad..only other way is if the line from the valves to the tank is plugged....highly unlikely. Let me know what you find and maybe I can help out more...
Posted on Feb 10, 2008
What is E1 error code
The E1 error code indicates a water inlet error. Do you still have your manual to test for this?
Jun 20, 2014 | Kenwood KDW243A Builtin Dishwasher
Kenmore Model 21082000 won't fill during wash cycle
Try checking the lid switch. Sometimes the switch goes bad or the stem breakes and when the lid shuts it will not activate the switch. Usually located on the right side of the dryer. When the lid closes it will allow water to.fill. Washers are easy to fix and the part is cheap. Get it from amazon dont pay the crazy price your dealer wants. Trust me, i just fixed my mothers...
Feb 16, 2013 | Kenmore Calypso
Washing machine cycle far too long
Hi Fiona.I believe the cold valve is probably faulty & is not flowing fast Its probably dribbling water in?taking forever to fill.the machine should be giving up & beeping at you if thats the case.If you have a faulty cold valve then switching to warm won't help as the hot valve will close itself off to compensate for the lack of cold water..afterall you have told the machine to fill with warm,,if it cant make warm water because of a faulty cold valve then the hot will decrease to a point where its not letting any water thru..try a hot only wash..if it goes thru wash cycle ok then good chance its cold valve problem.wow i hope that helped.
May 30, 2010 | Fisher and Paykel Washing Machines
Hoptopint wd72 - E15 and wont take water in
Hi, - fixed this myself. Problem was a blocked pipe from front of drum to pressure switch. - The machine was fooled in to thinking it had water in when it hadnt! - hence the error 15. that was also why it would not fill. - im guessing the heater blew because it was on with no water to keep it cool!
Jan 09, 2010 | Hotpoint Ultima WD72 Front Load...
Washing Mashine draw Wont Empty
check the screen on the valve where the hose connects to the washer, it may be clogged
Jul 07, 2009 | Washing Machines
Cold water into tub of wash machine
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!
Mar 05, 2009 | Kenmore Washing Machines
Cold water feed into tub seems somewhat pluged.
8. re-try.
Asko 12605 overheating the wash water
(even not taking in hot water when filling before the wash stage which seems good)
The washer fills with cold water then heats it up 3 degrees a min. Your problem does sound like a faulty thermostat. Especailly if the glass door does get hot even if it is on 85f.
May 29, 2008 | Asko Washing Machines
Whirlpool AWT5108 Top Load Washer Logo
79 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
