Question about Whirlpool LTG5243D Top Load Stacked Washer / Dryer
Out of balance
In our washer we overloaded it and now it is out of balance. We would like to know how to dissasimble the machine so we could fix it. Thanks
  • 178 Answers
Get a repair manual from http://www.repairclinic.com/
They have everythng for it. Also I replace the same part you are needing to replace. It is a black gromet that wears out over time not your fault just a common problem. If need any help let me know.
Thank you for your time
Posted on Feb 10, 2008
What does error code dc mean?
DC error code means: "Unbalanced load". It can occur if the washer:
1. is overloaded (too many clothes inserted),
2. can't balance the load within a few balance cycles,
3. has a damaged balance sensor,
4. isn't regulated properly (vibrates abnormally).
IMHO you just overloaded the washer :)
Jan 19, 2015 | Samsung Washing Machines
How do I fix a whirlpool calypso washer that cuts out after 5 seconds on the spin cycle?
Is it overloaded? Out of balance? Try no clothes and a small amount of water. It may give a clue. Depending on its age, a lightly used replacement may be close to the repair tech's charges.
Jan 13, 2015 | Whirlpool Washing Machines
GE Profile washer, tumbler out of balance?
Empty, fill with water only run through spin cycle. Replace clothes
do not overload and try to distribute clothes in an even weight pattern over the tub bottom.
Sep 04, 2014 | GE Profile WPRE6100G Top Load Washer
I overloaded my washer and now when it spins it seems to be off balance. It's really loud and inefficient in getting the water out of the clothes. I don't know anything about electronics and don't really...
You may have knocked the whole machine off balance. Is it a bit wobbly when you lean on it? If so adjust the feet to level it.
Try spinning on empty to get the drum happy again.
Dec 09, 2010 | Kenmore Elite 45986 Front Load Washer
I have overloaded the washing machine and now it is off balance and i need to know how to fix it
Kenmore top loaders are equipped with an auto-leveling system on the back two feet of the washer. Typically, what happens when the washer becomes off-balance it's a simple matter of the auto-leveler needing to be readjusted. This is a very simple process that requires no special tools. The following link explains:
http://www.fixya.com/support/r3868923-level_whirlpool_top_loading_washer
The rear auto-leveler should be periodically checked from time to time to ensure the washer maintains level. Any excessive vibration may cause the rear of the washer to become mal-adjusted. This is normal. Once the rear feet are properly leveled, make sure the front feet are adjusted so that the washer is level front-to-back and side-to-side. Use a level across the top of the washer cabinet (NOT the lid! The lid on most washers is slightly bowed.) to check.
If you have any questions, please post back and let me know. I hope you find this information helpful.
Oct 06, 2010 | Kenmore 24032\24036 Top Load Washer
Unbalanced Load Problem
you can easily inspect where the water is comming from
carefullyinspect tghe door boot
the gey thing between the door and the washer tumbler, inspect very carefully, this has a habit of ripping when the machine goes out of balance viloently
Oct 13, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a whirlpool calypso washer and it is showing an error code of C1, what does this mean and how do I fix it
CI (an "i", not a "one") and OB are related - overloaded, the washer's motor controller will draw too much current and either the average current will peak ("CA" error) or the instantaneous current will spike ("CI" error). OB - out of balance - indicates of course a load that is not balanced, or is too heavy. Wash less items and see if the problems lessen. That is what we have had to start doing, but we still can wash a BUNCH of items in this type washer!
Mar 25, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore washer flashing f71
These machines are very touchy and go out of balance easily. You may find success by unplugging the machine for 10 seconds and plugging it back in. Also consider releveling the machine. If you may have overloaded it, avoid that in the future. hope this helps!
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Balancing
This type of thing should not be required. Front load washing machines (well, topload too i guess) will balance themselves out for the spin cycle unless the machine is grossly overloaded.
Good luck.
Apr 15, 2008 | LG WM-2277HW Front Load Washer
Own a Maytag Washing Machine Model No. LAT9416AAE I overloaded with a extra large comforter. I started the cylce and went upstairs to my room leaving it unattended. My parents were down stairs With it, and...
there is a thermal overload protector in the motor. After the motor cools it should restart. There is an off balance switch that might have been tripped when pulling out the comforter or when bailing out the water. As for the belts, tip the machine back and you will see the belts underneath the washer. Very easy to change and you'll see what I mean when you see the belts. That should solve your problem. AND DON'T OVERLOAD THE WASHER AGAIN.
Feb 27, 2008 | Washing Machines
Whirlpool LTG5243D Top Load Stacked Washer / Dryer Logo
Dan Webster
Dan Webster
Sal DeAngelo
