Question about Hitachi 32LD8700 32 in. LCD Television
Hitachi 32LD8700 - TV won't turn on although has power
My Hitachi 32LD8700 seems to have developed a fault whereby the LED on the front of the TV tells me it has power (shows red - on stanby) but when I try to turn it on (LED should turn green), the LED turns green for about 3 seconds and then switches back to red??
Has anyone else come across this issue, I'm sure even where to start trying to get my tv to work?
Any help appreciated.
Thanks
  • kathrynpurdi Feb 01, 2009
    hi i have the same problem but mine turns green and stays green but doesnt do anything else i think it may be a main power board problem the trouble is the board cost as much as a tv thats if you can find 1
  • Anonymous Mar 13, 2014
    the stby led swithces from red to green when turn on the tv set
  • 579 Answers
The general problem with LCD type TV's is that the power supply fails. They are very sophisticated designs that are difficult to troubleshoot and generally best to just replace the module, but sometimes there is visible damage in some of the electrolytic capacitors (visibly bulged) and high voltage rated parts can be substituted.
Hope Ya Fix It
Posted on Feb 10, 2008
I have hitachi 32" led tv but i want to know that how can i play a dual audio movie (in hindi) form usb drive
just inser the USB into the slot, and start play. Both Hindi, Tamil, Urudu, Bengai languages will be displayed, all of then will be heard together. Will be nice to hear. Pooda Pullee...
Aug 30, 2016 | Hitachi 32LD8700 32 in. LCD Television
I have a hitachi television L32HP04U A that won't come out of standby. When switched on it the LED will light blue and then blink blue and red.
Probably you should just disable the Standby feature, though it also depends on why it's in Standby. On some TVs, it's when it's been left on and idle for a certain period of time- basically the TV will turn itself off, or go into a lower powered state. It's possible it will not come out of it because the TV could be overheated, and needs time to go back to normal. Without know the specifics as to why the Standby happens I couldn't say, and it's also hard to say what the issue is with it coming out of it.
Go into the TV Menu and find Power Options. Set Power to Normal, or Quick Start (or whatever Hitachi calls it). If this is separate from the Standby Options, then disable the Standby option on its own.
Jun 06, 2014 | Hitachi 32LD8700 32 in. LCD Television
How do I stop my channel changing.
hi i'd put your sky box to av1 and dvd player to either av2 or hdmi 1 hope it helps
regards
shaun
May 04, 2014 | Hitachi 32LD8700 32 in. LCD Television
Hitachi led TV model le24ecd05au switch on sometimes
It is with the fault to its main power supply regulator board itself. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 14, 2014 | Hitachi Televison & Video
I have a Hitachi 32
You require a new power supply board, it is a stock fault with this TV. You can obtain the part on Ebay for #36.00.
Feb 29, 2012 | Hitachi 32LD8700 32 in. LCD Television
Hitachi 32ld8700 ua no sound
Make sure you are not set to SAP mode...use mono or stereo.
Feb 03, 2012 | Hitachi 32LD8700 32 in. LCD Television
Hitachi 55in plasma TV, model 55HDS69. It will not power up from either the remote or the on/off switch on the side. The TV was used a lot, for more than 5 years. It shut off while running. The red...
Hi sir Jim!!!!
kindly check the 5 LED if there is lit lights to diagnose where the fault came from..You said the 5 led turn off for 1 -2 seconds it means no error but still won't turn on I think there sometime wrong on logic circuitry..
Try to read the voltages on highlighted words on picture of block diagram above such as vs,va,vcc,stby+5v,stby+3.3v,+5.5,+10.5 and +12v...
After that let me know the results to diagnose where the fault from..
Hope it helps...
chester..
Jan 19, 2012 | Hitachi 55HDS69 55 in. Plasma Television
I have a 32inch hitachi and was working fine turned it off and when i went to turned it on nothing happened not even the red light came on have tried changing the fuse and still nothing only had it 18...
Check ur house power outlet source?Yes.Than the tv whole power supply board it is dead,modern electronic equipments rarely have dead fuses alone or only.Tries websites like Shopjimmy.com Ebay.com to buy a whole refurbish power supply board for the replacement.
Apr 30, 2011 | Hitachi 32LD8700 32 in. LCD Television
Hitachi 32LD8700 32 in. LCD Television Logo
2,776 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
