HP, who supports this printer does not have a driver for vista. the latest driver it makes is for the Windows 2000 OS.HP, who supports this printer does not have a driver for vista. the latest driver it makes is for the Windows 2000 OS.
You can't post conmments that contain an email address.
check if you have the 32 bit vista or a 64 bit vista os. if you have the 64 bit vista on the computer try to install a 64 bit vista compatible printer driver to make it work.
When you print a test page, do all 3 colors show up? If they don't your cartridge is out of one color, or the print head for that color is cloged. When you install the printer on Vista, if you are using a USB cable, bring Vista all the way up and then plug in the USB cable. Vista should then tell you it found a new device. If it does, the Vista probley has a driver built into Vista. If it askes you if you want to use the existing drivers, say no and chose the drivers from the Vista printers.
Vista has its problems with drivers. If you can get on the internet dowlad and install the Vista drivers for the model of printer you have. Also you can go to control panel and delete this printer out and shut your computer off. Plug printer in and turn the computer on. If it is a plug and play printer the computer should find it and install. You should get a copy of the install disc. Good luck
To use it with Windows Vista, install the software for Windows Vista.
The Windows XP software for your product cannot be used under Windows Vista.
Easy-WebPrint and PhotoRecord do not support Windows Vista.
Upgrading from Windows XP to Windows Vista :
Before
upgrading your OS from Windows XP to Windows Vista, delete / uninstall
all the Windows XP software first; then, upgrade the OS to Windows
Vista and install Vista software. If you have already upgraded your computer's OS to Windows Vista :
Delete / uninstall Windows XP software before installing Windows Vista software. You can download from Driverscollection.com
Vista is a brand spanking new OS. Your printer may need updated drivers to be compatable with vista. It should otherwise install automatically as it has in past. Go to dell website, and download the most recent driver (vista compatable) from them. It wouldn't hurt to see if cahnges in manual too and download it also.
