Question about Panasonic DMR-E55 DVD Recorder
Panasonic dvd recorder
Hallo can you help when i press a button on my dvd recorder it comes up (hold) on the front display. thank you.
  • 1 more comment
  • dan180283 Feb 14, 2008
    hallo none of the buttons work at all and you can not open or shut the drawer i used to be able to leave it on for an hour then it would work but not now just always says hold. thank you for trying to help
    yes that would be very helpfull thankyou very much
  • Palmbeach
    Palmbeach May 11, 2010
    Does it do this with every button?
    Can you open and close the drawer?
    Does it say Hold with a disc in the unit or when empty?
    If you can provide me with a little more information such as whether the recorder has been ok up until now and if you have tried a variety of discs etc, I will try to help.
    Thanks...
  • 185 Answers
Hello again Dan
I repair these, but I have not seen this particular fault before.
However, you mention that you used to be able to leave it for an hour and it would then work. This means the unit was having difficulty in initialising.
There is a very common fault with this model where a power board regulator overheats and fails. This causes the machine to go into a self checking cycle. It will say "Self Check" on the display and if you leave it, the machine will often eventually work.
The regulator fails from about two years onwards, with various symptoms gradually getting worse until the unit packs up completely.
I can send you the full repair details if you want them, but you would have to be able to use a soldering iron and be confident in your own ability to disassemble and tackle a job like this. Or you may know someone who could repair it, if given the full details.
It should be an easy fix, so it would be a pity to write it off for such a fault.
Best wishes...
Posted on Feb 14, 2008
  • Palmbeach
    Palmbeach Feb 14, 2008
    Hi Dan
    As requested, repair details for the DMR E55 Self Checking cycle..
    In 99% of cases this is caused by a faulty regulator on the main power board. The power board is located on the right hand side of the unit. The regulator is IC001 which is mounted on a thin metal strip which acts as a totally inadequate heatsink. This means that this component constantly works at temperatures beyond its tolerance. Because of this it, usually lasts a couple of years and then starts causing problems. The Self Checking syndrome is typical. If the regulator burns out completely, it can take other components with it, blow fuses and scorch the circuit board.
    If you are competent in using a soldering iron with care, order an STRG 6353 regulator. These can be obtained online from a number of suppliers. Disconnect your DMR E55 from the power source and remove the lid.
    Next, remove the fixing screws from the circuit board on the right where the regulator is located. Carefully remove the multi connector on the left side of the board. Remove the screw above the power connector on the rear of the unit. The power board can now be removed from the cabinet.
    Using a small pair of wire cutters, clip all five pins from the old regulator as close the the top of the board as possible. Undo the screw securing it to the heatsink and remove the old regulator which can now be thrown away.
    Next, using your soldering iron, remove what's left of the pins from the printed board and with a solder sucker or desoldering braid, clear the holes ready to accept your new regulator. Be careful because if you overheat the print, it can lift away from the board.
    Use a little heatsink compound on the back of your new regulator, poke the pins through the circuit board and then secure it to the heatsink. I usually fit an extra heatsink on these units which helps to reduce heat and prolong the life of the new component.
    Next, resolder the 5 pins on the print side of the board. Use a magnifying glass and make sure you haven't missed anything or bridged connections in error and caused short circuits.
    The board can now be put back. This can be a little tricky but it's easy enough if you take care. Replace all the screws and carefully reconnect the multi connector.
    If you have followed this correctly, switch the unit back on, pop in a DVD and give it a try. Unless you are very unlucky, You DMR E55 will no longer repeatedly self check and will operate correctly.
    Whilst it saddens me to hear that some people would throw out a DMR E55 for such an easily repairable problem, please do not attempt this unless you are confident in your own ability.
    Finally, do check that the fan operates but remember it is temperature controlled and will not activate until it is needed. Do not assume it is faulty because you do not see it working straight away. I have repaired lots of DMR E55s and I have never found a single fan or fan control circuit to be faulty. That's not to say it can't fail.
    Kind regards
How do I get rid of all these zeros moving accross the display
This problem maybe is caused by a software bug and
can only occur if the Line-in NR is turned on in
DISPLAY > VIDEO menu before starting to
record, Unit hangs after trying to record from Line
Input to DVD
If the "OK" or the "Return" button on the
remote is pressed at this time, the unit will
hang and the front display shows scrolling
"ooo...".
Unit can be recovered by pressing the RESET
button on the front panel.
to correct it Download the improved firmware from
Panasonic Web site and update the
unit
May 13, 2013 | Panasonic DMR-EZ28K DVD Recorder
During my recent transfer to a new flat i lost my remote control for my panasonic dvd recorder type DMR EH67. I bought a universal remote control but i did not have the full functions of my lost one. In my...
You can try changing the command mode of the (genuine Panasonic) remote itself, press and hold [ ENTER/OK ] and the number [ 3 ] button together for 5 - 10 seconds, then release. Then try the remote with the unit. If it still shows DVD 3 on its display, no matter which button is pressed, reset the main unit to factory default as outlined in the user manual (assuming this model recorder has a tuner, there would be channel buttons on the front - try pressing and holding [ CH/UP ] and [ CH/DOWN ] together - for 5 - 10 seconds, until 'SETUP' appears, then release). This may or may not restore your DVD unit to the default (DVD 1) command mode. (Don't forget to reset the remote back to DVD 1 if you do reset the main unit - press and hold [ ENTER/OK ] + the number [ 1 ] button together as above).
Your new remote may be set to DVD 1 by default while your unit is DVD 3 = different remote command modes.
May 02, 2011 | Panasonic DMR-EH67EG DVD Recorder/HDD...
Panasonic DMR-ES45V - DVD recorder / VCR combo Remote not workin
My remote is not working. When I press a button, I get the following message on my unit: U12, U30, SET #, CHK REMOTE #, or RC #. What can I do to fix this? The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Jun 04, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
EVERYTHING YOU NEED IS IN MY LETTER BELOW.
1. On your remote, find the record mode button; it is near the bottom on the left side. This button sets
the recording speed for the DVR. Faster recording speeds provide higher quality recordings.
2. Look at the display on the front of the machine: it should say XP ( records 1 hour on the disc,)
SP ( 2 hours, ) LP ( 4 hours, ) or EP ( 6 hours. ) You can also set it to record 8 hours on a disc,
but the quality of the recording will be poor.
3 Press the record mode button until the screen displays the recording speed that you want.
4 Note: if the powers fails or the Machine is unplugged, the machine will automatically reset itself to
SP mode.
Apr 29, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Universal Remote says ''RC2'' for DMR-EZ27
Question (s): The remote control for my DVD recorder has stopped working. Every time I press a button, the display says "CHK REMOTE 1", "RC1" or "SET1". What is wrong? Answer/Comments: Your DVD recorder remote control can be programmed (with different codes), so it can be used with multiple Panasonic DVD players. When you press a button and the display shows [CHK REMOTE #] or [RC#] or [SET#] it means that the DVD recorder and the remote control are not set to the same code.To set the remote control code to that of the DVD recorder, press and hold [ENTER] as well as the corresponding code number on the display (1, 2 or 3) at the same time for more than 2 seconds.
Mar 14, 2009 | Panasonic DMR-EZ27K
X HOLD on player screen if button press. Panasonic DMR-ES10
My Panasonic is doing the same (displaying HOLD). Did you find out what the problem was?
Jan 20, 2009 | Panasonic DMR-ES10 DVD Recorder
DVD Recorder Screen keeps saying HOLD and not switching on
CHILD LOCK:
The Child Lock Deactivates All Buttons On The Unit & Remote Control.
To Deactivate Press & Hold (OK) & (RETURN) Simultaneously Until "X HOLD" Disappears.
Oct 28, 2008 | Panasonic DMR-EH50 DVD Recorder
Vchip was accidentaly set by guest and password was forgotten
For Panasonic:
Parental Lock Feature
Combo's, Screen will say VCR Lock Activated.
During stop or power off, hold the stop/eject button on the unit for at least seven seconds.
Combo's, Another method
With unit on and no cassette inside, hold the rec/time button on the front of unit for 7 seconds.
CTV's Lock Mode
Only the on/off button will work,the others have no effect. Press the action and power buttons at the same time on the front of the set for 10 seconds or so.
LCD TV's, Lock Mode
If customer forgot Parental Lock Code, unit must be re-initialized.
Press and hold the Volume down button on the front panel, press the OK button on the remote for 5 seconds.
DVD's Lock Mode
Setting Method
The sales demonstration lock function is set by simultaneously pressing the "POWER" button of DVD Player on the remote control unit and the "STOP" button on the main unit. ("LOCKED" is displayed when the lock function is engaged.)
Release Method
The function can be released using the same procedure as for setting. If the remote control unit is not at hand, the function can be released by using the same method as for player initialization (pressing the "PAUSE," "SKIP/SEARCH<<"and "OPEN/CLOSE" buttons simultaneously).
VHS-DVD Recorder (DMR-ES40V), Forgotten Ratings Password
From the Owners manual: Open tray, Keep Pressing Rec and Play/X 1.3 buttons on the remote for 5 or more seconds.
Another servicer found resetting to defaults worked well.
(VCR>DVD Dub) + (Open/Close) + (DVD Rec)
Bill
Apr 01, 2008 | Panasonic CT-27E13 27" TV
Panasonic dmres10 dvd recorder showing ' x hold '
This is the child lock feature, to stop unwanted use of the unit. Using your remote control, hold down 'enter' and 'return' until a message is displayed.
May 05, 2007 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-E55 DVD Recorder Logo
97 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
