Question about iLO 3200 32 in. LCD Television
Television will not operate
Black screen. normal steady red indicator, located front bottom, is now faintly blinking. Remote and / or buttons located on side of television do nothing. changed batteries, changed electric outlets, notning!
  • 579 Answers
The general problem with LCD type TV's is that the power supply fails. They are very sophisticated designs that are difficult to troubleshoot and generally best to just replace the module, but sometimes there is visible damage in some of the electrolytic capacitors (visibly bulged) and high voltage rated parts can be substituted.
Hope Ya Fix It
Posted on Feb 10, 2008
What component board on the Toshiba regza 42rv530u needs to be replaced? Where can I purchase this component online?
My advice is take it to a television repairer. It is far cheaper in the long run. Fixya is full of people who have bought every board off eBay and still don't have a television that works. Correct diagnosis is the key plus experience of that particular make or model. The course to be a television engineer is 2 years full time college course.
Jan 24, 2018 | Toshiba Televison & Video
Panasonic Plasma - turns on, but stays blank.
Your TV probably has power supply trouble.
Jan 16, 2014 | Panasonic Televison & Video
Black screen with Green letters indicating Static Mode? All buttons on the front ov TV are unresponsive? Except for OFF
Static would indicate a lock up exists.
If you had a power outage it will cause this.
UNPLUG SET FOR TEN MINUTES AND PLUG BACK IN AND SET SHOULD RETURN TO NORMAL OPERATION.
Mar 15, 2012 | Hitachi 53SDX01B 53" Rear Projection...
The small black rca universal remote lost code book and need a code for a emerson tv
Hello
There are so may RCA model remote controls with black colour. If you send the model number of your RCA remote control I will try to send the codes for Emerson. Its model number will be either on its front or back cover, or inside the battery stop lid. Anyway I hereby give you some universal remote control codes for RCA with Emerson TV. Just try them.
011, 026, 027, 028, 029, 030, 031, 032, 037, 042, 053, 064, 065, 067, 075, 076, 079
Four digit universal remote codes for RCA are:
0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162 0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Jun 23, 2011 | Televison & Video
Sony KV32FS120 Trinitron TV No picture or sound when power button on remote is turned off. Red light at front of TV blinks nine times per cycle.
Once your television blinks about 9 times then it means there is a problem somewhere most likely the lamp of the television. Another source of this problem is also a bad capacitor from either the main panel or the power panel.
If your remote turns off actually it is because there is nothing to operate on the television, so once your television starts the blinking light, the remote will not be able to operate the television, once you unplug the television and plug it back then press the power button, the remote will do the same.
Until the television is fixed is when the remote will work normally.
Take care and good luck
Dec 31, 2010 | Televison & Video
The top light of the two is flashing green/red back and forth very fast and the light on the bottom is a solid red. how do I fix this so that way it will work normally
The steady lower light indicates the unit needs a new toner cartridge, MLT-D108S. Did you previously see this light blinking or blinking rapidly? (Those indicate the toner being low.) Replace the cartridge and check for any other error lights. Turn off the machine and let it cool. Then open the front cover and pull the old toner cartridge. Open the package with the new cartridge, remove the packing tape and paper that protects the cartridge and gently shake it (avoid touching the blue or green parts of the OPC drum). Press the cartridge into the slot until it is fully seated. Close the front cover.
The green/red blinking power light is not one I'm seen before. The printer indicates a non-toner failure (open cover, no paper, LSU failure, etc.) with a steady red light.
Aug 02, 2010 | Samsung ML-2240 Laser Printer
TV blinked out and now it doesnt come on?
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Feb 26, 2009 | Akai LCT2715 27 in. LCD Television
Protron 26' t.v
Dec 30, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
Vizio L32 hdtv10a..
Dec 15, 2008 | Vizio L37 Television
Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Dec 26, 2007 | Panasonic PT-50LC13 50" Rear Projection...
iLO 3200 32 in. LCD Television Logo
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
