Question about Canon PowerShot G6 Digital Camera
Flash shot haf of face is underexpsoed maybe the flash is out of sync, whatever that means how do i fix it
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 114 Answers
Turn the button to the M position, press Menu button to go to the Rec. Menu
Then click the down button to select Flash sync and change between 1st curtain and 2nd curtain with left and right buttons.
Hit Menu key again to exit the menu
Posted on Aug 24, 2008
PS3 - Yellow/white light
It sounds like the yellow light of death (YLOD) This is usually an issue with the heat sync inside has lost a connection with the solder because of overheating. An easy fix with the proper tools. eBay sells a inexpensive kit to fix that very problem. The only tools you will need that probably won't be provided, are a Philips head screwdriver, and a heat gun. (NOT A HAIRDRYER) as they don't get hot enough. ******IMPORTANT*******MAKE SURE TO COMPLETELY CLEAN THE SURFACE AREA OF THE HEAT SYNC TO ENSURE A PROPER APPLICATION OF HEAT TRANSFER PASTE!!!!!!!********** Then again, if it's still under warranty, just send it back for a free repair. Hope this helps, good luck.
Apr 16, 2013 | Sony Playstation 3 (PS3) Console
My quantum flash is misfiring...fire a few shots, then misfire again.
I can repair it for you or try this first.
Turn power on with no camera connection.
Does it fire by itself?
PC Sync on camera, does flash fires by itself?
Dec 14, 2012 | Quantum Qflash® 5d TTL Flash
How to change time format from military to 12 hour
According to what I have read if you sync your phone with it, the docking station syncs with whatever time is on your phone...but mostly i read a bunch of reviews claiming that it only ever shows military time, but syncing the other device with it is worth a shot.
Nov 04, 2012 | Cell Phones
I have a sony a200, i want to fit an external flash for that.
The camera already has a hot shoe that will accommodate a Sony flash unit or a third-party flash unit designed for Sony cameras. You don't need anything else (other than the camera and the flash unit, of course).
Mar 01, 2012 | Sony Alpha DSLR-A200 Digital Camera
I just bought a Sony Cyber-shot DSC-W530, can I force the Flash?
if by forcing it you mean by making it use the flash on every shot you take just make sure you have the flash set to on. you might have alot of different options to choose from like night portrait or whatever. try and see if turning it to plain on helps. if not please clarify what you mean by force.
Aug 23, 2011 | Cameras
My Canon 550d is new and right out of the box on full auto indoor pics are dark. If I go to no flash mode they are much brighter. It's like the flash is out of sync. Is it the camera or me?
the flash only covers a certain range and the built in flash has quite a small range. so lets say its dark in the room and you take a shot of a person they probably look really bright but the background is pretty dark, thats pretty normal and its better not to use flash, now in the auto mode without flash it will be using a higher "ISO" number to get you brighter shots indoors. shots may look slightly grainer but it means its brighter and the 550d handles low light pretty well.
in auto mode you have no control over the ISO but put the camera into P mode which is basically auto but with access to more controls which you can override. now next to the shutter button there is an "ISO"button. experiment with the different numbered setting (100 being low 3200 being high) and you will see what I mean
Oct 14, 2010 | Canon EOS 550D Rebel T2i Digital Camera
How can you test a camera before use to be sure the flash sync is working properly.
Set camera up and aim at a blank wall. Place flash on camera, fire off test shots with camera set to flash sync speed and lens set to wide angle (eg 18 mm), ensure flash matches angle of lens.
You will probably have to turn auto focus off, so that camera will fire, after taking photo/s use review to ensure that you have a nice even coloured piece of wall.
Any problems either with camera sync problems or flash coverage will show up in the test shots.
Camera sync, will show as part of the frame only exposed, for example you may find a horizontal line approximately 1/3 to 1/2 of frame with a proportion of the frame dark.
If you have flash "drop off" you will find the corners of your frame will be dark, you need to ensure that your flash angle specified on the flash and the focal length of the lens match.
Hope this helps Ian
Jul 21, 2009 | Cameras
Rockband Guitar won't sync
try syncing up one remote so it logs in as player #1 and then press the button to sync the guitar and it should sync up as player #2
Dec 26, 2008 | Nintendo Rock Band for Wii
Canon PowerShot G6 Digital Camera Logo
55 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
