When I try to boot up all I get is a loud 'beeping' sound and the black screen displays "Code 0210 Stuck Key 35". Questions: how do I locate key #35 on the keyboard and what can I try to fix the problem?
Many thanks for your help.
With the pc off. run your fingers over all the keys a few times. make sure you hit all keys and then try booting again.
Goto the device manager and uninstall the keyboard and restart the system. check that the error is still coming..
If still the error remain same ...shutdown the system and power off and just clap the each and every key of the keyboard to release the keys if any stuck. Check that error by rebooting the system. Hope that the problem is solved.
If still not then maybe the keyboard is going bad.
Cheers - Parveen
Sounds like one of two things...
1. Somebody spilled somthing or got some sticky junk in there and one of the keys is semi gummy.
2. The machine got banged around once too many times and one of the connections is slightly ajar.
So basically it sounds like it's hardware and not software, so you'll probably have to pull it apart yourself, or else take it to someone
Loud beeping and error code 0210 stuck key 35
Erroe: 0210 :Stuck key 41. Screen is mostly blotchy now, with a small area @ top right that I can see error message. Have checked All Keys & blown with an air hose. Have pressed FI,which takes me to Boot Priority 1: PCI LAN. Can't see anything further. HELP
