Question about Canon PowerShot A75 Digital Camera
Taking a picture
When I push the button to take the picture I get 1/60 F2.8 code on the bottom of the screen. Then it will not allow me to take the picture at all.
  • kamanji Apr 07, 2008
    1. shutter does not work when button is depressed. 2. can not foward the film. handle is stuck.
  • 983 Answers
It is 1/60 mode change it...
1/60 mode means it will take a scene 1/60 of the seconds....
change the mode and then try... your problem will be solved...
change to normal mode...
there are many modes available in ur cam just like 1/80 etc & so it means it will take 1 photo for 60 seconds i think i dnt know exactly but by changing this mode to normal mode you problem will be solved...
by using this 1/60 mode v can clearly see in the photo the dirt and grit also.....
Posted on Feb 10, 2008
  • 2 more comments
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Feb 10, 2008
    some extra details
    Portrait
    Use this mode when you want the subject
    to appear sharp and the background to blur.
    Landscape
    Use this mode to shoot expansive landscape
    scenes.
    Night
    Scene
    Use this mode to capture human subjects
    against the backdrop of an evening sky or night scene. The
    people are illuminated with light from the flash while the
    backdrop is captured at a slow shutter speed so that both
    appear correctly exposed.
    Fast Shutter Speed
    Use this mode to shoot fast moving objects.
    Slow
    Shutter Speed
    Use this mode to shoot moving objects
    to make them appear blurred such as river rapids.
    Stitch
    Assist
    Use this mode to shoot a series of overlapping
    frames for merging (stitching) into a large panoramic image
    using a computer.
    Movie
    Use this mode to shoot movie frames.
    Mode
    [320]
    [160]
    Resolution
    320 x 240
    pixels
    160 x 120
    pixels
    Frames*
    Approximately
    15 frames/ second
    The maximum length of individual movie
    clips is about 3 minutes.
    Format
    AVI
    Image data :
    Motion JPEG
    Audio data :
    WAVE (monaural)
    Program
    AE
    Use the program AE mode to have the camera
    automatically set the shutter speed and aperture value to
    match the brightness of the scene.
    Shutter
    Speed-Priority AE
    When you set the shutter speed in the
    shutter speed-priority AE mode, the camera automatically
    selects an aperture setting to match the brightness.
    Faster shutter speeds allow you to catch an instantaneous
    image of a moving subject while slower speeds create
    a flowing effect and allow you to shoot without a flash
    in dark areas.
    Select
    a speed using
    or
    on the multicontroller.
    The aperture value and shutter speed
    change according to the zoom state as follows.
    Zoom State
    Aperture
    Shutter
    Speed (seconds)
    Wide
    Angle
    F2.8 - F3.5
    ~ 1/1000
    F4.0 - F8.0
    ~ 1/1500
    Telephoto
    F4.9 - F6.3
    ~ 1/1000
    F7.1 - F8.0
    ~ 1/1500
    The range of selectable shutter
    speed is from 15 to 1/1500 second.
    If the aperture value shows in red
    on the LCD monitor, the image is under-or overexposed
    (insufficient light). Adjust the shutter speed using
    the multicontroller until the aperture value display
    turns to white.
    This camera applies special processing
    to images shot at shutter speeds slower than 1.3 seconds
    to eliminate the noise.
    Aperture-Priority AE
    When you set the aperture in the aperture-priority AE mode, the camera automatically selects a shutter speed to match the brightness. Selecting a lower aperture value (opening the aperture) allows you to fade the background and create a beautiful portrait. A higher aperture value (closing it) brings the entire range from foreground to background into focus. The larger the aperture value, the greater the range of the image brought into clear focus.
    Select a value using or on the multicontroller.
    The aperture value and shutter speed change according to the zoom state as follows.
    Zoom State Aperture Shutter Speed (seconds)
    Wide Angle F2.8 - F3.5 ~ 1/1000
    F4.0 - F8.0 ~ 1/1500
    Telephoto F4.9 - F6.3 ~ 1/1000
    F7.1 - F8.0 ~ 1/1500
    If the shutter speed shows in red on the LCD monitor, the image is under-or overexposed (insufficient light). Adjust the aperture value using the multicontroller until the shutter speed display turns to white.
    In this mode, the shutter speed with synchronized flash is 1/60 second to 1/250 second.
    Manual Exposure
    You can manually set the shutter speed and aperture to achieve a particular effect.
    Select a shutter speed using or , an aperture setting using or on the multicontroller.
What does it mean when theres a picture of a key on the bottom left screen
  • If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired.
  • If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels.
  • If you have a GT2011J or GT2011S Television, hold the (Display) button for 10 seconds, it will unlock the screen. If password or code is requested, try 3308 or 6688.
  • Nov 26, 2012 | Apex Digital Televison & Video
    My Torch 9800 camera has a black screen, but the icons at the bottom of the screen are there. It will not take pictures and then also tends to freeze.
    This is not a solution, but helps to get the camera functional:
    1. Push the dots/BB button. Set Autofocus to "Single Shot".
    2. Go to Scene Modes, some people recommend selecting "Face Detection", but I find "Auto" also works well.
    3. Under Options - Select Select Picture Review to "Off".
    My Torch (9800) now at least have a functional camera with reasonable pictures, as long as I hold the camera steady for taking pics.
    Jan 17, 2011 | RIM BlackBerry Torch Cell Phone
    Time betwween taking picture and actual shutter actuation to slow
    Push the button half-way and allow the camera to focus before pressing the rest of the way. By pre-focussing, you can wait for just the right moment before pressing the rest of the way.
    Dec 06, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
    Part of the picture is being cut off, how do i
    Just called Sony about this same problem...taking your CABLE BOX remote, push the # key on the bottom right of the remote (it also says HD Zoom on mine). You can cycle through 4 or 5 zoom options...make sure you are on an HD channel to see the changes. :)
    Nov 27, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
    No picture/ power button flashes twice constantly. 2 flash code?
    Sorry, but there is no simple answer to your problem.
    Bottom line, it needs to be repaired by a qualified technician.
    The blinking is a code for what circuit area of the set called for the shutdown.
    No matter what it is, there is nothing more you can do.
    www.mcveyelectronics.com
    May 03, 2009 | Philips 50P8341 50" Rear Projection...
    Broken button for taking pictures
    You need to replace Switch Control Block as shown in below picture.
    Let me know color of your camera cabinet to provide you part number info..
    Dec 12, 2008 | Sony Cybershot DSC-T200 Digital Camera
    CANON POWERSHOT S2 IS 5 MEGA PIXELS
    I bought mine 2 1/2 yrs ago too. Found this solution on this site and tried it. It worked perfectly.
    Turn to TV mode, set the exposure to 15 seconds by pushing the little "arrow dial" until you have 15"
    Push the button to take the picture.
    Wait 7 seconds from when you push the button, then turn over and open the battery door while it is "taking the picture."
    Close the battery door and turn back on.
    I did this three times and the last time, it worked and the iris became unstuck.
    Then I took a million pictures to get the iris moving.
    Jul 11, 2008 | Canon PowerShot S2 IS Digital Camera
    LCD - Focus
    DSLR camera was not made to be used as a point and shoot camera and you cant preview the shot before taking a picture. You are to use the eye piece to focus right. Also before taking a picture, push the exposure button just a little to let the camera focus right.
    Jul 04, 2008 | Sony Alpha DSLR-A100 Digital Camera
    Flash for Coolpix L6 Digital
    You can try to reset all of the internal settings. This has worked for me with a digital camera.
    It would be good here to know what kind of camera we are working with.
    Make sure you do not have any of the settings in the camera set to turn off the flash...for instance setting it at mountains or most any outside setting may not allow the flash to work. Some cameras will allow you to override the setting internally.
    If the flash does not work at all, then repairs will be needed.
    Dec 18, 2007 | Nikon COOLPIX L3 Digital Camera
    Xd ! picture error
    I'm having the same problem with mine. I'm trying some data recovery programs right now. PhotoSalvage works great for Macs.
    Sep 04, 2007 | Olympus FE-230 Digital Camera
    Canon PowerShot A75 Digital Camera Logo
    195 people viewed this question
    Top Canon Cameras Experts
    TC CAMERA REPAIR.Com...
    old marine
    old marine
    Are you a Canon Camera Expert? Answer questions, earn points and help others
