Question about Logitech Pocket Digital Digital Camera
Logitech pocket digital camera
Battery wont charge camera wont work even though it shows fully charged.
  • 4 more comments
  • Anonymous Mar 28, 2008
    same
  • KOAUNG Jul 13, 2008
    battery won't charge
  • herlbert moreno Aug 04, 2008
    no file
    no file
  • jad6007 Sep 15, 2008
    Yep, same for me. I just happen to run across this nifty little camera that was siting in a drawer and I can really put it to use. However, how does the battery seem to charge. And where is the battery? When I plug the camera into my computer via the cord it came with, I see that the battery appears in the frame as to maybe it is charging???? Not sure as I just attempted this.
  • Ann McCartney Nov 05, 2008
    :( Why is this happening. It used to work 2 yrs ago! Now it's not..
    It just says "PC" when it's connected, then when it's DC, it shows low bat.
Same happening to me. The solution is to try it in a different USB port, as it is a USB related issue.
Posted on Jul 21, 2008
Even after my olympus mini digital battery is fully charged it doesn't work for long
This is probably because the battery has been worn down after many charges or because it has been over-charged.
When charging devices with batteries you have to make sure that you don't over-charge them.
It happens though, batteries do degrade over time and the amount of charge it holds becomes lower.
The only solution I can think of is changing the battery or buying a new camera.
Hope this helps.
Mar 05, 2011 | Olympus Stylus Verve / ?-mini Digital...
Won't turn on!
Had that problem too in October (during vacation in Sardinia); had to return the camera to Canon for repair. They noted a change of circuit ...
It 's now fully operational again
Aug 02, 2009 | Canon IXUS 960 IS Digital Camera
Camera won't work. Only shows Change Batteries,even with new ones
akaline batteries wont work
only rechargable FULLY CHARGED
if that doesnt work clean battery terminal
Apr 28, 2009 | Canon PowerShot A470 Digital Camera
Camera won't turn on.
Make sure the battery contacts are clean. The rechargable batteries looses their charge even when they are not in use. It is important to fully charge the first time the rechargable batteries.
Dec 14, 2008 | HP Photosmart R707 Digital Camera
I have Canon power shot S2 IS digital camera.I bought it around 2 years back.Now my camera is showing the sign of "change the batteries" even though the batteries are fully charged and the lens does not...
i suggest replacing a fresh battery will most likely solve your prob, overtime rechargeable battery can drain easily, try changing with a new battery and see if it does work well, there might be insufficient current, thats why it tends to drop of voltage easily upon using,
there is a specified lifetime for rechargeable battery, depends on your usage and charging method, theymaybe fully charged but sometimes wont give you enough power to drive
cheers
Nov 26, 2008 | Canon PowerShot A540 Digital Camera
Battery charge indicator seems faulty.
Solved own problem. Bad conection between pcb and battery contact pins. Reheat each battery pin on the pcb carefully until solder reflow occurs then remove heat. PDA now repaired
Aug 03, 2008 | Fujitsu Pocket Loox 410 Pocket PC
It wont work!
if it said fully charge its probably not yet.
could it be that you damage your camera in the first time that it was jammed?
Jun 22, 2008 | Fuji FinePix Z100fd Digital Camera
Even though the battery fully charges the camera, and it works.--The camera's battery dies out really fast.
Call tech support and tell them that you are having trouble with your battery and they will probably replace it for you free of charge.
Feb 18, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Wont turn on
Possible failed battery showing fully charged but actually not -or even charger.No reset] Disconnect from the wall socket- re connect and tell us if the battery is now charging. If show full- replace battery. Also tell Sony customer support
Jul 31, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
Logitech Pocket Digital Digital Camera Logo
492 people viewed this question
Top Logitech Cameras Experts
Are you a Logitech Camera Expert? Answer questions, earn points and help others
