Question about Curtis-Mathis CM27101S TV
White screen say heat run after a power failure
Power was flickering on and off, now the tv has a white screen with the words heat run acoss it, no sound, but has a faint picture an the input 1 with the dvd player
  • 654764 Feb 10, 2008
    tv was going on and off, have unplugged for a while and plugged in again, but when i hit the menu screen all that shows up and looks good, how do you reset i have no manual
    tv was going on and off have unplugged, can rewad the menu screen just fine,how do you reset i have no manual this is a cm27101s
    serial gt17df1136
    Scholar:
  • 90 Answers
Was it the house power flickering or the tv poping off and on? If the house power you may have damage in the tv. Try unplugging it for 20 minutes and the plugging it back in. May need to be reset......If this doesn't help, it will need to go to the shop.....
Posted on Feb 10, 2008
  • Timothy Smith Feb 10, 2008
    If you get a menu screen and it looks as it should, you may need to go into antenna setup and select either cable or outdoor antenna, and have it scan for all channels. I am not familiar with this tv, just tvs in general,
Thin white horizontal line in the center of the screen when the tv is on.
Hi Tim,
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
If your TV, flatscreen, or monitor is more than 5 years old it is more like to have suffered a component failure.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
May 22, 2015 | Emerson Televison & Video
Samsung 32d403 white screen, no picture
- Flickering screen
- Dim screen
- Slow start
Apr 21, 2014 | Televison & Video
Tv problem troubleshooting screen all white no picture
- Flickering screen
- Dim screen
- Slow start
Apr 08, 2014 | LG Televison & Video
White line across screen
- Flickering screen
- Dim screen
- Slow start
Apr 05, 2014 | Sony 46 KDL46EX523 LCD TV
Tv powers on, see three birds in color then flickers and fades to white
The problem must be with its main digital processor board. It will be best to make it confirm. Contact any service technician. Try this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
May 20, 2013 | ViewSonic N1930W 19 in. LCD TV
White and purple flickering vertical lines. No image or sound.
I Hope this helps!
Sony has extended the Warranty for people experiencing picture anomalies due to LCD Panel failure through October 31, 2012.
See here:
http://esupport.sony.com/US/perl/news-item.pl?news_id=378&template_id=1
IF YOU FOUND MY SOLUTION HELPFUL PLEASE VOTE 4 THUMBS UP.
(any less hurts our averages)
Thank and Good Luck!
Jan 04, 2010 | Sony KDL-46XBR4 46 in. LCD Television
Upper half of screen is flickering. Started last night. Appears to heat up and flicker. When I shut the TV down and let it cool off, flicker stops, but then starts again after the TV is on for a while. ...
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 16, 2009 | Gateway XHD3000 LCD TV
Ghosting, Flickering, Green Sparkeling Lines, Color Washout.
There is a component failure on the board inside the display. Since you did not post the model number that is all that I can tell you.
Mar 17, 2017 | LG Studioworks 700B (White) 17 in.CRT...
Flickering white cloudy screen. Can still make out picture barely.
Based on your general description, it could be:
1. loose connection or cold solder on any of the connectors and/or boards specially those related to power;
2. heat related - at some point, the heat generated inside the unit could cause a component failure or worsen a cold solder/loose connection;
3. a component is about to fail - on most Samsung projection TVs, this would be the DM board. Exhibited symptoms would be screen flickers (white flashes) and in some instances after about a minute the screen gragually turns very very bright (almost white) from the bottom of the screen to the top.
Any of the above would require familiarity with electronic circuitry and components, use of a DVM and a soldering iron as well as access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable venturing into a DIY, perhaps your best bet would be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 15, 2008 | Samsung Televison & Video
Samsung DLP 42" flickering green screen
Just unplug and plug back in. Worked for me.
Try it a few times.
May not work for everyone.
Apr 21, 2008 | Samsung HL-R4667W Rear Projection...
Curtis-Mathis CM27101S TV Logo
164 people viewed this question
Top Curtis-Mathis Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Curtis-Mathis Televison and Video Expert? Answer questions, earn points and help others
