Question about Alienware PC Systems ALIENWARE 5620D Notebook
Alienware backlight problems
How to change backlight cable
If your computer is running kind of sluggish, you can fix it with an easy clean up of your registry. Here's a link to a free scan that works well:
www.your-free-info.com/RegCure
I've used this one and it sped up my computer by quite a bit. Hopefully this helps.
Posted on May 11, 2008
    Scholar:
  • 163 Answers
Cable change needs you have to Pull the Bulb or CCFL from the bottome of the screen internal.. What size screen? Some are easy some are not. Also if you have not diagnosed try inverter first. Many make this assumption and are wrong initially.
Posted on Feb 10, 2008
How to install Alienware Drivers?
Get drivers and downloads for your Dell Alienware. Get in touch via toll-free number 1-800-204-4427, Dell Alienware technical support number 1 (800) 204-4427 for Alienware laptop series 14,17,18 to fix Alienware PC,Desktop gaming issue by http://www.delltechnicalsupportphonenumbers.com/dell-alienware-support
Jun 23, 2017 | Dell Computers & Internet
Turning off keyboard backlight
First of all, did they worked before?
If yes, then it means your Alienware maybe went into a power saving mode because the adapter you're using doesn't provide enough energy.
If the lights didn't worked before, then you should install all the necessary drivers and the Alienware OSD Application and Alienware Command Center.
If you have all the applications and drivers installed, then you should configure the lights in the Alienware Command Center.
Here are the official links for drivers and resources:
Alienware M17X Drivers:
http://www.dell.com/support/troubleshooting/us/en/19/Product/alienware-m17x
or
Alienware M17X R2
http://www.dell.com/support/troubleshooting/us/en/19/Product/alienware-m17x-r2
Jun 13, 2013 | Alienware PC Systems Computers & Internet
My Alienware M11X R2's screen broke completely off. I thought I could just hook up an HDMI cable and use the base with a monitor but it keeps beeping... and the video wont show up on the monitor.
Do you mean that the hinges broke and the screen is no longer attached to the laptop. I googled ' Alienware M11X R2 screen' and one of the first results is a story from PC World which contains:
"Dell will repair broken hinges on any Alienware M11x system for any R1 or R2 customer worldwide regardless of warranty status," wrote Dell's John Blain, in a blog entry on the company's website.
Sep 14, 2012 | Alienware PC Systems Alienware Aurora High...
Alienware m14x battery won't charge
Remove main battery, get a stiff toothbrush and clean battery terminal in laptop and prongs on batteries. Install battery and charge, if no change! rechargeable battery needs to be replaced.
Mar 22, 2012 | Dell Alienware M14x Notebook
Alienware Area-51 7500 R5 BIOS AHCI problem
I changed mine by hitting F12 at boot screen. that brings up a menu where you can change boot methods
Jul 09, 2010 | Alienware PC Systems Alienware Area-51®...
The montor doesn't come on and shows no connection on the monitor screen
check the pins on the monitor cable my be some are broken
and also check your VGA card it may not be good and need to be changed
May 11, 2009 | Alienware PC Systems Alienware Aurora High...
Laptop screen will not light up
It sounds like the inverter for the backlight has died.
They are about $100, unless you shop eBay. I just found one for my sister's AlienWare D9T for $36 with shipping.
The little rubber buttons around the screen must come off, they are just stuck on with sticky-stuff, but they are tenacious. Underneath there are small philips-head screws, you'll need to get a small set if you haven't already.
Then after the screws are out around the bezel (that's what the plastic around the screen is called) you'll have to carefully pop it off. There are several tabs around the edges, be careful not to break the tabs or the bezel. Be patient.
At the bottom of the screen, there is a narrow board with LEDs and buttons on it, and the large lump is the transformer used in the inverter to create the high-voltage AC required by the backlight tubes. There will be one or two small philips-head screws holding it in.
That is the board you'll need to replace. A big, big caution: on my sister's AlienWare, the connectors on the cables are really horrible. The plastic is crumbling, they are -very- difficult to remove without falling apart. If you break them, it is a -lot- more complex replacing those cables. Once you have to open the main part of a laptop, it starts reminding me of the puzzlebox in "Hellraiser".
I hope this helps, Steve Greenfield
Electronic Engineering Technician student
Electronic Technician 20+ years
CET Computers and Consumer Electronics
IPC-A-610D CIS Specialist
Sep 25, 2008 | Computers & Internet
Computers & Internet Logo
473 people viewed this question
Top Alienware PC Systems Computers & Internet Experts
Larry Chandler
ddalecki
Rochell Cruz
Are you an Alienware PC Systems Computer and Internet Expert? Answer questions, earn points and help others
