Question about Frigidaire FDE336RE Dryer
Dryer heating dryer heats sometimes and sometimes it wont.....any advice?
  • johnny39553 Mar 31, 2009
    thanks, it was the heat element
  • 734 Answers
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
The dryer runs but dont heat up i changed the heating coil but it still wont heat up need advice
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Mar 17, 2011 | Dryers
Dryer wont trun off wont heat at all
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 05, 2011 | Dryers
Dryer wont heat up just spins keeps spinning with timer set. replaced heat element and still wont dry
heatman101
l;
Jan 03, 2011 | Roper RGX4634KQ Gas Dryer
Dryer works but heat is gone. Any advice?
heatman101
Oct 14, 2010 | Maytag Neptune MAH5500B Front Load Washer
Dryer heats sometime other time wont heat
heatman101
Sep 26, 2010 | Maytag Dryers
My amana dryer wont put out heat. I've taken the heating element off but it doesnt look broken anywhere. I changed the fuse on the element 2 months ago because it wasn't putting out heat
heatman101
May 21, 2010 | Kenmore 62602 Electric Dryer
No heat in dryer
What you have is probably some intermittant gas coils. they get hot and quit. later they cool down and work a little more. I have the pictures and advice right HERE
NOTE: here is ever more WISDOM
Apr 09, 2009 | Whirlpool LGB6300 Gas Dryer
Ge dryer not heating
Most likely problem is burnt out heater coils
Feb 02, 2009 | GE DVLR223 Dryers
Dryers Logo
79 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
