Question about Sanyo HT32546A 32 in. Television
Hello Makes a humming sound
    Problem Solver:
  • 3 Answers
Turn it off count to 10 and then turn it back on
Posted on May 25, 2008
HELLO, I HAVE ESTATE WASHER MACHINE, ETW4300TQO, IT WILL FILL BUT THEN IT MAKES A HUM SOUND AND SHUTS OFF COMPLETELY
You will need to pull the drain pump and look for an article of clothing hung up in there.
Dec 03, 2012 | Washing Machines
I have a washer LSQ8543JQ1. When I try to run it it makes a humming noise. I thinh it is the timer, motor or the gear. Is there any way of pinpointing the bad part?
Hello
Sounds like the coupling is broken .The humming you hear is the motor running nicely with no load.
$20 part and easy to install.Part# 3364003 Sears.Have to take front of cabinet off.
If the hum is really loud the motor is probably shot. To confirm Let it hum for a minute.If motor is bad it will cut out on overload or might blow fuse..
Good Luck
Jul 26, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My Whirlpool Estate TAWL600W will not drain, agitate or spin. Instead it makes a humming sound like a motor under heavy load. Is this a gearcase or motor problem?
hello it sound like the brushes on the motor 2 plastic blocks either side of the motor just replace them they just slide out hope it helps
regards
shaun
Jan 28, 2011 | Whirlpool Washing Machines
It doesn't empty the water out of the bottom. It makes a humming sound.
Hello- The water is pumped out by a separate drain motor. If it's humming, it is either stuck or worn out. Part is about 70$. Bosch techs are hard to come by, so ask around. Let me know if this info helps- have more if needed. Thanks- ED
Mar 07, 2010 | Bosch Evolution 500 SHE45M05UC Stainless...
Maxtor 3100 80GB External Hardrive clicking/humming sound.
This could be an issue with the circuit board.I am facing a similar problem & shown it for repairing. And facing issue in sourcing the IC. Seagate is giving support for maxtor after it has taken over. Data recovery is possible only if the circuit is working.
Jan 10, 2010 | Maxtor Personal Storage 3100 (M01B080) 80...
LEA30AW makes a humming sound when i hit start,
motor is most likely bad shorting out in the windings
Jun 26, 2009 | Amana NDE2335AY Electric Dryer
My 1997 Jimmy 4x4 makes noise like a really loud humming sound when I am turning left or right, what could that be?
HELLO. IT SOUND'S LIKE IT COULD BE YOUR POWER STEERING . IT COULD BE THAT YOU LOW ON FULID CHECK IT. OR YOUR BELT COULD BE LOSE.? OR IT COULD BE GOING OUT AL TOGETHER. WELL HOPE THIS HELP'S YOU GOOD LUCK
Jun 06, 2009 | 2000 GMC Jimmy
Left front speaker works the rest dont and the sub makes a hum
Either you have it configured incorrectly this time around, or the settings are defaulted back to original on your DVR........ adjust your DVR sound properties/settings. and check all wires/connections as well.
Apr 20, 2009 | Creative Labs Gigaworks S750 Computer...
Tv makes humming noise when on. how can I eliminate or reduce the nose?
Some of the larger TV's are DISH ready, meaning that they have the tuner inside for SAT TV. The SAT tuners often have an internal fan that makes a humming noise. If it sounds like something other than that, you might have a bad component in your sound circuit that allows 60 HZ hum through the speakers.
If it is a rear projection LCG TV it has a fan in it to cool the bulb. You will hear the fan if you listen closely. It usually cannot be heard over the volume.
The fluorescent bulb and electronics inside make humming sound naturally. Kinda like when you turn on a lamp, and some lamps make a low humming sound.
Apr 03, 2008 | Televison & Video
Humming Sound
Hello, that is actually happening when the light that is on in the keypad. When its lit up, u will hear a slight humm. Its known as the keypad hiss amongst people in the know. That is the part that motorola used that makes the sound. its a very common thing. It was the first time motorola used that type of LED in the keypad flex. Hope that helps. Only way around it is to turn off the keypad light.
Jan 23, 2008 | Motorola Mobility RAZR V3
Sanyo HT32546A 32 in. Television Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
