Question about Neff W5340X0 Washer
Neff washing machine W5320
Hi, Can anybody help me as to why my washing machine has suddenly started to take over 2 1/2 hours to complete a washing cycle? I have tried other programmes and they all seem to be taking alot longer than usual to complete! Many thanks in advance.
  • Grezza Apr 08, 2008
    I also have a Neff washing Machine W5320- and its recently been taking 2 1/2 to 3 hours on all its cycles. (ie 30,40,60 degree etc). I programmed it to do a 90 degree wash with nothing in the machine- and this seemed to work, but only for 3 or 4 washes, then it went back to the 3 hour wash! Can anybody help with this?
  • brownrlah Jan 24, 2009
    Neff washing machine. The time on the clock for coloured wash at any tempaerature has suddenly almost doubled.
    Scholar:
  • 90 Answers
What is the temp of the water coming in to the unit. If it is not hot enough some machines heat the water up to a prescribed temp before washing, rinsing etc..... Could be a problem with the sensor too...let me know,
Posted on Feb 10, 2008
V4380X0GB/13
Try Googling (Neff)(V4380X0GB/13)(manual) without parens or contact Neff directly to request the manual.
Jun 07, 2017 | Neff Washing Machines
I have a Neff integrated washer/dryer. The machine seems to turn on and take in water but doesn't start to spin. It sit's for half an hour making clicking noises then will start spinning and finish the...
Assuming that it pumps out okay then could be the motor.....Check belt is okay not fallen off , next motor brushes, they wear out after around 6 yrs ,
Apr 01, 2011 | Neff W4380X1 Front Load Washer
Machine washing cycle is out of sync, it doesn't empty and it seems to wash for hours but the water is cold and it doesn't complete the washing cycle. I have a NEFF S9151F
SOUNDS LIKE THE HEATER IS BAD ITS TRYING TO RAISE THE TEMP OF THE WATER IT WILL STAY IN THAT CYCLE UNTILL IT DOES
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Feb 24, 2010 | Dishwashers
Neff washing machine not spinning
sounds like motor brushes have worn out will need to remove motor to replace they are inexpensive.the clicking is the relay telling motor to rotate clockwise or anticlockwise.
May 30, 2009 | Neff W4380X1 Front Load Washer
Neff S5433 Dishwasher - Detergent tablet not dissolving
Hi!
Please run the machine without detergent for 2-3 washes. Also try using a little hot water. Also, don't used cleaner and softener together but add softener on the last rinse.
Feb 22, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Neff Dishwasher
The offending parts are on the left hand side of the machine (viewed from the front). You need to remove a screw (or two?) at the back top edge of the side panel which will then lift upwards and come off.
Before I did my fixit I phoned Neff service (actually BSH appliance care) who quoted me £60.50 for the first half hour then £45/hour plus parts or £159 for 12 months parts and labour. A bit of a no brainer! Anyway, I provisionally booked a service call but said I would call back to confirm.
2 days later I still had the machine pulled out and the panel off because I was testing it. Phone rings - service engineer to say he's on his way. Thought he may as well look at it anyway. He said I'd done exactly what he would have done except he'd have used new part instead of cleaning out the original. He even cancelled the call off his system so no call out charge!! He also told me that 1 minute on the timer display is actually an error code not the actual time left.
Be warned - after the fix I ran the machine on a rinse cycle - completed ok. Put it on an auto wash cycle and it stuck with 1 minute to go! Much swearing and cursing!!
However all subsequent washes have been fine and it has now been working properly for several weeks.
I took some photos whilst I was doing the repair - I can email them to you if you want.
Hope the above makes sense - good luck.
Sep 30, 2008 | Dishwashers
Neff W4380 error or warning '03'
Hello there,
when the machine makes drowning sounds and beeps error dry (while trying to drin out) blow strongly into the drain pipe. It should result in a higher flow of water out the drain pipe and error 3 should go away.
Jun 02, 2008 | Neff W4380X1 Front Load Washer
Neff slimline dishwasher type S5946
hi there sounds like your wash pump has burnt out
Jan 11, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
Neff W5340X0 Washer Logo
384 people viewed this question
Top Neff Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Billy Detlefsen
Are you a Neff Washing Machine Expert? Answer questions, earn points and help others
