Question about Saeco Vienna Espresso Machine
Ventilate I have not ever made enough coffee for it to signal descale. No water will come out, will not ventilate. I took it apart and cleaned what I could, put it back together. It worked once and then went back to saying ventilate. So, I followed the instructions, no help Thanks Peggy Not my make, it is not listed. iIt's a SAECO V SPRESSO about 2 or 3 years old.
  • 2,039 Answers
You didnt use the machine for a long time start the machine remove the water container if you have a turker blaster fill with water the hole were the water container goes put the blaster in it and apply pressure and try to ventilate and for descaling the machine use descaler not vinergar. vinegar remove calcium in little piece descaler melt it use 1 part descaling produit 1 part water put that in water container start machine open valve turn it off after a few second let it rest for 15 minute and repeat untill empty do 2 or 3 rinse cycle with clean water it important that stuff is corosif thanks for using fixya pierre
Posted on Feb 10, 2008
Cappuccinatore and steam does not work
Does water come out of the wand when you press the hot water button (top left)? Try ventilating and descaling the machine. More details about each can be easily found by googling.
How to descale:
https://www.youtube.com/watch?v=W20FJlKKCO0
How to ventilate:
https://www.youtube.com/watch?v=7sZWJ9z9xTA
http://www.purebean.com.au/office/coffee-machines.nsf/office-coffee-machines/saeco-royal-cappuccino-ventilate-message-showing
Jul 24, 2014 | Saeco Royal Professional Espresso Machine
No water comes out on ventilate. At first, the water was coming out very slowly, in drips. The doser or grind were not the problem, because even when I switched to Hot Water, it was still dripping. ...
Hi
It should take about 45 minutes to an hour to properly descale the machine. If it only took a couple of minutes you really didn't descale your machine. If you used the powder it has to disolve completly before descaling. The best way to descale is with the descaler in the tank. Turn on the machine and run about 8 ozs of water-descaler through the wand and then turn off the machine. Wait 10 minutes and repeatthe last procedure. Do this until the tank is empty. When done with the descaler, rinse out the tank and put fresh water in the tank and run the whole tank through the wand. Then fill the tank and your ready to go.
Nov 13, 2010 | Gaggia Syncrony Compact Coffee...
Gaggia Titanium - can't get it to move beyond 'Ventilate.' This started as a problem with extremely slow coffee output. We've been good about de-scaling but brought it into a repair place who cleaned it...
Select "Hot Water" and open the steam valve. Let it pump water out the steamer for awhile. It usually clears right away but may need to pump a lot of water to clear the error.
If you aren't able to get any water coming out the steam nozzle, you may need to prime the pump with the little squeezy tool they gave you with the machine - or you can use a turkey baster. Mainly you are trying to get water up into the pump to prime it (get the air out of the pump) so it can pump water instead air.
Oct 09, 2010 | Gaggia Titanium Espresso Machine
Lights for descale and grounds drawer flashing red
Have you ventilated the machine . turn to hot water and see if can get water out .
Dec 10, 2009 | Saeco Talea Giro Espresso Machine
Machine says ventilate
Hi
That means the pump needs to be primed by running water through the wand. Push the water button. You will hear the pump change tone when it primes and the light or message will disappear. Also check the steam tip. This can get plugged and prevent the pump from priming.
Make sure that you water hardness is set on 4 in the menu. Descale more often than not enough and you machine will last a long time.
Oct 29, 2009 | Saeco Magic Comfort Plus Espresso Machine
Will no ventilate,no hot water will not descale
HI
You have a calcified solenoid valve for you steam and hot water. It either case it has to be taken apart (which is not easy) or replaced. This is why we need to descale more often. Solenoids work on close tolerance and any scale on them will cause the to stick and not activate. Now they will not open to allow water to flow. So now you can't ventilate. Sorry
Oct 17, 2009 | Saeco Royal Digital Plus Coffee...
GAGGIA BABY. NO WATER COMING OUT.STEAMER FINE
I had exact same problemeven took entire machine apart - all fine. Solution is very simple... descale with Gaggi descaler solution. Remove filter and block, mix solution with 1.5L of water, turn on for 20 seconds, wait 20 rinse through steamer, wait 3 minutes and repeat until all solution used - rinse compeletly with clean water
Jan 19, 2009 | Gaggia Baby Espresso Machine
No steam and ventilate
When you try to get out water, can you get a full cup of water or just a half cup?
How often do you descale your machine?
/Mirran
Aug 17, 2008 | Saeco Royal Professional Espresso Machine
Saeco Incanto -- no coffee coming out
After I posted this I decided to descale the machine again, even though I'd just done it a couple of weeks ago. After descaling and rinsing I tried running water through the brew group by pressing the pre-ground button, then holding down the big cup button. Still no water, but then I turned the little knob on the coffee dispenser counterclockwise, about half a turn. It worked! I rinsed it well, then made a cup of delicious espresso.
Mar 01, 2008 | Saeco Incanto Classic Espresso Machine
Keep reading "ventilate" on the screen
Running hot water button a few times worked for us
Dec 18, 2007 | Saeco Royal Professional Espresso Machine
Saeco Vienna Espresso Machine Logo
204 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
