Question about Oreck XL2600 Vacuum
Oreck vacuum won
I took my oreck apart to remove a sock that sucked up into it, i was able to pull the sock ou ot the motor when it was apart but now even though i have all the screws it won't completely close now. there is a space of 1/2 inch. the motor works fine
    President:
  • 1,673 Answers
Sounds like the motor, fan chamber and the end cover for the fan chamber is not all of the way in place. They have to be on right on top of the scew posts.
Posted on Feb 12, 2008
Oreck vacuum is blowing out air and not sucking up dust. Why is it doing that???
Most likely the air passage from the motor to the bag is clogged.
Take it outside, remove the bag, and turn it on. That may blow the clog out. If not, open it from the bottom, and try to snag the clog out.
May 14, 2015 | Oreck Vacuums
Took apart removed belt plugged in turned on power motor shaft will not spin
Check the electrical connections to the motor and make sure they didn't come loose. Also most people don't know the motor shaft can become dirty and needs to be clean and shinny. Clean with steel wool.
Nov 22, 2013 | Oreck XL2200 Bagged Upright Vacuum
My Oreck vacuum cleane won't turn on
I have an Oreck vacuum. My son used it just earlier today and it worked just fine, then just a little while ago a tried to turn it on to vacuum our bedroom and suddenly it won't turn on! I tried plugging it into other outlets but it was no use. My husband takes a look at it and first thinks that the switch is out in it. He takes the handle apart and quickly realizes that it is not the switch that is causing the problem. Then he took the base of the vacuum apart, removes the spin brush part and cleans it off, puts it back together, and suddenly it works! He said that when those brushes get real dirty the motor gets clogged, then it just won't turn on. I'm just happy I married someone who can figure these things out, because even if I knew the problem I'm still no good with a screwdriver, taking things apart and putting them back together again. Hope this works for your Oreck too and it's running again for you soon.
Jun 18, 2010 | Oreck XL2200 Bagged Upright Vacuum
My oreck vacuum has stopped sucking up things.
It won't turn the brush because the belt is stretched or broke from the heat of sucking something too big up. If you have your service manual it should show you the location of the belt covers to replace it.
Dec 03, 2009 | Montgomery Ward Oreck XL Celoc...
I had a loose wire in my Oreck XL motor. I took it
Lights are 12 volts.
The motor has taps on it to pull 12 volts rather than 120 volts for the lights, uses the motor as a transformer.
Should be black and white to the motor from the switch, believe the switch breaks the black wire. White wire should be neutral. I can't remember colors for the wires to the lights. Would expect it to be the white wire and then the "tap" wire to be red.
One crazy way to do it, is to hook up wires, leave the light bulbs out, turn on power, and check voltage at the bulb socket with a voltmeter. (This is one of those things they tell you on television to only let a professional do, do not attempt at home.)
Aug 07, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Clogged hose
if you have a drain auger then you can stick it in until it won' go any further then you have hit the sock.turn the cable and grab the sock and pull it to the surface.please leave feedback
Mar 30, 2009 | Electrolux Central Vacuum
Wiring schematic oreck xl2600hh
I have a Oreck XL and the propeller that is in the housing will become hard for the moter to turn. I have took it apart and do not see a problem, but when I reinstall the parts it will run for about 15 sec. and the moter will stop turning. When the propeller housing is off the motor turns ok and doesn't stop. Do I need a new propeller/housing?
Nov 06, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL 2600HH
The fan has a nut holding it unto the motor shaft. I sent you the wiring diagram to your email, hope it helps.
Oct 01, 2008 | Oreck XL2600 Vacuum
Kenmore Progressive Model # 116 25914507
I had the same problem with my vacuum. I called in for technical service and was told to push the "reset button". It turns out that there is a small red button right next to the dirt indicator light. I pushed the button, plugged the vacuum back in and started it up and it worked like a charm! :) Hope this helps!
Mar 25, 2008 | Kenmore 23913 Progressive PowerMate Bagged...
Oreck Vacuum troubleshooting
Hi. If the motor is on its way out the motor noise will be eratic eg slowing down speeding up popping noise & a smell of electrical burning. If you have none of these symptoms then chances are its not the motor. Does the bag inflate or is it easy to collapse when you push the bag ? If bag inflates ok check belt. If bag not fully inflating check for blockages along length of the handle pipe its designed to pull apart by lifting up rubber sleeve at machine end of pipe, push ball latch in & pull pipe out remove any debris stuck in the pipe. Remove bbottom of machine as if replacing belt check to see if there is any debris stuck in the oppening that goes to motor fan, then check the fan blades you can see them through the port is there any missing or snapped off. If blades are missing or have big chunks missing you will need to replace. If fan only has minor bits missing then reassemble it should now worl well.
Sep 07, 2007 | Vacuums
Oreck XL2600 Vacuum Logo
211 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
