Question about Nikon Coolpix 5200 Digital Camera
Flash problem with my Nikon Coolpix 8700
When I go to take a picture with the flash on auto it dosen't take the picture the only thing that happends is the letters SB and a red flashing dot appear on the screen but if I trun off the flash it takes a picture fine. what should I do.
Send the camera in to Nikon for a replacement and write a nasty letter. I have the same problem and that's what I did. This is a wide-spread problem. Then once they send you a replacement (that works), quickly sell it on E-bay and buy yourself something that works!
Posted on Mar 09, 2008
My Nikon 8700 will not take any pictures..when I turn it on a message comes on the screen that "speedlight is in the closed position". When trying to take a picture, it buzzes,and an orange light flashes...
Please try resetting the camera to factory defaults first, but it sounds as though it may be a mechanical problem with the flash linkage. You can also use the flash selection on the side
of the lens housing and select "No Flash" to see if the camera will take pictures then. Since you have an attachment for an external flash, that might be an avenue to help you still use your camera. Getting it repaired would be expensive.
Sep 09, 2013 | Nikon Coolpix 8700 Digital Camera
Simple problem: how di i turn the flash off on the nikon coolpix
Press the flash button (Up on the multiselector). This gets you a menu with five choices: Auto, Auto with red-eye reduction, Off, Fill flash, and Slow sync. Select the one you want (eventually, you're going to want to turn the flash back on) and press OK.
Mar 03, 2010 | Nikon Coolpix S51c Digital Camera
No camera flash
If the pictures are good, don't worry. The auto-mode will pop the flash when needed.
If the pictures are not good, check the flash mode and set it either auto or on or fill-in.
Dec 13, 2009 | Nikon COOLPIX S60 Digital Camera
Pictures are blurry - have the red hand flashing
select flash in auto... normally when you turn off the flash. the hand appear...
Aug 06, 2009 | Nikon Coolpix L11 Digital Camera
Flash doesn't work on nikon coolpix l12
I actually just fooled around with mine because it was doing the same thing. It will only flash in the scene mode, but not the normal quickshot mode. i noticed under the camera symbol on the screen said BSS and i went into the menu and clicked on BSS and turned it off b/c it was on and that worked finally.maybe u can try it, if its the same situation.
Jul 20, 2009 | Nikon COOLPIX L12 Digital Camera
I am not able to find, How to turn of the Flash of Nikon Coolpix 8700. When i need to take pictures without flash, but when i click, it automaticaly turns on the flash, and i tried to figured it out how to...
ok. there is a button on the side of the lens. it has an eyeball and a bolt of lightning, press that button and look in the top right corner of the screen. keep on pressing this button until you see; a lightning bolt with a circle with a line threw it. then "click". if that doesn't work switch your camera to manual and try this again.
Jan 11, 2009 | Nikon Coolpix 8700 Digital Camera
Help flash Nixon coolpix L11
hello,
make sure when you press the round selection button on the back of the camera flash option, you press the ok in the center of the button on the back.
it will show brief yellow AUTO in the LCD screen upper right corner for a sec.
when you are going to take a picture holding the shutter button half way down, you should see up at the right corner outside of the LCD screen a red led flashing to indicate flash is ready.
one thing to try if this is not working, find the camera reset option in the menu. after doing this you may have to reset the date & time. it will bring the camera back to default settings
on the bad side if these dont work, possible flash circuit may have failed inside the camera.
good luck!
Jun 13, 2008 | Nikon Coolpix L11 Digital Camera
Nikon CoolPix Flash Problem
This happened to me too!
Turn the dial to setup, push the menu button & select reset all. This will restore the defaults & let you use the flash again.
Feb 13, 2008 | Nikon Coolpix 7600 Digital Camera
About taking picture
u need to set your flash mode on auto mode u can by pressing flash button or u can press menu & selet reset and ok it
Jul 14, 2007 | Nikon COOLPIX S6 Digital Camera
Nikon Coolpix 5200 Digital Camera Logo
99 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
