Question about Intel Motherboard
Mother board dead
When i start the coputer power is flowing @ CPU fan also spining but no display no bees sound, please tell me what is do
  • 4 more comments
  • afaque Feb 19, 2008
    Motherboard dead no display no sound..on boot
  • zee38 Mar 23, 2008
    I have same problem with my ECS KN1 SLI Lite.
    Mobo powers up all fans spinning but no beeps no signal. This sys when I assembled did gave me no start at very first boot I replaced power supply then it started working, but some times it showed same signs what I'm having now but a restart and it worked fine.
    I checked and removed everything & tested in other systems all worked fine. Changed power supply too. I always used 24pin 450 or higher power supplies.
    I removed the board from the case installed video card new power supply and powered it up same problem.
    One main thing I noticed this board has a big plastic back plate below CPU housing and it touches the case floor and when screws are installed this board bends that’s what probably killed my board.
    I noticed lot of postings about this board may be it needs a special case or longer spacer which support the board or may be it had a manufacturing flaw?
    Any suggestions comments ?
  • John Apr 11, 2008
    my emachine T3042 with K7MNF-64 motherboard stopped working. when I plug the power in the fans start working and I hear the harddrive turn. however no beeps no display no start. Is the system toast and just a paper weight or can I fix it
  • shuka Jun 27, 2008
    when turn on the computer every thing runs good except screen runs as black and nothing come on the screen please let me know what is the problem and how can it be fixed .
    Tony
  • harjit08 Jul 07, 2008
    when i start the coputer power is flowing @ CPU fan also spining but no display no bees sound
  • brian c
    brian c May 11, 2010
    Is this by chance an e-machine desktop?
Dear Sir/Madam,
I have Intel original motherboard .there is no display in the monitor, i had changed sevral RAM but still the problem prists.
Please, tell me the reason and my motherboard is in warrenty period plez tell me the service center of intel for Andheri(w),Mumbai. sothat i could replace it.
my contact number 9324341937
SANTOSH THAKUR
Posted on Mar 29, 2008
Dear Sir/Madam,
SANTOSH THAKUR
Dear Sir/Madam,
SANTOSH THAKUR
Dear Sir/Madam,
SANTOSH THAKUR
Hello. Start machine. CPU fan running, pilot light on, network interface shows live signs, no RAM issues. The computer boots, no Intel Logo shows, but only a number 94 at bottom right corner. Screen is black. Model of Motherboard: Intel Desktop Motherboard D94GTP. No beeps, just a black screen.
Posted on Feb 22, 2008
  • 178 Answers
Hello how are you. Please give me ome detailed information the make and model of the computer. i will help you with this. Easy. This is what I do for a living.
Thank you hope to here from you
Posted on Feb 10, 2008
P4M900T-M2 Motherboard cant display anything on display, Power supply fan & CPU fan is running. I changed processor, RAM, Power Supply, Capacitors around CPU, but am still getting nothing on the...
It seem that changing the mother board was needed to confirm as there seems to be a problem related to non communication of the mother board with the CPU, RAM and sections.
Swap and confirm.
Aug 08, 2011 | Computers & Internet
I have lost my audio and video driver how can i find them tell me plzzzzzzzzzzzz
this siddu my mother board is not display no beep sounds no display please solution intel p4 mother board
Dec 10, 2010 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
I need a replacement fan the Tforce 550 SE Mother board
Being so, you need a small standard Fan, ask for it in any coputer parts store.
Apr 26, 2010 | Biostar M6TSU Motherboard
My pc monitor is blackout and no beeps whaen i start up even my hdd is not spinningmy cpu fan is working what is the problem tell me what can i do pls , As done by me----- 1. Clean the RAM memory and try...
If do not hear any beep then it means that the mother board is dead you can try clear the BIOS by removing the battery of the mother board for 5 mins or by shorting the jumper for clearing the BIOS if that didn't help then you have to repair the board or replace it.
Feb 09, 2010 | Asrock P4I45GV R5 Motherboard
Cpu not powering press on button lights flash fans turn for a sec
It a issue with the power supply or the SMPS. Change the SMPS of same capacity and then it should work..............sodeep
Jul 30, 2009 | Compaq Presario 5000 PC Desktop
Power supply Ok.But CPU fans started with seconds It's stop.
sounds to me like your mainboard is bad, i bet if you closely inspect the capacitors around the cpu one or more is bulged out or leaking
Feb 15, 2009 | Asrock P4S61 Motherboard
Problem
My be something wrong with your ATX. It can depend on transistors too. If you have tester you can check all ATX pins.
Sep 07, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
My mother board AOpen MX4LR, socket 478, dead
bad mobo or psp is bad try psp for now lock down mobo tight also losee no good
Jan 06, 2008 | AOpen (MX4SGI4DN2PRE) Motherboard
Intel Motherboard Logo
466 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
