Question about Philips Magnavox 27MS343S 27" TV
Out of Range
I have set up my tv as a monitor for my desktop. Everything works fine but there is a little blue and white rectangle moving up and down and left to right on the screen that displays "Attention, Out of Range". How do I get rid of that. It is very annoying.
    New Friend:
Same thing can't figure it out ??
Posted on Feb 04, 2015
    Brigadier General:
  • 6,966 Answers
You may need to lower down the Screen Resolution or the Screen refresh Rate of you PC's Display Properties a bit.
Good luck and kind regards.
Posted on Feb 10, 2008
    Sergeant:
    Champion:
  • 317 Answers
The refresh rate of your computers graphics card is set either too high, or too low. right click on the desktop, select properties, go to the settings tab, and click advanced. then go to the Monito tab, and play around with the different refresh rates, until the picture will show up. This is usually, around 60 Hz or less.
DISPLAYING ON SCREEN THAT VIDEO INPUT OUT OF RANGE
Right click on the back ground of the computer desktop. If windows XP click properties, if vista click personalise. Now look for settings and move the resolution slider to 1024 X 768. This is the native resolution for this monitor.
If you still have the HZ error, click on advance look for the monitor tab, and make sure it is set to 60Hz
Mar 02, 2012 | NEC MultiSync LCD1525V (White) 15.1" LCD...
I want to know if I can hook up a second monitor to this system?
The HP Pavilion a450n video card does not support 2 monitors. You can hook up a monitor and a TV at the same with the current video card it has. If you wanted 2 monitors you can replace the AGP video card with a new one that has 2 monitor outputs. You will need to get an AGP video card with 2 monitor outputs (DVI or VGA), open up the case, remove the current video card and replace it.
See the HP website for more technical information on this computer:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00058235&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&site=null&key=null&product=392522#N59
I hope this helps.
Apr 26, 2011 | HP Pavilion a450n PC Desktop
How can we connect two moniters to one cpu
To have and use 2 monitors at the same time, you need a video card with a dual VGA outputs.
To use 1 monitor at the time you can buy a VGA switcher, to switch between the 2 monitors.
Best of Luck
Sabre
Feb 18, 2010 | ViewSonic Computers & Internet
Just got a hand me down Benq model t903 19
Quite the opposite -- your new monitor can't handle the screen settings that you're running on the old monitor.
Hook up the old monitor and start up the computer so you're looking at a Windows desktop. If you have windows open, close them or minimize them down to the taskbar so you can see the desktop/background image.
Right-click on the background image and select "Properties" to bring up the Display Properties dialog.
There are tabs across the top of this dialog -- select the one named "Settings"
In the bottom half of the Settings tab, there's a control named "Screen Resolution" with a slider to move between "less" and "more"
Move this slider to 1280x1024 or lower. If you're already at a resolution smaller than 1280x1024, then set it to 800x600 and we'll troubleshoot from there.
Hit "OK" to accept the new settings. Windows will ask if the new settings are OK -- click on "yes"
Now unplug your old monitor and plug in the Benq.
If you are happy with this screen resolution, then you're done!
If you're looking at 800x600 and want to see more, then repeat this process -- go to the Display Properties -> Settings dialog and try a bigger resolution. Hit "Apply" instead of "OK" to try a new setting.
If the screen says "OUT OF RANGE" for a setting, just wait for 15 seconds, and windows will revert to the old (working) settings.
Let me know how this works! If it's helpful, click the little thumbs-up. If it's not, ask questions and I'll try to explain in more detail
Aug 09, 2009 | BenQ Computers & Internet
My external monitor suddenly has a blue tint
Try a different monitor, if it is OK then your 19" monitor is faulty or the video cable is faulty.
Apr 06, 2009 | HP Compaq Presario F730US Notebook
My moniter says out of range.
Video Card has a resolution setting higher than the monitor supports. The below works with XP, may work for Vista as well
Start the PC
Start hitting the F8 key repeatedly until you see a menu
Choose Safe Mode (make sure not to pick safe mode command prompt)
Once you see the desktop, right click on an empty area on the desktop, then choose properties
Find the resolution property in this program and bring it down. 1024 x 768 should be ok
Click on OK til the window disappears
Reboot
Mar 19, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
COMPUTER WON'T WORK WITH NEW HD LCD TV
Sounds like the PC has too high a screen resolution set for the TV to handle
Re-connect PC to PC monitor , change display resolution to 800 x 600 (right click desktop, properties, settings, slider marked "screen resolution" to leftmost side, save settings.
connect PC to TV, TV should be able to display PC data now.
Go through same procedure with PC connected to TV, move slider to 1024 x 768 posn. (depends on TV model as to what it can cope with) - *apply* this setting & see if TV is able to display at this resolution.
If it is, desktop will appear - if not, you'll get the warning box generated by the TV...don't worry, in 15 secs, the PC will revert to the old (working) setting.
Hope this helps.
Dec 19, 2008 | Computers & Internet
Digital Power Saving Mode
Go to your monitor power settings and turn off Hibernation and other monitor power schemes.
If this problem persist, request for more technical assistance from the manufacturers website
Nov 30, 2008 | LG W2252TQ Monitor
How do I increase the size of my desktop and remove the blue border?
There are three size settings you can choose from, Normal, Wide and Zoom. Try changing it using the 'Size' button on the remote or by going into the On Screen Display (OSD) settings. If you don't have a manual you can get one here. Hope this helps.
Mar 14, 2008 | Samsung 192MP (Silver) 19" LCD Monitor
Monitor out of range
Most commonly, this problem is caused by an incorrect refresh rate setting. LCD monitors typically DO NOT support refresh rates higher than 60hz - and this is no exception. Try running the game in "safe mode" if it has one. Adjusting the in-game video settings should solve the problem, just look for a screen refresh rate or any video-related setting with a number followed by "hz". Set it to 60, everything should be fine.
It could also be that at some point the game changes resolution (this frequently occurs if there is an in-game movie or cut-scene). In this case the resolution settings for the in-game movie might be at fault, check them if you can.
Sep 23, 2007 | Computers & Internet
Philips Magnavox 27MS343S 27" TV Logo
340 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
